USB Led Light
Intro: USB Led Light
USB led light
STEP 1: Materials
USB plug and cord
Blue LED (any other color will work too)
100 ohm resistor
Case or housing to hold the led ( I used a cheap mini keychain flashlight housing)
Tools Needed to do this project
Soldering iron
Solder
Pliers
Screwdriver to take apart case
100 ohm resistor
Soldering iron
Solder
Pliers
STEP 2: Assembly
Open keychain flashlight housing and remove all components. Solder positive wire of USB plug to the positive of the LED, solder the negative lead to the 100 ohm resistor, and solder the other end of the resistor to the negative of the LED. Install components in case.
STEP 3: Test It
Connect to a working USB port and it should light up. :)
32 Comments
G.one 12 years ago
and i can't afford another USB cable
markee2 12 years ago
copied from
http://www.simple-electronics.com/2011/08/usb-led-lights.html
bilal.a 16 years ago
nodoubtman 12 years ago
Good luck! :)
thank you!
amitesh.chanda 12 years ago
ranger_steve 12 years ago
ahmad2117 13 years ago
nbagf 14 years ago
windrago 13 years ago
windrago 14 years ago
I mean writing an app in C# for example.
ForenceKiller 13 years ago
ranger_steve 14 years ago
dna24 14 years ago
rakol1 16 years ago
ranger_steve 16 years ago
poop11346 15 years ago
jgeekw 15 years ago
Jahoovi 15 years ago
