Washed Ashore Sea Glass Floating Necklace
Intro: Washed Ashore Sea Glass Floating Necklace
FULL TUTORIAL and many more: Shrimp Salad Circus
This little gem was created as part of the Tutorial Exchange Program that I've told you guys about before on Totally Tutorials. The lovely Corrie of 808Sunshine {How fun is that shop name?} was kind enough to send me a set of gorgeous little drilled sea glass pieces to use for this project. Corrie was an absolute sweetheart and even offered to send me a new set when I thought I lost my first set {long story that involved Mish and Rosco - or didn't really...}. She finds all her sea glass while scouring the beaches or diving the waters in Oahu, so if you're looking for legit sea glass, you've found your source!
For all my nail polish fans, get excited - the fiery coral tips are back! I must apologize for the terrible photos because we were having a horribly rainy, overcast week, and it's also sort of difficult to capture the beauty of something that is almost totally translucent. This project is super easy but yields a stunning result, so get to supply shopping!
STEP 1: Materials
Materials:
- Round Nosed Pliers
- Flush Cutter Pliers
- Chain
- Eye Pin, Head Pin, or Piece of Stiff Wire
- Sea Glass Pieces with Holes {available at 808Sunshine}
STEP 2: Create and Eye Pin
Step 1. I used a head pin because it was all I had on hand, so I had to snip off the end with my flush cutters. If you're using an eye pin, you can skip this step. For a head pin or wire piece, wrap the end around the round-nosed pliers until you have a little loop.
STEP 3: Add Sea Glass
Begin sliding your pieces of sea glass onto the pin. Continue adding sea glass until you have attained the desired length. You might want to arrange them first on your work surface to decide what order to put them in, since they will not be symmetrical.
STEP 4: Close Eye Pin
Use the round-nosed pliers to make another loop to close off the end of the pin and secure the glass in place. Your finished sea glass focal piece should look something like this.
STEP 5: Add Jump Rings
Attach a jump ring onto the loop.
STEP 6: Attach Chain With Jump Ring
Thread your wire through the jump ring, and close the ring. Repeat with the other side. Your necklace should look something like this.
STEP 7: Add Clasp
If you like the length of your necklace, cut the chain at the middle, and attach a clasp component to each end. If you would like, adjust the length of the chain before adding the clasp.
STEP 8: Voila!
You're done!
12 Comments
TammyC138 5 years ago
sunshiine 11 years ago
Sunshiine
ShrimpSaladCircus 11 years ago
RaNDoMLeiGH 12 years ago
The little pieces that are too small to drill can either be kept in the tumbler for another round (they'll eventually break down to sand), or you can put them in a dish and use it for incense burning or drip potpourri oil on it. Clean occasionally by putting in a closed container (like tupperware) with a squirt of dish soap and hot water. Use a strainer or a dish towel to keep the bits from escaping down the sink when rinsing.
I also use the pebbles for photography:
http://www.artfire.com/modules.php?name=Shop&op=listing&product_id=3195069
And of course you can always put them in a fish tank.
wocket 13 years ago
SOisme 14 years ago
mazinggrace 14 years ago
Once you have your drill bit I recommend drilling under water. It will keep your bit and glass at a cooler temperature to avoid breaking. I use a metal bowl and I place my glass on a small block of wood to keep it steady. I then fill the bowl with enough water to cover the glass completely while I am drilling.
Then just drill, nice and slow. With the diamond bit you do not have to use alot of pressure. With the other glass bit you will need to use more pressure but be careful the glass will break and water will go everywhere when you do this.
Here is also a video of sea glass drilling but with a dremel tool. You can use either a dremel or a drill. http://www.youtube.com/watch?v=0RaHRyuBIwI
wocket 13 years ago
JClouseau 14 years ago
ycc2106 14 years ago
So the hole point I cam to see this page... was to try and find out how to make the holes.
Sunbanks 14 years ago
And I love your nail polish :D
