Tesla Free Energy Air Circuit Design and Testing
Intro: Tesla Free Energy Air Circuit Design and Testing
This video demonstrates a circuit design I found on YouTube called a Nikola Tesla Free Energy Air Circuit. That video showed a hand drawn circuit diagram that looked simple so I decided to build one. Actually, I ended up building a few. This instructable will demonstrate two of the circuits I made. One is just the basic design and the other is two circuits wired in series with a push button to control an led. I connect the circuits to my house ground and an antenna that was already mounted to the top of my house. The antenna was not being used and had been there since I moved in years ago.
STEP 1: First, Follow the Schematic to Build the Free Energy Circuit
First you need to build the "Tesla Free Energy Circuit". So find a breadboard and follow one of the diagrams above.
The first diagram shows the basic circuit and the second shows the schematic for two wired in series.
You will need at least the following to build the first circuit:
4 diodes ( I used 1N34A Germanium Diodes)
2 100pF ceramic capacitors
2 100uF electrolytic capacitors
STEP 2: Now Use Antenna and Ground Connect to Test Out the Free Energy Circuit
1. Find a good antenna
You can use whatever you want for an antenna. I use the one mounted to my roof. It's large and works well. Any antenna will work. However, the larger the better usually.
2. Get a good ground connection.
You can use your house ground connection which is usually really good. I've also used a metal stake in the ground (works best if the soil is wet).
3. Connect a multi-meter and start testing
a. Test the AC voltage of the ground and antenna
b. Test the DC voltage of your circuit (after connecting the ground and antenna to the circuit)
STEP 3: After Hours Testing
I left both circuits connected to the antenna / ground for a few hours while I processed the video. Later on that evening after dinner I checked the voltage on the first circuit and it was near 20 volts! Keep in mind it's still not that much actual power. It would light an LED for a little while but the voltage would drop off quickly. Just being connected to the multi-meter caused the voltage to slowly start do drop. But over time, if dumped into a battery or larger capacitor bank, you could accumulate enough energy to do something more useful than lighting a LED.
STEP 4: Testing With a Wimshurst Machine
These tests demonstrate that the circuit receives more than RF (radio) signals. Any electromagnetic radiation can be received. Any electronic device produces an electromagnetic field. These circuits can pick up this energy and convert it to DC power. This video demonstrates the circuit receiving energy "through the air"; otherwise known as induction.
STEP 5: Testing With Fluorescent Lighting
Another observable repeatable test done with fluorescent lights. This test demonstrates two Tesla Air Circuits being tested with fluorescent lights. Proving that these circuits receive more than just radio (RF) signals. These circuits will harness energy from anything that produces a strong enough electromagnetic field. Anyone with the desire to build the circuit can demonstrate this proof of concept by repeating the tests.
STEP 6: The Story Behind the Testing
More Tesla Air Circuit demonstrations and tests. Plus, the story behind the project and testing. I noticed that the circuits performed better at night. Find out why in the video.
20 Comments
tony17837 8 years ago
Cool Demo. The energy is however not really Free. It is being radiated by from RF sources in you area. For example you local FM rock station. what you have built is a radio receiver. If you added a oscillator to the circuit and tuned it, you might be able to hear Air Supply or Tay Tay if you're lucky.
Ojo 4 months ago
dmainmon 8 years ago
While the circuit does convert RF signals to DC power, radio frequencies are NOT the only source this circuit can receive. In Step 5 of this instructable the circuit is tested with fluorescent lights( https://www.instructables.com/id/Tesla-Free-Energy-Air-Circuit-Design-and-Testing/step5/Testing-with-Fluorescent-Lighting/ ) The circuit will pick up and convert the frequency emitted by the fluorescent lighting ballast.
Teskekl 3 years ago
Well done!
shawnleegabriel 10 months ago
I have four of these. I am thinking about selling them on eBay with my documentations and essays of the system.
andersonjeric 2 years ago
Add a small coil. Tune the RF coil/caps to 1420 mhz.
RF input anywhere. Not dependent on local radio stations.
Has anyone done current measures? mA?
TravisM18 4 years ago
discostu956 8 years ago
I was actually wondering recently if you can get usable electricity from an antenna, so this answers it for me. I'm guessing the stronger the signal and higher the transmission power the more electricity. Cool project, thanks for sharing
After a few hours the single circuit reached nearly 20 volts. The double circuit reached over 8 volts. I had been pushing the button so it had only charged a couple hours; less than the single circuit.
I posted a "Step 3" that shows another video and picture to demonstrate.
rickharris 8 years ago
We are awash in radio wave many of which come from high power sources such as commercial radio stations. Tapping into this sea of energy is of course possible and by no means mysterious - If you include a tuned circuit, a coil and capacitor you will get even higher levels of power "sucked from the air"
On a small scale this is no more than what a crystal radio does, on a larger scale, large enough to be useful your going to upset a lot of people by creating black spots in their transmission pattern, it won't take them long to find the source of the problem.
Free energy? 1. this isn't really free as the transmitted signal has to be paid for 2. Free energy doesn't, as such, exist. energy can neither be created or destroyed, only changed from one type to another. If anyone wants to extract "free" energy they will be bett off looking at solar, wind or water power.
ImBarticus 6 years ago
rickharris 6 years ago
https://en.wikipedia.org/wiki/Wireless_power_trans...
That wasn't my point.
This type of energy leech is "cashing in " on the wealth of high power radio transmissions that surround us.
It isn't extracting energy from the ether. And neither did Tesla.
bodo 8 years ago
it depends on he sumation of thecirquits asmach as you can connect in paralle you gat asmauch power
McantonyP 7 years ago
Hello
which antenna did you use?
Thank you
emp0001 7 years ago
Hello,
which voltage rectifier you used ?
Thank you.
nnadine1973 7 years ago
Nothing 'free' here. You made a receiver. I used this 30 years ago to power up a small bulb, nothing more. The energy is coming from the radio stations around so, theoretically, with a very long antenna and decent earth plug, may squeeze out about 1or2 watt .
russ_hensel 8 years ago
20 volts or even 1000 volts is not energy, it is potential energy. To get energy out of it you must have charge flow, or current. Since current is charge/time, current * voltage = power.
Allow some current to flow, measure it, do the math, and let us know how much power you are able to harvest.
This is free energy in the sense that you do not have to pay for it ( except the capital cost of the device ). It does not violate thermodynamics, or extract the so called "vacuum energy"
Nice Idea and execution, let us know some more results please.
