Turn Your Old DSLR Into a Microscope!
Intro: Turn Your Old DSLR Into a Microscope!
Did you know you can use your SLR's zoom lens as a microscope? I didn't!
My uncle gave me an old SLR film camera that he didn't need, Because he knows that I love taking electronic devices apart, I was really happy because I'd never taken apart a SLR camera! A couple minutes later, My 5 year old cousin came to me and asked me "What are you doing with that camera?" So I told her that I want to take it apart and save all of the small parts, Because I might be able build something out of them (as I always do).
Just for fun (and to make her laugh), I removed the zoom lens and held it up to her face as if I was a pirate that was looking through binoculars, And what did I see? Well, Nothing, Because it was out of focus.
This gave me an idea: I know knew that the lens should magnify something, So I looked far away, But everything was still totally blurry. I thought that if it doesn't work when I look far away, Then it might work for a close up: I looked at my hand, And yes: I could see the tiny dust particles that were on my hand! I was SHOCKED! I have a free microscope!
Yes, I know this a weird story, But it is 100% true!
I'm sure will use this a lot, And what could be better that a free microscope? A microscope with incredible magnification like this will probably set you a few hundred dollars back!
STEP 1: What You'll Need:
Materials:
A DSLR Camera (Canon EOS Rebel Ti- SLR Film Camera)
Super Glue (Epoxy can work too)
A Small Handle (this was salvaged from a broken toolbox)
2 Zip-ties
Tools:
Hacksaw
Vise
Pliers
Wire Cutters
High Power Lighting (I used SpectrumLED with only the cool LED's on max. brightness)
A Smartphone (If you want to take pictures)
Why: Reuse that old dust collector (AKA camera) that you don't need!
Protection Gear Needed: None
Cost (for me): FREE!
Needed Skills: Gluing, Hacksaw-ing
Approximate Time: 15 minutes
STEP 2: Remove the Lens
To remove the lens, Press on the button that I've shown in the picture, You might have to turn it a bit until it pops off.
These are 28-90mm lens, In case you're wondering
STEP 3: Fully Extend the Lens, and Super-Glue It in Place
Fully extend the lens (maximum zoom), And glue them in place with Super-Glue. Drop a few drops through the crack, As I show in the picture.
Because the picture will be totally blurry if it isn't extended to the maximum, It is a good idea to add glue, So you don't have to manually adjust it every time...
STEP 4: Saw the Handle
I wanted to add a handle to make it more comfortable to hold, Because it would help your hand from aching and shaking...
I used a handle that I salvaged from a broken toolbox (don't buy cheap ones!), And sawed part of the handle off, As shown in the picture.
STEP 5: Glue & Zip-Tie the Handle on the Lens
First, I glued the handle onto the lens with Silicone Adhesive.
And after that, I added two Zip-Ties on each end to help hold it with more strength. A Hose Clamp will work too.
STEP 6: Example Pictures
These pictures were taken with a phone camera, Which means the quality isn't the best. When I look through it with my eyes, I can see dust particles on ceramic capacitors, Yes! THAT SMALL!
Oh, This has already saved a pretty expensive appliance in our house, That had a burnt transistor
27 Comments
Yonatan24 8 years ago
If you don't have a zoom lens of a camera that you don't use, You can always take only the idea from this Instructable, It will still work fine as a microscope...
This is a film camera so I can't use it even if I want to
Yep, I could have sold the camera on eBay, But a microscope would probably cost a lot more than than what I could sell it for
alamaral 8 years ago
That's true, Hot glue could be better for making this :)
camera_Joe 5 years ago
This is great but as an alternative...If you simply take the lens off the old camera and turn it around, holding it back to front on the old camera body and set the lens to its widest position you will get a high level of magnification and be able to take high quality stills with the old camera. You can buy a metal ring on ebay for a few bucks called a reverse ring adaptor which screws into the front of the lens, where the filter would normally go and will even allow you to mount the lens backwards on the dslr camera. The wider the lens the greater the magnification! have fun.
Yonatan24 5 years ago
The lens for the camera I use here was a useless film camera, but I think I tried this with my current DSLR and it didn't work.
3967 7 years ago
I use a cheap 3$ Webcam with manual fixfocus objectives. The can
changed to an extreme near focus ( approx 1cm) so you have a fullsreen
view of electronices
Yonatan24 7 years ago
I don't have a webcam, but I'll keeo that in mind.
Thanks for the tip! :)
RonC36 8 years ago
Just an FYI for you.... Such lenses are not junk just because they are attached to an old film camera. Most are fully compatible with new DSLR cameras especially Canon and Nikon SLR lenses and including the one you show in your photos. The lens you are using is actually a nice consumer quality lens that is still sold by Canon - for around $190 new and between $20 and $30 on eBay. Not to spoil your fun but I'm quite sure you can buy or make a much better microscope than this lens makes for less than that. You are to be commended for your creativity though!
Uh-oh... :)
alanjamesblair 8 years ago
This was my first thought. However, using this idea, we now have a way to recycle all those old FD and AE lenses. But EOS are still usable.
Near me there is an electronics Goodwill where I can pick up an old FD lens for a few bucks. I use them to do silly things like DIY tilt-focus. But something like this seems perfect! Thanks for the idea, yonatan24!
Sorry. I meant EF lenses for the EOS systems.
николайм 8 years ago
очень плохая идея. Мало того что испортили объектив, так еще и результат отвратительный, изображение не покрывает и пол кадра.
And in English...?
Google Translate:
You wrote: "A very bad idea. Besides that messed up the lens, so also the result of a hideous, the image does not cover even half of the frame"
Why do you say messed up the lens? These lens can still be mounted on a camera, And the super-glue can easily be broken off because of its fragile properties. This Microscope is NOT meant to be used as a photography microscope, When I look through it with my eyes, I can see the full image...
Why don't you keep your "hideous" thoughts about my projects to yourself, This microscope was made for me, Not you... Thanks...
Gursimran Singh 425 8 years ago
Congartulations on winning !! :-)
Thank you so much! I have to admit that I'm pretty surprised that I won, This is such an easy project!
I think the difficulty level doesn't matter you have nice and clear pictures as well as new idea!! It is just awesome!! You deserve this!! Rock on!! :-)
12Samzo34 8 years ago
Thanks for pointing that out! I didn't know that :)
Now that makes a lot of sense, because I've seen the term "Digital-SLR". I'll keep the title as DSLR but I'll change the camera that I have to SLR
