The Double Sided Modular Altoids Survival Tin
Intro: The Double Sided Modular Altoids Survival Tin
There are Tons of Altoids Survival tins on the Internet but; Mine is Double the Space and is FULLY Customizable ( I will add Velcro later and show you how to add add ons! )
Materials Needed:
2 Altoids Tins
Double Sided Sticky foam
Duck Tape
Scissors
Time to Assemble:
15 Minutes
Materials Needed:
2 Altoids Tins
Duck Tape
Scissors
Time to Assemble:
15 Minutes
STEP 1: Set Up and Asembly
Place Tins upside down, I have them so the tin flaps will open from the same side. ( Pic 3 )
Press sticky tape on one side of a tin leaving one side of the tape with paper still attached so you wont get dirt or stuff on the foam. Overhang tape a little over edges of tins then trim off with a exacto knife or scissors.
( Pics 4&5)
Remove paper from sticky foam and press tins together. ( Pic 6 )
Line up Duct tape and score a line ( or use a ruler..LOL ) and tear at scoring then wrap tape around the tins a few times. ( Pic 7 )
( Pics 4&5)
STEP 2: Final Assembly
I Placed the sticky foam inside and put a few demo items inside tins and also cut a piece of the tape to hold the small items it.
Well; Thats it, I will post MORE pictures as this project is just getting started, it will have Velcro ALL around it and you will see more to come!!!
Enjoy
Dane
Enjoy
Dane
22 Comments
1inspirit 10 years ago
evilmadcow 10 years ago
what's up this ALL CAPS?
EyeWander 10 years ago
I am not sure who or what you are referring to.
1inspirt
what:
his usage of all caps.
sorry for the confusion, eyewander.
Veewee111 10 years ago
Perhaps velcro strips would do same job without turning pins gooey.
HickLife 8 years ago
What if you riveted the 2 together? You could start out just like shown and once they are the way you want them drill some holes in it (maybe 1 in each corner and one in the middle of each long side) and then use a hand riveter. Won't be sealed completely unless you calk between them or use something else before riveting but will be good for loose stuff
Fingerprickre 9 years ago
Really Cool Idea!!
Captain MacTavish 10 years ago
Nice idea EyeWander, I gotta hand it to you!
lastoldbat 10 years ago
hmmm... wonder if I could "stack" more than two, possibly by alternating the side which opens....?
maybe you could add altoids smalls containers around the regular altoids?
marcellahella 10 years ago
So; keep racking up your ideas and I will Gleam from you too!!
SJU87 10 years ago
you could use JD Weld as previously suggested to permanently "weld" and seal the two together and then use a Dremel tool to cut a hole between the two. This would allow larger items to fit in the case.
this would also be handy for some of the electronic projects in Altoid cases - maybe put a iphone charger and headphone amplifier in one unit?
great concept
ocbeaner 10 years ago
PhilKE3FL 10 years ago
windbag 10 years ago
patron_zero 10 years ago
