USB Solar Charger
Intro: USB Solar Charger
This Instructable will show you how to build a cheap and easy USB charger that charges by solar power.
STEP 1: Acquire Materials
You will need the following:
•An Altoids tin
•a small car USB charger
•a small toggle switch
•a rechargeable nine volt battery and a clip
•a small solar panel
Other Tools/Materials: drill, Dremel, some wire
A screwdriver, and hot glue.
•An Altoids tin
STEP 2: Take Apart the Charger
Find the screw on the front face and remove it.
Take off all the casing.
STEP 3: Cut the Holes
Use the Dremel to cut a hole for the USB port on the side and another hole for the switch. Drill two holes in the top for the solar panel wires.
STEP 4: Soldering
Take the ground wire from the clip and solder it directly to the strips of metal that come out of the charger. Take the positive wire and solder it to one of the pins on the switch. Then put another wire leading from the switch to the positive strip of metal on the charger. - see the pictures for help.
STEP 5: Put Together
Mount the components into their holes and hot glue them.
STEP 6: Solar Panel
Lead the two wires from the solar panel through their holes.
STEP 7: Solar Panel Prt. 2
Solder the panel's positive wire to the positive wire coming from the battery clip. Solder the panel's ground wire to the outside strip of metal on the charger.
STEP 8: Wait
Let it sit in the sun for a couple hours and plug it in!
STEP 9:
A full battery will give your iPod about 15% charge.
13 Comments
jlandreth1 10 years ago
iDrwish 9 years ago
Yes, the size of the solar panel will vary in the Amps coming out of it also in the voltage, however you need to Calculate the right size of the the Panel, the relation isn't straight forward meaning more amps meaning faster battery charger, what you need to do is charger the battery by around 10% of it's Amps, so figure out your battery rating then get your panel :)
nsrt44 9 years ago
hi I wonder if you could give the circuit diagram
Ryhorn12 10 years ago
Solarcycle 10 years ago
You're essentially charging two devices, the external backup battery and your phone, at the same time. This instructable explains what kind of charge controller and power is required to perform this task and give constant phone charge even under non-ideal conditions: https://www.instructables.com/id/DIY-Solarpad-Kit-...
Marik I. 10 years ago
laffinm 10 years ago
piedrabob78 10 years ago
osoriocj 10 years ago
kmjrmalfunction 10 years ago
jogendrasingh 10 years ago
because i was thinking that how can i double the storage capacity.
http://createyourownbots.blogspot.in/
this Solar phone Charger very important example of Solar energy for daily life.
thanks.
