The Official Guide to Knex Ball Machine Path Selectors
Intro: The Official Guide to Knex Ball Machine Path Selectors
STEP 1: Vertical Path Separator
Tracks: 2
Height: 1 blue rod
Video: Almost any ball machine
Instructions: Just see the pictures
(Pictures: RNB, Shadowman39)
STEP 2: Horizontal Path Separator
Tracks: 2
Height: tilted ramp for momentum
Video: A lot of ball machines, here's one (0:24)
(Pictures: Darth Trainman, Shadowman39, knexknexknexknex, collinjo12)
STEP 3: Giant Car Switch
Tracks: 2
Height: 2 red rods
Video: Seen in Project 360 (2:46)
STEP 4: Infinity Switch
Sorunome's redo of YardKing's version allows many paths coming out of this ball separator.
Tracks: infinity (but no-ones ever tested)
Height: 1 Blue rod + tilt for momentum
Video: http://www.youtube.com/watch?v=1WP-c4BjMmY
Instructions: https://www.instructables.com/id/Knex-Ball-Machine-Elemenit-Infinity-Switch/
STEP 5: Bezempje95's Infinite Switch
Tracks: As many as you want
Height: 1 blue rod + tilt for momentum
Video: www.youtube.com/watch?v=LfatMtT_IXI
Instructions: None yet, but here are a lot of pictures:
https://www.instructables.com/id/My-collinjo12-guide-to-KNEX-Ball-Machine-Element/step54/Path-Separator/
STEP 6: Shadow Separator
Sandroknexmaster made his version of the infinity switch, where a ball activates a motor at the end.
Tracks: As many as you like
Height: Tilt for momentum
Video: https://www.youtube.com/watch?v=3B0PKqlQx7I
Instructions: https://www.instructables.com/id/Shadow-Separator-a-knex-ball-machine-path-separato/
STEP 7: Leapfrog Separator
Sandroknexmaster also made the leapfrog separator, which is kinda similar to the previous step except all the balls are released at the same time.
Height: 3 Green Rods + 1 Green Rod per Track
Video: https://www.youtube.com/watch?v=EtPe_q9TV9g
Instructions: https://www.instructables.com/id/Leapfrog-Separato...
STEP 8: Circular Path Separator
Shadowman39 built a curved path with barriers that push the ball out the way, which also get raised and lowered.
Tracks: 10 in example, but can be increased
Height: 1 red rod
Video: http://www.youtube.com/watch?v=hBJBwLS1Ijc
STEP 9: Orange Slide Path Switch
This switch is a remix of the horizontal path separator and a module of the infinity switch. It was built by Mmtunligit.
Tracks: 2
Height: 1 blue rod
Instructions: https://www.instructables.com/id/Knex-Orange-Slide-Path-Switch/
STEP 10: Barrel Roll
Each ball releases the previous ball, then gets caught in a different position. While doing this, the mechanism rotates 90 degrees.
Tracks: 2
Height: 1 red rod
Video: Explained in this ball machine (0:32)
Instructions: Follow the pictures
STEP 11: Thibault's Switch
Thibault made a switch which is a mix between the 'Infinity Switch', 'Mechanical Dizzy', and the 'Barrel Role'. It uses a Ferris wheel element connected to small barriers positioned across a track.
Tracks: 8
Height: 1 red rod (+ tilt for momentum)
Video: http://www.youtube.com/watch?v=ISlkZ2mMBCM
STEP 12: Quad Switch
collinjo12 Made a smaller version of Thibaults's separator.
Tracks: 4
Height:
Video: https://www.youtube.com/watch?v=y17Um0F5gzI
Instructions: https://www.instructables.com/id/Quad-Switch-Knex-Path-Separator/
STEP 13: Mechanical Dizzy
Featured in project ARCANE by Yardking, this has a small Ferris wheel element geared to a path that turns around.
Tracks: 8
Height: 1.5 red rods
Instructions: See YardKing's comment below. (Remember, his version is for golf balls, so the entrance at the top [tagged in first pic] needs extra space.)
STEP 14: Octoswitch
Caverat built this separator. This is an inconsistent separator, as it relies on a motor spinning which a ball lands on, then rolls to the side.
Tracks: 8
Height: 3 blue rods
Video: https://www.youtube.com/watch?v=A4bcZbW7qfk
Instructions: https://www.instructables.com/id/Octoswitch-a-Knex-path-separator/
STEP 15: Trainman's Switch
Tracks: 2 (but can probably be modified)
Height: 1 red rod
Video: https://www.youtube.com/watch?v=NdmFTE_1qU4 (3:54)
STEP 16: Rotating Crane Arm
Tracks: As many as you want, if it fits.
Height: Tilt for momentum, or have elements
More pictures: https://www.instructables.com/id/Knex-Ball-Machine-Erection/step2/Path-Separators/
STEP 17: Motorized Tilting Panel
Do not use with other crankshaft lifts that run at the same speed.
Tracks: 4 (can be modified)
Height: 1 red rod
STEP 18: Tilting Panel
By Shadowman39, this is a small panel with 4 exits, each one leading to a lever that shifts the panel's direction. Explanation as tags in the picture.
Tracks: 4
Height: 1 red rod
Video: http://www.youtube.com/watch?v=rugwVv6ZZsA
STEP 19: 2 Way Panel Separator
This version of the Tilting Panel Separator is made by Borisv9. It has less paths than Shadowman's version, and is a lot more compact.
Tracks: 2
Height: 1 Blue rod
Video: https://www.youtube.com/watch?v=IAPyLNLodao
Instructions: https://www.instructables.com/id/Knex-2-Way-Panel-Separator/
STEP 20: 3-Way Geartrain Switch
This switch was built by Mmtunligit, it evenly divides three balls by combining the vertical path separator and the barrel roll.
Tracks: 3
Height: 3 blue rods
Video: https://www.youtube.com/watch?v=mitgAJy3ra8
Instructions: https://www.instructables.com/id/Knex-3-Way-Geartrain-Switch/
STEP 21: YSL's 6-way Ball Separator
This switch was built by YoloSweggLord. It has two 3-way ball separators connected to a frame, and the frame tilts to change which side the ball goes to.
Tracks: 6
Height: 3 blue rods
Instructions: https://knexflux.net/instructions/ysl's-6-way-ball...
STEP 22: Double Drop and a Reset
Best used with other switches, this switch I made first saves one ball, the second sets it off, and the third resets the switch.
Thibault also made a version, probably earlier, in his ball machine 'the Millenium' (2:00).
Tracks: 3
Height: 1 red rod
Video: Seen in this ball machine (1:45)
Instructions: Just look at pictures
STEP 23: Stacker Separator
Tracks: 3
Height: 1 red rod
Video: https://www.youtube.com/watch?v=dPcrNoxN0V0
Instructions: https://www.instructables.com/id/Stacker-Separator-a-knex-ball-machine-path-separat/
STEP 24: Raiser Lift
A ball lift I attempted to make but had no proper entrance track mechanism, making it consistently inconsistent.
Tracks: 2
Height: -1 red rod (ball goes up or down)
Video: http://www.youtube.com/watch?v=I-WB3c2Y4RA
Instructions: https://www.instructables.com/id/Knex-Raiser-Lift/
STEP 25: Lifts With Multiple Exit Tracks
Lifts such as the chain lift (including most modifications) and the quadruple arm lift have different ways of holding the ball, and different places to hold to ball, meaning the ball can fall off at either point.
(Pictures: collinjo12, mathsboy314)
STEP 26: Separating Arm Lift
This lift is similar to the quadruple arm lift, except the separator is in the arms instead of the hands. When the ball reaches the top of the lift, it rolls down the arm, and falls off at a different point in each arm.
Tracks: 8
Height: -6 to -10 red rods (it is a lift)
Video: https://www.youtube.com/watch?v=cTLSKf1oqyI
Instructions: https://www.instructables.com/id/Separating-Arm-Li...
STEP 27: Inconsistent Elements
If the ball element doesn't always land in the same place, it can classify as a ball switch.
(Pictures: KneXtreme, Shadowman39, Darth Trainman, Sandroknexmaster)
STEP 28: Elements That Don't Reset Instantly
If the element doesn't reset, the next ball probably wont go the same way as the first ball. For it to be a proper path selector, one of the balls must reset it. (Almost all basic 2-path switches would fall under this category.)
STEP 29: Compact Separator
This is another element that doesn't reset instantly, built by www139. This separator is convenient because the entrance track is a basic ball machine path.
Tracks: 2
Height: 1 Blue rod
Video: https://www.youtube.com/watch?v=FJCJdsscgJs
Instructions: https://www.instructables.com/id/Compact-Separator-a-Knex-ball-machine-separator
STEP 30: Ball Waiter
When a ball is waiting to enter an area (e.g. lift) and a new ball comes around, instead of joining the queue it can roll to the side instead.
Do not use with lifts that quickly collect balls
Tracks: 2
Height: tilt for momentum
Video: https://www.youtube.com/watch?v=owQMRP64UrM
(Picture: Sorunome)
STEP 31: Double Drop
STEP 32: Quadruple Drop
Tracks: 4
Height: 1 blue rod
Instructions: https://www.instructables.com/id/Knex-Ball-Machine-Dragonfire-new-elements/step5/Four-balls-divider/
STEP 33: Other Multiball Elements
(Pictures: mathsboy314, Sandroknexmaster, Sorunome, collinjo12)
STEP 34: Size Selector
Tracks: 2
Height: tilt for momentum (+1 blue rod in one track)
STEP 35: That's It!
Happy Knexing!
42 Comments
Borisv9 4 years ago
I'm also going to try and make instructions for ShadowMan's 4-way panel separator.
Tator283 4 years ago
Borisv9 3 years ago
mathsboy314 4 years ago
GameCrusher218 5 years ago
Mmtunligit 8 years ago
I have made a new one:
mathsboy314 8 years ago
Added, step 8!
Mmtunligit 6 years ago
And another:
mathsboy314 6 years ago
Inserted at step 18.
FanPlastic 7 years ago
Here is one I made, But it has never been tested with the 2 piece balls https://www.instructables.com/id/Wheel-Switch-a-Knex-Ball-Path-Selector/
mathsboy314 7 years ago
That falls under step 23. Can you think of a better name for that step?
Not really, howzabout " super silly stylized switches of superbity"
www139 8 years ago
https://www.instructables.com/id/Compact-Separator-a-Knex-Ball-Machine-Separator/ here's one from our latest ball machine :)
Added, step 24
www139 8 years ago
NorthernF 8 years ago
I made this horizontal infinity switch about 2 years ago but I forgot to post it here looking through some old photos I found some pics of it. I don't have any instructions for it but I think it isnt that hard to figure out...
www139 8 years ago
sandroknexmaster 10 years ago
https://www.instructables.com/id/Shadow-Separator-a...
And the second :D
mathsboy314 10 years ago
I've saved this, but the title isn't changing.
Thanks for the separator!
Thanks for adding!
