The Mini Electrostatic Generator
Intro: The Mini Electrostatic Generator
here ist an instructable on how to make a small electrostatic generator.
STEP 1: Wath You Will Need
you will need:
A 9v battery
1x NE555 (Timer IC)
1x 10k pot(you can yous any 10K pot)
1x 15k
1x 47nf(MKS is a good one)
1x 1nf(MKS)
1x BD241 or BD242(or any similar N transistor)
1x audio transformer 1:10 - 1:100 or small hv transformer
14x 1nf-47nf 1-2kv
14x 1N4007
Here you see the diodes, capacitors, 9V battery and the HV transformer.
A 9v battery
1x NE555 (Timer IC)
1x 15k
1x 1nf(MKS)
14x 1nf-47nf 1-2kv
14x 1N4007
STEP 2: Solder
Solder everything together and then solder a cable to GND, and a cable to the negative hv.
Construct all nice and handy in a plastic box.
STEP 3: How to Yous It
Ok now the fun can begin. The first thing you can do is to load objects not too big and not too small electrostatic.
GND should touch your body, now touch the object with the HV cable. The object is now negative loaded. when you now touch the object, you will get shocked.
The other things you can do, is to load yourself negative up. If you now touch someone, the person will get shocked.
Put the GND cable under your shoe, glue a piece of foil under your shoe so you have better connection to the ground. The HV cable should touch your body.
Now you are ready to shock your frends with your finger.
For questions visit www.ultra-voltage.com
34 Comments
admin 15 years ago
kalana45 8 years ago
I am a university student.please help me.I want create static electricity in PVC pipe how to this create.I want help from you .thanks
RufioD 9 years ago
Question. Is there a way to ... connect this to a duster to make sure the duster would be constantly charged and collect more dust? I'm a janitor btw, the "static dusters" just aren't high powered enough and really just poop out after u use them enough, I was thinking a battery powered static duster would be awesome.
takyatane 10 years ago
1nf capacitor will be charged more quickly than a 47nf capacitor right?
so what's the better way? i think that with 1nf we will have a high frequency when sparks discharge, and with 47nf we will have some powerfull spark gap?
is that right or wrong? thank you if reply
ps: i'm french so sorry for the bad quality of my english ;p
amandaparkes 10 years ago
jatenelef 11 years ago
If i may, the component count could be greatly reduced by replacing the 555 with a transistor and using a "Blocking Oscillator " circuit. and the same audio transformer, followed by the transformer used in flash bulb triggers circuits in throw away cameras..
As always take care whom you play with though, pacemakers don't take kindly to high voltage pulses and remember that ladies have lower resistance due to water nearer the surface of the skin, you might just get yourself a healthy slap ... have fun, and ill put up a "blocking Oscillator cct later
very best regards.. G8NLF.. qrz.com
oliverkellow 11 years ago
Wouldn't the alternating current mess with the recharge time of the giant capacitor, or do you cut that out of the circuit and feed it directly to the transfromer?
Any chance of getting a back-of-the-napkin sketch if you don't plan to Instructable it, i can even offer to clean it up as a tutorial if i get it working!
connect NE555 pins 2 and 6 (not shown in diagram).
Also, to test put a speaker across where the secondary pins are on the transformer.
You need a solid sound that can be adjusted with the pot.
Dreistein 12 years ago
MrMGN 12 years ago
Of course static electricity isn't the amazing thing it once was so for this to work as a good bar trick I need to be able to charge myself up (or create a high voltage current to pass through my body and leap from my finger) as subtly as possible, is this the device for the job? Or would it be just as effective to shock one hand in my pocket with a piezo generator from a lighter and the spark jump from the other finger? Thanks!
coilsinamotor 13 years ago
funky alex 13 years ago
turner_chris1 13 years ago
yann245 14 years ago
333333 14 years ago
Articas 14 years ago
the_dude09 15 years ago
duckythescientist 14 years ago
mikemmcmeans 14 years ago
toddjwood 14 years ago
