Up-cycle (popped Air Mattress + Water Bottle = Shop Vac)
Intro: Up-cycle (popped Air Mattress + Water Bottle = Shop Vac)
I built a shop vac from some "trash" my girlfriend wanted me to throw away
this is my first instructable ( even though i try to build something every other day )
hopefully, many more will follow!
STEP 1: Get the "air Module" Out of the Failing Air Mattress
I started with an air mattress that wouldn't stay inflated.
(ipretty sure the cat put 17,897 small punctures in it while we weren't looking)
removed the inflation module by cutting around it with sharp knife or scissors.
(i guess, i should put warnings about safety and stuff here!)
STEP 2: Cut a Whole in the Water Cooler Bottle.
i used a cordless circular saw to cut out a rectangle from the side of the bottle.
for my first attempt, I just "eyeballed" my air module to be about the size of the label on the front of the
5 gallon water-cooler bottle and cut it with out even marking or measuring anything.
--AS ALWAYS, use caution when working with potentially dangerous tools.
... water bottle should be empty.... before you start any of these steps...
... ... you'd be surprised....
STEP 3: Seal
i wedged the air module into the hole i cut into the water bottle
later models will probably use an epoxy or something of that nature to seal the air module to the bottle,
but today i simply used vinyl tape to secure the connections.
used an old shop vac hose to extend the range
STEP 4: Testing
Because the mattress had a deflate option as well as the inflate option ,
i was able to use my new device as a blower AND a shop-vac.
There is also a handy little compartment for cord storage.. or whatever...
The prototype works better than i could have anticipated.
Impressive amount of storage and suction!
Picks up broken glass, water, pine needles, much much more.
i will retool and make a v2 in the near future
15 Comments
drewscreen 3 years ago
tabsross74 3 years ago
Just4Fun Media 8 years ago
Have a great day! :-)
Tretech 8 years ago
emptying, as it turns out is super easy. i flipped it over and switched to blow instead of suck, and it blew everything out quickly.
i put a old cloth bag over the mouth and collected all the debris with no airborne dust hitting my delicate sinuses
I have another pump and am toying with filter add in the build.
mypublicpersonas 6 years ago
MissyTaylor71 4 years ago
Deathstick 7 years ago
I dig it. You have got what has mostly disappeared from today's Ible's, originality. I find myself Googling Ible's these days more than not, just to see how many hundreds of recycled ideas prefaced them. There really isn't a need for the 459th rendition of "How to tie your shoes.", and the "That's a great idea!" comments to follow. Keep it real, keep it original.
My only suggestion on your Ible itself would be to make things as simple as possible whenever the chance presents itself. Not everyone who may want to do this will have a saw. Use what you have by all means building projects, but offer up ideas on alternative methods of getting to the same end. Open doors.
kylegilbert 8 years ago
scott.lile.5 8 years ago
That's way cool !!!
ranwithjesus 8 years ago
that's super cool!
JmsDwh 8 years ago
Very cool!
theblckwlf 8 years ago
DIY Hacks and How Tos 8 years ago
Great idea for reusing the pump.
