Universal Portable USB Charger
Intro: Universal Portable USB Charger
Hello! In this Instructable I will show you how I built myself a universal portable USB charger. I am soon attending a weekend festival with camping and I realized that my crappy chinese "10000mAh" USB power pack won't last that long. I have my phone (Galaxy S4), a GoPro and my friends will also want to stay charged. As I fly RC multirotors, I have a handful of various LiPol batteries - so why not use them as a power source?
This charger can be powered by pretty much any source from about 7V up to 30V and can deliver 3A USB charge current. I am powering it from 3S (11.1V) LiPo's, but it should also run from 2S (7.4V) LiPo's, car batteries (both 12V and 24V) and even solar panels.
The parts are readily available and I believe you can build this under $10.
Let's get started!
STEP 1: Parts List
Here are (almost all) parts that I used in this project.
- Project box (This is from my local electronics store, they are based in Czech and Slovak Republic)
- Universal PCB
- 3x USB type A sockets
- 10Kohm resistor
- 33Kohm resistor
- DC-DC step-down converter
- LED voltage display
- Switch
- Wires
Not on the photo, I also used a 2-pin screw terminal and 2-pin male and female PCB headers.
I used a XT-60 connector for the main power connection, which is commonly used with RC LiPol batteries. However you can use anything else instead to fit your needs.
You will need a soldering iron, solder, files or sandpaper, hot glue gun and a dremel tool, along with basic tools (screwdrivers etc.).
You will also need a digital multimeter.
A USB voltage-current meter is very helpful for testing your charger.
STEP 2: Initial Planning
I started by cutting the PCB roughly in half and making a cutout in it, so that it will fit nicely around the central standoff. Then I freely placed most of the components inside to get an idea on the overall layout.
As the 3 USB sockets are the main feature of the entire device, I placed them first onto the PCB. They slightly extend the edge of the PCB.
The last picture is the connection diagram.
STEP 3: Soldering the USB Connectors
This is a fairly easy step. Just drill slightly bigger holes for the USB connectors' tabs, push them in and solder them in place. Then solder together the GND (pin 4) and the connector case for each connector.
Here I added a 2-pin screw terminal for the power connection. You don't have to do this, but it makes the final assembly a bit easier.
STEP 4: Wiring the Board
This step is not too hard, but you have to pay constant attention to the wiring. Be careful so that you don't swap or short together the 5V and GND rails.
Start by soldering the two resistors. These will tell your device that it is connected to a charger and can pull higher current. Note that the values may be different for various phone/tablet brands, so just google "<your device> DIY charger" and see what works best. I first tried just connecting the USB data pins together without any resistors. That worked, then I tried the 33K and 10K resistors and it worked as well, so I just used them. Also, this produces a 1.2V voltage on the data pins, which is the same as my original Samsung fast charger does. With this configuration my phone only draws 0.6-0.7A (although it can charge at up to 1.7A), but that's enough to keep it charging. (This might be because my battery is old now? I am not sure.)
Next step is to solder the power rails. Connect the screw terminal pins to the first USB connector. Then use some wire to connect all the +5V pins together and all the GND pins together, paying constant attention to polarity and any possible shorts. The wire I used here is 26AWG, which is not ideal - you should use at least 22AWG.
Then solder the data pins of each connector together and connect them to the resistors center point.
After checking (again!) all the voltages, polarities and possible shorts, you can now power it up from a bench supply set at 5V. Measure the voltage at USB data pins, it sould read about 1.2V. If it doesn't, check your wiring again... otherwise you can try charging a phone.
STEP 5: DC-DC Module
We need to prepare the DC-DC step-down converter. Just solder some wire to the output terminals. Use thicker wire (at least 20AWG), I used wire from a computer PSU.
Then hook up the input terminals to a power supply (I used 12V) and connect your multimeter to the output. Adjust the pot with a screwdriver until you get a voltage between 5.0V and 5.1V.
STEP 6: Front Panel: the USB Connectors
Here comes the most tedious part: doing the front panel cutouts. I first drilled a hole into the PCB for a screw, which attaches the board to a small screw standoff inside the project box. Then I slid the front panel to it's place and traced out the connectors onto it with a marker. Using 1mm drill bit I traced out the first connector, then checked if everything still aligns and repeated this for the second and third connector.
To make the actual cutouts I pre-drilled a lot of holes next to each other just on the inside of the traced lines. Then I used the same drill bit at higher rpm to route the pre-drilled holes out. Again, after checking the alignment I repeated this for the rest of the connectors.
Finally I used a square file to smooth out the edges. Notice that the holes turned out to be a bit bigger than intended, because I was drilling too close to the traced lines. Being slow and precise here pays off with nice result. A laser cutter or CNC router would be a life- (and also time-) saver.
STEP 7: Front Panel: the Voltage Display and Power Switch
Next two features are the voltage display and the power switch. Once again, I decided on the layout, traced them out and used the same technique as for the USB connectors.
I added a connector to the LED voltage display, it is a 2-pin male PCB header. The voltage display has 3 leads: power (red), ground (black) and input (white), I just joined the power and input together. The other side of the connector is a female PCB header with wires going to the power input. As with the screw terminal, this is optional but makes the final assembly easier.
Before gluing the display, I slightly beveled the edges of all holes with a small file.
Then I laid down the front panel, put the display in place and secured it with hot glue.
STEP 8: Wiring It Up
I soldered the female connector of the voltage display to the input of the converter module.
Then I made a input power lead from a length of wire (again from computer PSU) and a XT60 connector. I twisted the wires together. I drilled a 4mm hole into the side of the project box and fed the wires through, making a knot on the inside to prevent pulling it out.
I inserted the PCB along with the front panel. The problem was that the board wasn't pushed strongly against the front panel and inserting a USB device would push it back a bit. So I had to improvise and used a piece of stiff wire, which is bent around the center standoff, fed through the PCB and pushes it against the front panel. Works surprisingly well.
The rest was simply wiring up the power switch and input of the DC-DC module, connecting the screw terminal and screwing the box together.
STEP 9: Finished!
Well there you have it! Now you can use almost any power source to charge your device!
Some improvements I can think of would be using a regular DC power jack as the input, so that you can also plug in regular power adapters.
Also, instead of using a step-down-only converter, you could use a buck-boost converter, which can operate on lower voltage than its output voltage.
Oh and if you are too lazy to spend an afternoon making this, just grab a 12V car USB charger and wire up your battery. Problem solved :D
Thanks for reading my Instructable.
Update after initial testing:
The charger performed very well. The 5000mAh battery was enough to keep 5 phones charged throughout the weekend.
62 Comments
Xanderford63 5 years ago
ehcarleton 5 years ago
1) I saw a comment about this not having a LiPo cutoff circuit could cause a fire. I am wondering if the Anker portable chargers have enough protection in them to prevent any issues.
2) I only want to charge one thing and only one thing, the Anker portable charger. How do I modified the setup to only charge one thing?
penguinoo569 6 years ago
3zuli 6 years ago
You can use pretty much any toggle switch. I think my switch is rated for 230V 3A and has 2 prongs, I salvaged it from some old PC power supply. Just search "toggle switch" on ebay and you'll get a lot of options.
gregdavid 8 years ago
One tool you might find extremely useful for the front panel holes is a nibbling tool (normally used for sheet metal). http://www.ebay.com/bhp/nibbling-tool
As great as dremel tools are, even with the best bits, they still don't cut very clean & square holes, esp. freehand. Once you get the hang of using a nibbling tool, you'll be able to cut sharp square holes as if they were precision die punched in a factory. Very cool and only ~$5-$10 for the tool!
3zuli 8 years ago
Thanks for the tip, I'll definitely take a look at this! Cutting nice square holes has always been a pain :)
amclaussen 8 years ago
I have seen terrible injuries produced by those thin and extremely Sharp small circular saw blades that can be mounted in Dremel tools. It is indeed VERY easy to mishandle them, and at high RPM's they can sever a finger or two in a very short fraction of a second, as they cannot be easily guarded. Beware of them, they can be really dangerous. The very small size of their teeth can give a false sense of harmlessness, but at speed, they slice soft flesh in a hurry. In contrast, it is almost imposible to receive harm from the nibbler. Amclaussen.
I have the same nibbler tool, bought about 25 years ago at a Radio-Shack store (when they still carried aceptable quality tools). And it still Works OK. It is easy to hancdle and while slow, it can produce precise cuts. The best tool fot electronic chassis projects, no doubt. Amclaussen.
erny1601. 9 years ago
did anybody built this thing ? Does it really work with the two resistors ? I want to do this, but I cant explain it to myself how it works with the both resistors, so the current won´t got to the data Pins, because the both resistors are directly connected over + and - so can anybody explain it to me, or was i wrong to now what i knew about electricity ?!?!
M. A.G 8 years ago
I have the same or similar questions as erny1601. Why is everything connected together? With the resistors keeping them separate. Why would I want my positive and negative connected yet separated with a resistor? Can resistors blow? It would seem to be prudent to insulate not resist. Also why have power to the data ports if you're just charging?
3zuli 8 years ago
The 33K and 10K resistors form a voltage divider which creates about 1.2V. This voltage is connected to the data lines on all three connectors. When a phone detects this voltage, it knows it's connected to a high power charger (instead of a regular USB port on a PC) and can draw more current.
These resistors only draw about 0.1mA from the 5V line. Don't worry, there's no risk of these resistors shorting out and burning.
M. A.G 8 years ago
Thankyou . Very illuminating. I was completely ignorant of that
paziek 9 years ago
It's a voltage divider and will provide both data pins with 3.75V of useless voltage. Some chargers did provide on those pins some voltage in order to indicate how much current can be drawn by device, but I don't think it is used any more. I have USB cable for charging only and internally it has just 2 lines, so unless they have soldered SMD resistors on both connectors - it doesn't provide any power on those pins. I'm too lazy to check them, just in case...
Arduino Tech 9 years ago
jwarner75 8 years ago
1 Question I have. Well maybe a few.
First 1. Could you use a Double USB Say like what's on a Computer so you have a total of 6 Ports or even 3 Stacked to make 9?
If so (I assume you can), Would the Voltage be different the more that's plugged in, or will it still be the same Consistant Voltage all the time.
I'm always Finding the problem of having way to many USB Items to charge on my PC and or Outlets and it's a Pain, 1 or 2 charging while th eothers aren't, then swap them out. i could use this to Make 6 or 9 ports, giving me the Ability to just Plug in ALL of my Devices that need charges at the same time.
Tablets, Phones, Nintendo DS, PSP, etc.
3zuli 8 years ago
Also there are some mains-powered multi port USB chargers available pretty inexpensively, I think that would be a better option for your purpose. My charger was intended more for being powered by batteries, but of course you can always power it with a 12V mains supply.
3zuli 8 years ago
Yes, technically you can add as many USB ports as you want. The converter I used here is rated for 3A, that's enough for 3 devices at 1A or 1 device at 2A and one at 1A, and so on.
If you want more devices, you'll need a more powerful converter, such as rated for 5A or even 12A. Remember that the higher the load is, the more will it heat up and the output voltage may also drop slightly.
The other option is to use multiple 3A converters, each with 2 or 3 USB sockets and dedicated resistors.
