Transistor Amplifier Build
Intro: Transistor Amplifier Build
I've made a couple of these. I found the original schematic online then modified it because I did not have one of the parts the original plan calls for. My design allows the use of much more common parts. Although it uses more parts and is a bit more complicated.
STEP 1: The Schematic
Looking at a schematic is always how I decide of I want to build a circuit or not so I will present it first. I found the one I based my design off of here:
http://www.redcircuits.com/Page1.htm
Although mine isn't exactly like that one it is essentially the same topography. It sure looks simple enough doesn't it? That is why I choose to build it myself. I made my schematic because I did not have a TLE2141C Op-Amp. If you do then you can build the original and it should be easier than building mine.
IC1 and IC2 on my schematic are 15 volt regulators I used 12 volt ones. SL4 from the power supply section should power the lower voltage dual op-amp of course.
STEP 2: Board
I've made so many of these I'm not really so sure which is what anymore. I know I cleaned the schematic up a little before I uploaded a screen capture of it for the previous step. I'll be honest, often when I am doing an electronics project I just want something to work so I don't spend as much time as I should making my schematics as neat as I could before I move on to the next step.
Just so long as everything is hooked up you know? Sometimes I find while I am routing a board that some things aren't connected to each other too! Then I have to go back and fix that.
Anyhow the one I am including here looks pretty good to me. If anyone finds any problems then let me know and I'll see what I can't do to fix it.
STEP 3: Power Supply
First I'll cover the input stage of the power supply for this project. It is a center tapped, rectified, then filtered configuration. Exactly like what is described here. Now I'll get some mileage out of that Instructable. No one ever bothered with it as of now.
You can see in my picture that I have 40 volts between my VCC and VEE, which gives me +-20V. Close enough for the 22V the circuit calls for.
STEP 4: Choose Your Poison
I've made this amp on perfboard, and etched boards for it too. Either way works. I'll offer some build pictures in this step.
STEP 5: Closing Thoughts
This is a pretty loud and sweet sounding amp to me. With my circuit one of the op amp sections of the dual op-amp is used as sort of a preamp stage and the trimmer next to it is a gain control. I like mine loud. The other trimmer by the transistors is the bias setting, jack it up until amp misbehaves, then back it off some. You're good to go!
I've had a Fender tube amp, I have a Marshall Lead 12, and I've a couple of these amps I've built. I like my amps the best out of the bunch. You could easily find someone willing to soak you $100 or even more for an amplifier like this. So why not build one out of some junk and rock instead?
Oh for the output transistors any matched audio transistors seem to work to me. If the pin outs of your transistors are different either bend the legs around or change them in the schematic and reroute. If the whole project blows up, well that is even more rocking! One of mine already has.
This ain't no cheese whiz LM386 amplifier. This puppy pumps.
23 Comments
vyeek apalma 7 years ago
Omnivent 8 years ago
Hi,
"Anyhow the one I am including here looks pretty good to me. If anyone
it."
Took a quick look at your board and must conclude that you dislike board layout as much as digital electronics ;)
Normally I'd say "back to square one" to a layout like this - 8 unconnected traces, more than 10 acid traps, awkward component orientation and just as awkward "pads" and traces not commanded by the schematic, topped of with this very strange build-up of rectangles (was it meant to be a pseudo copper fill?). Not sure where you connect ground from the power supply either. Just went down with a fever and a blinding headache, so I might have missed other stuff.
If you need help fixing it, just say so - I could make the schematic more readable as well.
An even quicker look at the overdrive pedal that you link to, seems to have very similar layout "qualities". I didn't look at what other layouts you may have posted, but if it's a trend, you might wanna practice some simple layouts before diving in the deep end :)
pfred2 8 years ago
I am grateful for any help you can offer. Just link to your fixed files in the comment section here. Thanks for the comment.
clevelandstorms 11 years ago
ARJOON 12 years ago
pfred2 12 years ago
ARJOON 12 years ago
still glad that i got a reply
pfred2 12 years ago
ARJOON 12 years ago
pfred2 12 years ago
Get some of your geeky buddies together and toss a shipping container into the harbor or something! If you can manage to round up that many geeky friends then just start a company with them. Shipping containers are heavy, and the best you could hope for pulling off a stunt like that is getting all wet from the splash.
If there is any meaning to life it is making your dreams real. In order to do that it involves a lot of effort in your waking hours though.
mdog93 12 years ago
pfred2 12 years ago
I've learned to strip stuff that is similar to stuff I want to build, in this case old home stereos or radios come to mind. Though TVs and car stereos may have useful components as well.
As to where its found, well it is found in the corners of people's basements, maybe the bottom of their closet. Ask folks. It seems today everyone has some old electronic thing they don't want and would love to get rid of.
For experimenting the vintage stuff has more easily used parts too. So the older the better. I have no use for new SMT stuff myself, but there is always an LED or maybe a switch or something I can use so I take it as well.
The real good stuff to get is obsolete commercial stuff. That stuff has so much better parts in it than the consumer electronics. But somehow some people manage to latch onto that then decide it may be better if they got rid of it.
So ask around and keep your eyes open.
mdog93 12 years ago
Sorry, last question i promise- if i had to buy all of the parts for this project, how much would it cost roughly? Would it still be cheap?
Thanks mdog93
pfred2 12 years ago
One of the very first electronics projects I can remember doing was when I took a cassette player and somehow managed to find the input for the amplifier section in it. I think I took a resistor from the positive and poked it around until I heard it make a loud noise or something crude like that. Then I hooked a microphone directly up to that spot and put that microphone onto a piece of scrap plywood, stretched some fishing line over it, and had me a guitar!
That was a long time ago now, and I did a lot of projects in between then and the amplifier in this article. It was when I got that to work that I figured maybe I have a knack for this sort of thing and the rest is as they say history.
Today I know I've no special talent, just a little luck and a lot of persistence.
One thing I have done for laughs is use a regular home stereo as a guitar amplifier. I think they sound a bit flat, could use some more aggressive biasing, or something, but it does work. Just working is an advantage though. With my circuit I cannot extend any real guarantees to others.
With hobby electronics it is often more about the process than the end results. That being said your process can yield impressive results sometimes.
mdog93 12 years ago
pfred2 12 years ago
If you like things black and white digital logic may be what you're after. There it is either on or off. Analog is a whole other animal. I suppose there are theoretical ideals which are never attained, but there is a lot of fun to be had in between too!
mdog93 12 years ago
pfred2 12 years ago
One thing I regret omitting in my article was outlining the subsections of the circuit. I think being able to grasp this is important to understanding a circuit. Then those circuit snippets can be handled in an intelligent fashion. What that also means is entire circuits do not, and often should not be built all at once. So I'll do that now and it may help you in reading my schematic, others too.
I'm probably not 100% correct with this but hopefully you'll get the idea and look at circuits as sums of their parts. Better than looking at schematics as big confusing mazes. Though they are that too.
Making the sub section block leap was a big step for me comprehending electronics. Everything is digestible if I break it down into manageable bite sized chunks. Put another way big jobs are more easily accomplished when broken down into lots of little tasks.
mdog93 12 years ago
Quercus austrina 12 years ago
Qa
