Thirsty Flamingo Soil Moisture Detector
Intro: Thirsty Flamingo Soil Moisture Detector
Moisture sensors are used in a variety of different projects. You can use them to test the moisture levels of different materials and even test the moisture levels in the walls of your home if you suspect they're damp. In the thirsty flamingo project, we're going to use a soil moisture sensor to monitor the humidity levels in our plants' environment. Every beginner gardener knows that it's not enough to water your plants, you also need to monitor the levels of moisture in the soil in order for your plants to stay healthy. The build we're about to show you is based on a soil moisture sensor that alerts you when the soil moisture in your plant dish changes.
https://www.youtube.com/watch?v=TBVYdHl1SKc&feature=youtu.be Note: in the video, you'll see an older version of circuito.io.
STEP 1: Electronics
The Electronics
We used two main components in this build - a soil moisture sensor and a Piezo speaker. The speaker starts playing a tune when the soil moisture levels reach below the pre-set threshold. After testing the circuit, we also made a custom PCB for it so that it would fit nicely into the 3D printed casing we designed.
Main Components:
Arduino Pro Mini 328 - 5V/16MHz9V
Alkaline BatterySparkFun
Soil Moisture Sensor
Piezo Speaker - PC Mount 12mm 2.048kHz
Secondary Components:
Transistor - NPN BC337 DiodeRectifier - 1A 50V
Resistor 1k Ohm 1/6 Watt PTH
STEP 2: Wiring the Circuit
Click here for a detailed wiring guide.
STEP 3: Code
Code
You can find the code for the project on our Github repo
After downloading the code, upload it to your Arduino using the Arduino IDE. Make sure to set the correct board and the correct port before you upload.
The main logic of the code uses the soilMoisture.read() function. If the soil moisture level reaches below 400 (or whichever value you decide to set), it triggers the piezoSpeaker to start playing a melody, in the case - piezoSpeakerHooray.
STEP 4: Casing
We designed a flamingo-shaped casing for the soil moisture sensor circuit. You can go wild and design different shapes and sizes of casings according to your liking. There are two main parts to this design, and you can download and print them from Thingiverse .
STEP 5: Putting It Together
After printing, you’ll need to place the circuit into the housing and screw together the using the screw holes in the design. Afterward, place the battery into place - and you're done! Let us know how everything goes. You’re welcome to share your experience with us in the comments below or on our community forum.
For the full tutorial visit our blog.
Enjoy Making!
21 Comments
dhouts 4 years ago
Hillhomer 5 years ago
A flamingo making the hooray sound just doesn't seem fit... :-D
osterac 5 years ago
AbbyS36 6 years ago
I have everything set up, but the code isnt working on my arduino uno. :(
Circuito io 5 years ago
Hey, try the updated code here - https://github.com/Circuito-io/Thirsty-Flamingo
AdopteUnRoux 7 years ago
Great project !
How long long do you expect the battery life to be ?
Circuito io 7 years ago
It really depends on the battery you're using, but generally speaking, it will probably last a few weeks. You can also select a different power source on http://circuito.io :) Good luck!
Per OleT 7 years ago
Hi
Really nice project you got here, but it seems the piezo speaker functions has changed in the updated version from circuit.io. It means that the above change in the .ino-file not working. Other than that. Cool idea :)
bluagd 7 years ago
Hi,
i did the circuit as described, but is not working correctly. When I put the sensor on the soil, it starts to sound, even when the soil is totally wet.
What may be wrong?
Thanks
eyak 7 years ago
(B) also: Serial.println("High moisture detected"); should be changed to: Serial.println("Low moisture detected"); We're sorryyy! and will fix the guide accordingly. Thanks for letting us know.
bluagd 7 years ago
Hi,
What may be wrong?
Thanks
muhammet resule 7 years ago
Rectifier - 1A 50V
why did we use these two items in the project.
eyak 7 years ago
The diode is a "fly-back" diode, meant to protect the circuit from reverse currents, but in most cases this diode will not be necessary with piezo speakers, but more important with regular (coil) speakers.
WoonkyeongChoi 8 years ago
And I have one more question.
Could you let me know why you chose those electronic elements but not others?
What is the size of that flamingo case?
SudiartoHsu 8 years ago
this is great project, but i don't have a 3D printer.
Akin Yildiz 8 years ago
great stuff.. building circuits and programming are getting easier each day. circuito.io is a great example of that, thank you for sharing.
are you familiar with my work. all of our instruments are solder free and ready to program; https://www.instructables.com/id/the-Plant-Doctor-f...
you should instead use usb rechargable powerbanks.!!
payasonegro 8 years ago
great x 5 :)
Could I do it with an UNO or UNO nano?
(I am new with that)
DorT2 8 years ago
Heating the printer ;)
ArifSae 8 years ago
A great case design, Thumbs up!
