The Original IPad: Diptych
Intro: The Original IPad: Diptych
STEP 1: The Archaeology
STEP 2: Harvesting
The process of extracting usable lumber from a log begins with splitting.The tools needed are very simple: a small hatchet used to make wooden wedges, a large sledge, and a saw or axe. During a particularly windy storm, the top half of a white pine tree came smashing down in my back yard. The tree it fell from was not the healthiest one on the lot due to a previous split a few years prior, so when the top fell it had already been attacked by bugs and there was a huge sap ball from where the tree was trying to heal. The log was split down the middle by sequentially driving wedges down the axis of the log and repeatedly striking them with the sledge. When the log was split in two I could then examine the interior grain of the log and select the best possible (least worm ridden) area to use. This selection was then sawn from the rest of the log and split once more, this time vertically to remove the outer rounded side and create a plank roughly parallel on two sides.
STEP 3: Hewing and Truing
This plank was then taken to the work bench where it was further shaped and smoothed out with the hatchet. This process proved to be dangerous due to the blade angle of the hatchet. Historically this hewing would have been done with an adze or a broad axe –two tools that are honed on one side only, the other side remains flat. Because the hatchet is sharpened on both sides like a “V” it is more useful as a cutting or splitting tool. When used to hew it tended to bounce away from the smoothing plane of the plank and often back toward my hand.
When the plank was hewn I was then able to take a plane and smooth it down perfectly flat; first by “scrubbing” across the grain to remove the big imperfections and then “running” with the grain to plane it smooth and flat. The same was done to the other side to bring it perfectly parallel with the first side. To ensure it was square and parallel I used a carpenter’s square- a tool directly from antiquity that remains unchanged to this day.
STEP 4: The Problem With Unseasoned Wood.
STEP 5: Carving
Having planed, sized and squared both boards the next step was to carve out a recess to receive the wax writing surface. This was mostly done with a gouging chisel, a tool with a “C” cross section designed to remove a large amount of wood. The smoothing of the recess was done with flat carving chisels for the bottom plane and side with-grain walls and carpenters’ chisels for the end grain recess walls. This carving process surprisingly proved to be very different for the two boards; one board carved very easily, but was more difficult to vertically cut the end grains, the other board was harder to cut and attempted to grab the gouge and run it past my markings.
Next, I drilled two holes for the hinge string. The ancients apparently favored a type of drill bit that was flattish and had a centering spade. These drill bits are still found today and are often used for making larger holes than spiral bits can accommodate. I attempted to use this drill bit with a makeshift bow drill on a bit of scrap wood, but was so terribly unsuccessful that in order to not ruin the diptych I decided to cheat and use a spoon drill bit and a brace drill. The spoon bit is also historically accurate to the Roman times, however the brace drill is dated to the 14th or 15th century a.d.
STEP 6: Wax On, Wax Off, Wax on Again
After coating the recesses with beeswax it was noted that any marks created on the yellowish-green wax were difficult to see in addition to the wax being somewhat transparent and being able to see a knot in the wood through it. The wax also proved very difficult to remove any writing markings by either scraping or smoothing. Upon re-inspection of the historical artifacts, it was then that the blackness of the wax was noted. Culling through internet sites suggested that the blackness was due to lampblack (soot), and furthermore adding the lampblack inclusions changes the consistency of the wax slightly and makes it easier to warm and erase. This being noted I removed and re-melted the wax this time adding a pinch of soot scraped from my wood stove, which ultimately fixed both the legibility and the hardness of the wax
13 Comments
Edbed 8 years ago
Great instructable. I love the way you started from a tree and showed the whole processes. If you want to try using getting the colour with lampblack check this out https://www.instructables.com/id/Lampblack/.
boaslad 8 years ago
This is awesome. Thanks for bringing back some childhood memories. My grandfather had one of these that I used to play with when ever we would visit. Apparently they were still in use in one facet or another during the colonial days. Grandpa said HIS grandfather used to use one in school. The one I used to play with was made of Cherry wood and had black hinges instead of twine. The two sides of the tablet were "locked" together by threading the stylus through 3 leather loops opposite the hinges.
dsmith84 8 years ago
Thanks! That's really cool that they were still around so late! I would have liked to use a nicer wood than pine, but it was a windfall and I couldn't pass on the opportunity to do something out of it. I really like the "lock" idea, I may have to add it now!
macniven 9 years ago
This is fantastic, I was looking to see if anyone had done this, as I would have posted an instructable as well, but you have not only made beautiful tablet, you did so using the most low-tech approaches. Congrats! Perhaps you could call it Wax tablet to make it easier to find!
dsmith84 9 years ago
Thank you! I would definitely encourage you to post your own
instructable for this topic. I'm sure that you have lots that you can
add or techniques I missed that someone would find helpful (for whatever
interest there may be out there for this). Thanks too for the advice,
I'll add "wax tablet" to the tags.
chonny 10 years ago
dsmith84 10 years ago
chonny 10 years ago
marccase 11 years ago
dsmith84 11 years ago
jon_chalk 11 years ago
