Wall Mounted Sewing Station
Intro: Wall Mounted Sewing Station
We are constantly creating awesome sewing projects in the office and our sewing station is constantly in a state of chaos! Instead of using bins and plastic bags to organize our sewing materials I made this wall mounted sewing station to organize all of our sewing materials.
STEP 1: Materials
Wood Board - 36" x 12", get a board that fits your wall
Fabric - to cover the board to make it pretty and to make bags
Nails - large and small nails, large nails are for thread spools and small are for bobbins, make sure the head of the nails are small so the spools can fit on them
Screws - to fasten board to wall
Eye Bolt Screws - Scissors
Hot Glue Gun
Pin Cushions (2) - I made my own, but you could buy them
Elastic
Hot Glue Gun
Elastic
STEP 2: Mounting Board
Marking and Drilling Board
- Draw a line on your board where the screws will be attached, mine were 4" from one of the edges
- Mark 5 spots along that line where the screws will be drilled in, I had one in the center, 2 that were 3" from each edge, and 2 that were in-between the center marking and the 3" markings
- Make pilot holes in the board where you marked. Drill all the way through the board.
- Cut out a piece of fabric that is 6" wider and longer than the board
- Finish the edges by folding and sewing the edges of the fabric 1/2" over.
- Hot glue the fabric to the board
- Poke holes through the fabric where the pilot holes are.
- Place the board where you want it to be on the wall. I held it in place with clamps, if you don't have clamps have a friend hold the board.
- Make pilot holes in the wall by drilling through the five pilot holes in the board.
- Attach screws.
STEP 3: Attaching Sewing Tools and Materials
Here is a break down of how the sewing tools and materials will be attached to the board.
Nails:
Nails:
- Thread spools
- Bobbins
- Needles
- Scissors
- Chalk
- Seam Ripper
- Tools
- Pin Cushions
Bags
- Measuring Tape
- Safety Pins
- Tools
STEP 4: Nails and Eye Bolt Screws
Nails : hammer nails into board at a 45 degree angle to attach thread spools and bobbins, hammer at a 90 degree angle for needle package.
Eye Bolt Screws: screw into board and make sure the eye of the screw is parallel to the floor. Place scissors in eye.
STEP 5: Elastic
Use hot glue gun to attach elastic. Glue each end of the elastic and lay it flat on the board so you can pull the elastic out and objects will stay put.
STEP 6: Velcro - Pin Cushions and Bags
Use velcro to attach pin cushions and fabric bags. See next step for instructions on how to make the fabric bags.
I used this instructable to make my pin cushions: https://www.instructables.com/id/SewUseful,-easy-and-practical-a-pin-cushion-made-u/
STEP 7: Making Bags
- Cut out a rectangle of fabric. The length of the rectangle should be 2x the length of the bag and the width should be the same as the width of the bag
- Fold over the shorter ends of the fabric a 1/2" and glue them down with hot glue gun
- Fold fabric in half and sew along edges, do not sew over the edges you just glued
- Fold one of the glued edges over again and glue down
- Turn bag inside out and attach velcro on the back.
20 Comments
JudyW23 5 years ago
jooknon 13 years ago
I took the advice of sharley and used spray glue to hold the fabric to the wood, now it wont pull away when removing velcro'd items
Carleyy 13 years ago
Once again, thanks for the great idea!
IvliaB 6 years ago
Make your pincushion then before sewing up the base insert a small magnet (from any good craft shop) and glue it to the fabric at the base, sew up and finish as normal. When you need to pull up pins just wave the base of the pin cushion over your work space and it will pick up all the pins then transfer to other side of cushion. Another way is the one used by my sewing mistress at secondary school, on a hook by the door she hung a simple horseshoe magnet and when we were finished our class before we left the room someone would take the magnet down and wave it over all the tables and the floor, voila, all pins suddenly accounted for. You could hang one on the end of the board or place it in a small bag as an alternative to the magnetic pin cushion. Either work just fine.
Lady Hazel 7 years ago
I love this idea. My sewing area is always so cluttered with pincushions, jars of scissors and tools, and all my thread organizers. Hanging it on the wall is such a great idea. And I can add some cute fabric and trim;)
SherylinRM 7 years ago
Years ago a friend of mine bought a fancy one.
They said home made ones didn't look very good.
I am going to show them this instructable to prove them wrong.
Good work.
Thanks for this :)
starrschaos 10 years ago
This is a really great idea! I've done this with peg board before and it was really useful, but this is a great cheap alternative that looks really nice. Thanks for posting
piggleliggle 12 years ago
Great work :D
makalove 12 years ago
twogirls 13 years ago
sharley 13 years ago
Great idea. I have to do one for my craft center!
pie popper 13 years ago
Kryptonite 13 years ago
dorinmouss 13 years ago
tbcross 13 years ago
tinkertoymania 13 years ago
ChrysN 13 years ago
angelabchua 13 years ago
