The Galvani-Edison Luminiferous Aether Disturbance Generator
Intro: The Galvani-Edison Luminiferous Aether Disturbance Generator
The Instructablist would like to draw attention to the recent developments by Messrs. Galvani and Edison and the use of their research in developing a practical Luminiferous Aether Disturbance Generator.
Readers are warned that there are considerable risks involved in using Galvanic energy in this way and care should be taken at all times to alleviate the risk of death or even worse, as the long term dangers of luminiferous aether disturbances are currently not fully understood by luminous aetherium scientists.
YOU PROCEED AT YOUR OWN ACCEPTANCE OF THESE RISKS.
STEP 1: Collect the Parts
The Luminiferous Aether Disturbance Generator was, to a certain degree a build up of randomly found bits from an original concept. Originally, a brass holder for an Aether Disturber with a Galvanic energy controller was purchased with no real idea how to use the device safely.
Then, by chance, the inventor came across a suitable sized protective chamber sold by Messrs. Ikea & Co of Sweden. Described by them as a BEGÅVNING Glass dome with base, but unable to speak Swedish, I can only presume that BEGÅVNING is Swedish for "Safety". As of today, I can say that the completed Luminous Aether Generator has continued to work safely whilst encased within the protective BEGÅVNING Glass dome with no known side effects or health risks.
Other items collected were some Galvanic wire connectors, a Galvanic Energy Variable Flow Restrictor from Messrs. Sodial of Amazonia (somewhat curiously referred to as a "table lamp whole range dimmer") and an LED (Luminous Edison Device) Aether Disturber capable of having its emitted luminous aether regulated by the restrictor device.
A suitable wooden mounting base was also purchased to provide both a stable support whilst protecting the user from the Galvanic elements of the design in the form of a turned wooden bowl.
Eagle eyed Galvanists will also note that there is no earth attached to the metal base. This is because everything within the base is double insulated and my house is also protected by an ELCB. However, if you are concerned, you should fit an earth to the metal base and the Aether Disturber holder.
STEP 2: Luminous Aether Generator Base Design
It was found that the brass Aether Disturber holder could be mounted centrally on the brass base by using the screw on Galvanic cable holder and a suitably sized hole was drilled. Similarly, a hole for the Galvanic Energy Variable Flow Restrictor was drilled and then fitted beneath the brass plate. The extra holes around the rim were designed to allow the brass base to be surely fitted to a wooden plinth, which had the dual purposes of containing the huge Galvanic energies involved whilst providing a stable base in case of an excessive Luminous Aether flux disturbance causing a breech in the time-space continuum field (fortunately, as it turned out, not an issue, but as always, better to be safe than sorry). The smaller holes were used for standard brass round head slotted screws, the larger holes for suitably powerful bolts. In reality, only a couple of screws were necessary but it was felt more were visually better. Random placement would also work. The only criteria is to make sure that none of the screws pierce or come near the cables or Galvanic Energy Variable Flow Restrictor.
All holes were drilled using a pilot hole followed by a larger drill if necessary. Using this particular base it was also found best to drill from the top as, although it appears to be a solid brass base, it is in fact a composite base of an alloy centre with a brass sheet outside. Drilling from inside can cause the brass sheet to distort.
STEP 3: Installation of the Galvanic Energy Flow Restrictor and the Energy Directors.
It is important to channel to the Galvanic energy safely through the Galvanic Energy Flow Restrictor to the brass Aether Disturber holder. In order to facilitate this, the protective cover on the Galvanic cable to the Aether Disturber holder was cut away for approx. 7.34cms in order to splice in the Galvanic Energy Flow Restrictor cables. The "live"/brown cable was cut into two, the safety insulation pared back and the Galvanic Energy Flow Restrictor placed in the circuit, using suitable two-way lever wire connectors.
Finally, drill a large centre hole in the wooden bowl (approx 2.451cm) and a smaller hole in the side which is used to take the Galvanic energy conductor through to a suitable plug.
To complete the Luminiferous Aether Disturbance Generator, feed the Galvanic energy conductor through the two holes in the wooden bowl and the mount the brass base on to the bottom of the upside down wooden bowl before inserting the Aether Disturber in its holder.
STEP 4: Luminiferous Aether Disturbance Generator Testing and Usage Information.
IT IS VITALLY IMPORTANT TO BE FULLY TRAINED IN THE USAGE OF AND AWARE OF THE DANGERS OF BOTH GALVANIC ENERGY AND LUMINOUS AETHER DISTURBANCES. YOU HAVE BEEN WARNED! FURTHER PROGRESS IS AT YOUR OWN COGNISANCE.
- Connect the Luminiferous Aether Disturbance Generator to an appropriate external Galvanic energy conduit source.
- With the protective cover removed, turn the Aether Disturber holder switch to "On".
- Test Galvanic Energy Flow Restrictor performs by rotating the control dial. There should be a visible variance in the luminous aether disturbance.
- Replace the BEGÅVNING (Safety) Glass dome.
Now, bask in the heady glory of your Luminiferous Aether Disturbance Generator as it brings the healing power of Aether waves to the darkness of your night.
There is also a little piece of satisfying personal theatre involved as you have remove the BEGÅVNING (Safety) Glass dome before turning the Luminiferous Aether Disturbance Generator on or off, always remembering to return it for the safe operation of the device.
Finally, I have entered this into the Galvanic Institute's 1897 Exhibition at the Crystal Palace where I hope to gain a Prince Albert of Saxe-Coburg and Gotha Award. Should you be visiting, please vote for me.
55 Comments
EddieTheAwful 4 years ago
Of course, the storage of something as elusive as galvanic energy would be absolutely impossible. It is such a shame that the usefulness your galvanic disturbances will never be realized outside of the few major cities that supply galvanic energy. Still, good show!
wobbler 2 years ago
Apologies for the delay in replying to your esteemed missive. I have been elsewhere engaged in pursuits, the nature of which I would not like to generally disclose at this moment in time for fear of my competitors in Galvanism leapfrogging my latest development. However, I am sure I can rely on your honour as a gentleman not to disclose this new form of transport.Just think of the potential of Galvanic energy in revolutionising transport. I am developing a new carriage which has a large hamster wheel mounted on it. Within this wheel a horse is placed and the wheel then turns an attached Wimshurst machine, which then provides the Galvanic energy to turn a suitable motor to drive the wheels.
At the moment though my experiments have been less than successful due to the Galvanic motor not having been invented yet so my current carriage stays resolutely in one place unless pushed. Another problem also seems to be that if the horse attempts to cantor it generates an excess of Galvanic energy. I have already lost three cart horses due to Galvanic shock as well as one stable lad who was standing too close at the time. I do however have plans to try having the next cart horse shod with gutta-percha horse shoes and wooden nails with the hope that that will solve this reliability problem. After all, you don't want to find yourself marooned far from home with a dead horse just because you decided to put on a burst of speed, maybe even as much as a calculated theoretical maximum of 10mph per horsepower.
I am considering calling it the Equine Powered Horseless Carriage or just E-Carriage for short and I have high expectations that once fully developed it will revolutionise the world as we know it.
Your esteemed servant, etc.
Wobbler
Taz-Hood 4 years ago
wobbler 4 years ago
I commend you on your furthering of Galvanic energy control but controlling by touch? What wizardry is this? I can only assume you have been dabbling in mystic Eastern arts but would warn you about the dangers of the potentially unknown consequences. You only have to look at Dr. Strange to realise the dangers of the path you appear to be following.
There is however great potential in your development and I look forward to furthering my own delopments by incorporating some of your esteemed ideas.
As for your underwhelmed admirers, pity them, they do not understand your genius, athough it may become painfully clear if they accidentally open a portal to another dimension by touching Buddha in tbe wrong place.
Wobbler
CaptClaude 5 years ago
wobbler 5 years ago
However, from your quaint spelling of humor, I can only conclude you are a Colonist and, as such, still somewhat behind on the latest developments in these advances The future is bright, the future is luminiferous aether.
Galvanism is the only way forward, the new energy of choice, Sir, steam has had its day and is for punks.
I remain, your humble servant, etc.,
Wobbler
Yr Obvt Svt,
Capt. Claude Rotier, 2nd U.S. Volunteer Engineers, Retired
MichaelB256 5 years ago
wobbler 5 years ago
However, these are actually moving pictures based on Magic Lantern slides. Should you not have a Magic Lantern projector, can I suggest you reproduce the effect of motion by either moving your head from side to side whilst observing my Daguerrotypes or by keeping your head still and oscillating your preferred viewing device?
I'm also sorry to hear that you have shenanigans, but I have heard that medical science is on the cusp of a breakthrough and in future they will be controlled, if not curable.
wobbler 5 years ago
wobbler 5 years ago
Please pass on my deepest condolences to your next of kin should your demise prove fatal. Walk in the path of the Cord and rest in pieces.
wobbler 5 years ago
wobbler 5 years ago
As to the assistant name, four letters seem to be de rigour, thinking of Igor or Hulk, but you need to go with something exotic/edgy/faintly scary. How about Mike?
From my experiments with frogs and Galvanic energy, I would suggest it would help if you could practice twitching in front of the mirror. The frogs will of course be happy to at long last be going back to their pond, should I find you to be a suitable test subject for my further experiments. I presume you aren't allergic to copper or too lanky? Lanky, twitchy and flailing limbs can be dangerous, even when controlled by suitable restraints, plus it's all about size for assistants. Traditionally, unencumbered by being overly tall is an asset, small is beautiful, although beautiful is a definite no-no.
If you still feel you meet the criteria, we can discuss terms, but I would suggest a 100year internship is a good starting point.
jimgarbe 5 years ago
wobbler 5 years ago
Plus, even if you do succeed, have you ever tried ironing a Luminiferous Aether Disturbance Generator? You really should stick with your original choice unless you always want to be remembered as "whatever happened to that guy who tried to wear a Luminiferous Aether Disturbance Generator?".
