The RMDSS V1.1 (Removable Mag Dual-Shot Shotgun) (internals!)
Intro: The RMDSS V1.1 (Removable Mag Dual-Shot Shotgun) (internals!)
This is my RMDSS v1 (Removable Mag Dual-Shot Shotgun). It fires two bullets (along side each other, not on top of each other) at the same time, and has a removable magazine which holds 18 rounds (9 shots), which are green rods attached to a grey connectors. Being a shotgun, this gun is pretty freakin' huge: it's 9 layers thick plus two extra, (connectors clipped to empty rod space) weighs a lot, and is about 24.5 inches long.
This gun took me a long time to get right. First was the issue of the mech, which turned out really complicated, then the issue of a good magazine/ammo, then the issue of making a good pin guide for two ram rods, and finally, I had a lot of firing inconsistency which took a while to nail down. (it shoots good every time now!)
Let's see some pros/cons, shall we?
::PROS::
-Fires two shots at the same time
-Looks quite awesome
-Comfy (even distribution of weight)
-Has awesome red dot sight (modded from knexpete's)
-Has two ram-rods
-Has a sturdy pin guide
-Large mag capacity -->18 rounds (9 shots) (mag can be extended too!!!)
-Can hold many rubberbands
-Awesome range - 30-60 feet (30= ~1 band, 60 = ~4-5 bands)
-Removable and preloadable double mag with internal pusher (modded from Knex.X's)
-Epic pullback length
-Uses the awesome handle from my ASR v1!!
-Never jams
::CONS::
-Very piece consuming (it's 9 layers thick...)
-Uses a few cut pieces (but don't all guns use 'em nowadays?)
So that's about it for this gun. I'm very proud of it and how it turned out. (my best gun so far (imo))
Special Thanks:
Knex.X - Magazine
knexpete - Red dot sight
Please let me know what you think about it in the comments! I'm open to posting this beast!
-FlyingFish10
UPDATE: Yes, this gun will be posted! However, I want to enter it into the upcoming K'NEX competition, so expect the instructions up sometime very soon after July 1st (2013).
::PROS::
-Has two ram-rods
-Never jams
::CONS::
Special Thanks:
Knex.X - Magazine
-FlyingFish10
31 Comments
Oblivitus 10 years ago
FlyingFish10 10 years ago
megustatrains 10 years ago
-looks: 4.5*
-sight: 5*
-range: 5*
-capacity(mag): 4*
overall id put it 5* :D
beanieostrich 10 years ago
DarkOwlProductions 10 years ago
Now that I look at this a bit more closely, I'm realizing how awesome that handle really is. I have very long fingers, and that handle is looking really comfortable.
Keep Calm and Don't Listen to DarkOwlKnex; he talks in the third person and probably should see the internals before critiquing a firing pin. :3
The Red Book of Westmarch 10 years ago
>>Update<<
I changed the front to a flatter version, and gave you credit in the special thanks! What do you think? And should I post?
