USB Magnetic Stirrer
Intro: USB Magnetic Stirrer
A magnetic stirrer is a great improvement in your workshop whatever the craft you plan to focus on. Actually I use it for paint, varnishes, resin, chemicals and even for parts or brushes cleaning ! Just turn it on and do something else. In contrast to myself it never get bored stirring.
Initially I found a lot of DIY instructions online. But most of them seems to me over-complicated with sometimes voltage regulator modules, and needed a dedicated +12v power supply unit. I did not have all that fancy parts on the shelf and did some investigations.
To stir well, a 12v fan should be powered between 4 (light stir) to 6v (hard core stir). Slower motion is probably not needed except for fine chemical purpose, and faster motions makes the magnetic attraction of the stir bar problematic. So what you really need is a power around 5v. Good news ! Like me you probably have a lot of 5v sources everywhere in the house, neither it's cheap adapters or USB ports. So you can really build a simple magnetic stirrer with a limited amount of parts :
BOM : 1x enclosure (printed or DIY)
1x Power Switch 6mm 3P
1x USB-A inlet
1x 60mm fan (12v)
1x 5mm led (optional)
1x 180 ohms resistor (optional)
5x 6x8mm neodymium magnets : 2x for the rotor, 3x for the stir bar (flea)
or 2x 6x8 neodymium magnets for the rotor + 1x stir bar (20>30mm or +-1")
This is a <5€/30mn project.
NOTE : all these parts are really common, you can use reclaimed ones. The minimal requirement is a 5v source, a 12v fan and magnets. Basic.
Watch the embed video for the building instructions.
The printable enclosure can be downloaded for free at : Thingiverse ; thing #2220363
Enjoy ;)
6 Comments
fuzzyhypothesis 7 years ago
Nice build. Any chance you could change the thingiverse post so that it could be printed out by 3rd party vendors (that folks that don't have a printer could buy from)?
J-Max 6 years ago
Actually the button "get this printed" seems accessible.
J-Max 7 years ago
Hi, thanks ! I understand some people may not have access to a 3D
printer. Well, on Thingiverse it seems every option is turned on. If I
missed any option, feel free to tell me what box I need to check.
Anyways you can simply forward the link or the .stl file to any trusty provider. For
example, download the .stl from thingiverse, then upload it in
3dhubs.com. If you're lucky enough to have a fablab in your
neighborhood, just go there with the thing number ;)
Actually I am not sure what the button would be. I do know that on some thingiverse items there is an "Order this printed" option on them. For example this spherebot
http://www.thingiverse.com/thing:844167
J-Max 7 years ago
That was about the Creative Commons license. I needed to allow commercial use of the thing. I did. Enjoy.
J-Max 7 years ago
I meant *which box I need to check (oops).
