Unclogging Rust-Oleum Nozzle
Intro: Unclogging Rust-Oleum Nozzle
I love Rust-Oleum spray paints because of the wide range and quality. Most of the cans can even spray at any angle, even upside down. But I quickly encountered one big problem: The nozzles get blocked easily.
Getting spare nozzles is not that easy, and not cheap either.
So I devised a way of unclogging the blocked nozzles, which seems to work quite well.
But before you try my invasive method, maybe also try some other methods mentioned in the comments section and on the web:
1. Use a can of brake or carburetor cleaner to clear the nozzle.
2. Soak it in mineral spirits/white spirits/mineral turpentine or paint thinners to soften up the gunk, and then try to blow it out with an air compressor, or clean it with a thin wire.
If none of these methods work, I hope mine will do the trick, as described in the following steps.
STEP 1: What You Will Need
1. A small awl
2. 1 mm drill bit
3. A thin needle with a thickness of approximately 0.7 mm (2nd picture)
4. A pair of pliers to grip the needle with.
5. A blower bulb or something similar to test the flow of air through the nozzle.
STEP 2: Remove the Jet From the Nozzle
With a sharp object (I use a small sewing awl) pry out the black jet from the white nozzle body (1st picture). A miniature screwdriver should also work. Be careful, the awl can easily slip and hurt you! The jet can also shoot out unexpectedly and land you don't know where.
Things should now look like the 2nd picture: the jet on the right and the nozzle body on the left.
See if the jet is clogged or not, as shown in the 3rd picture. If the orifice is not clean and round, it should be cleaned with the needle. It is important not to dig around with the needle, because that will destroy the spray pattern of the jet. Force the needle straight through the jet as seen in the 3rd picture, and slide the jet along the needle a few times to clean it.
If the jet is clear, you can now test the flow through the nozzle itself using the blower with air or water. If the flow is non-existent or weak, the problem probably lies with the horizontal canal/passage between the jet and the vertical opening into which the can's spout fits (last picture).
STEP 3: Cleaning the Blocked Canal
We're going to clean up/rebore the canal with the 1 mm (1/32 inch) drill bit (1st picture).
As shown in the 2nd picture, we just drill down the canal. You'll feel when the drill bit reaches the vertical opening inside after about 6 or 7 mm, and that also means the canal is now cleared.
Blow any swarf out with the blower, and just pop back the black jet (3rd picture). The nozzle should now be working perfectly again (last picture).
STEP 4: Prevention Is Better Than Cure
Of course, best would be if the nozzles do not get clogged in the first place, and this can supposedly be prevented by removing the nozzle each time after you've used it, and placing it in a container filled with mineral turpentine (white spirits). I've only just started using this method after getting the tip on the internet, and still have to see if it is 100% effective.
Of course, if you go to the trouble to blow some mineral turps/thinners through the nozzle after each use, you'll probably have the best results in maintaining your nozzles.
And of course, always wipe the nozzle's jet after using, as stated in the instructions on the can (you did read that, didn't you?)
55 Comments
KeithM2 1 year ago
mxx 1 year ago
Willys36 2 years ago
mxx 2 years ago
Devinkrack 3 years ago
How the devil do you get the STEM unclogged? That's the paint-waste I'm tired of
mxx 3 years ago
JohnnyNight 4 years ago
Just go back to Customer Service at Walmart where you probably bought the goop and tell them the nozzle is all stuck up and they'll give you some new ones. Even if you didn't buy them at Walmart they don't care, they give you new ones anyway. I walked up to Customer Service and just pulled the Rustoleum Spray Can out of my bag and I didn't even say anything and the girl didn't either.. LOL..! She just reached down and pulled up this big plastic container of nozzle heads and handed me a couple.
And if you don't feel like hiking over to Walmart just call Rustoleum on the phone and they'll send you and handful through the mail... I just did that..!!
I do like the idea though of turning the can upside down and spraying till the paint stops coming out and just the compressed air comes through..!
God Bless..!!
Quiggley 6 years ago
Although the "turning the can upside down and spraying until no more paint exits the nozzle" will work on some cans (where instructed on back of can), it doesn't work on the cans that allow you to spray with the can in positions other than with the can straight up and down. These are typically the cans with the nozzle as shown in the instructable. Turning the can upside down to spray only allows the paint to continue spraying out without clearing the nozzle.
instructible01 6 years ago
jimmytvf 6 years ago
with MTN paint, is even worse!!! they clog every damn time! even they sell nozzles, with the 94 paints, i always have to buy at least 3 or 4 extra nozzles (0.10cts each) but man, when it's about to clog, it spites some blobs and you have to start all over. I know they are meant to make graffiti, i use them to paint objects as well. I know some proffessional painters and what they do is soak them overnight with acetone, i didn't tried that though...
mxx 6 years ago
I also still have to try the acetone method. And I know the blob spraying all too well. Of course the answer is to make sure the nozzle is properly unclogged before you start spraying. ;-)
Dawsie 6 years ago
nice I have a couple of cans that have never been used simply because I can not get them to spray at all I did not notice the problem until a few months after I had bought them and of course lost the docket {lol}
I have them sitting there now for a few years now never been able to get a spray out of any of them. I always keep spay can nozzles (don’t know why never used them before but had been told years ago to keep them {lol}) so I went through my stash of nozzles but nothing has worked so far, yep they work on other spray cans. The trick I use is fly spray to clear out the nozzles when finished {lol} it works or even a can of WD40 I have two cans sitting around with no nozzles so I can use the spray paint nozzles on them to clear them out.
I am at a loss as to why these two cans will not spray at all I have checked the spout on top of the can and that looks clear as best as I can see {lol}
I have used the old trick of a tire valve placed over the can and with the air compressor pumped them up which also shows me their pressure just as if it was a tyre and that’s correct for a can that has not been used yet.
Last option I have is to cut the cans open and use the paint with my minture model spray painter.
SvenZ3 6 years ago
After usage wipe with cloth, turn upsidedown and spray until no more paint exits the nozzle. then you are done!
bgreen3 6 years ago
Here's my secret: Tips are most likely to get clogged when cans sit unused for a while, however, there are often times when I spray something really large and use multiple cans at once. The trick when using multiple cans is to pop off and save unused nozzles and just use one of them for the entire project. 5 cans of paint = 1 nozzle for the day and 4 spare nozzles for the future! By planning ahead I always have backup nozzles. :D
mxx 6 years ago
Thanks, bgreen3, makes sense!
jimvandamme 6 years ago
I use one bristle out of a steel brush to get the dry paint out. Also, I have a stash of "good" nozzles.
mxx 6 years ago
Jimvandamme, I've not had success with the bristle method, but will give it a try again. Maybe I wasn't patient enough.
justiniano 6 years ago
What I use is to bed in auto paint thinner for a while and work nice for me of course rechek with a drill bit lower or almost the same size of the nozzle you can find it at hobby or miniature tool suplire.
mxx 6 years ago
Thanks, justiniano, I've not had much success with auto paint thinners before, but will try it again.
mtdc 6 years ago
