Water Proof Charging Port
Intro: Water Proof Charging Port
OK!!!! So you built this awsome electronic instructible that operates in harsh conditions or is submersible. It requires you to recharge the unit once batteries are discharged. It is a pain to take the unit apart to get to the batteries to recharge them. What is the simplest, most inexpensive way to achieve this??? Sure you can purchase a marine grade type enclosure..... but at what cost...... I have come up with an awsome solution.... Please follow me to get the answer..........
Tools: Cutting device to cut plastic, High Temp Hot Glue gun, Canned Air (optional)
Parts: Charging port (user determined), Coke bottle, gatorade bottle, water bottle, etc.... (what ever works for your needs)
STEP 1: Coke Bottle / Water Bottle / Gatorade Bottle
I'm sure you have a bottle of some type in your fridge, or you're sipping on something right now. I used a coke bottle for mine. I built a small pool craft using a bildge pump, battery, switch, and charging port. I had to figure out a way to waterproof the charging port.
1st. Take a Coke bottle and cut the top off.
STEP 2: Coke Bottle Top
2nd You cut the top of the coke bottle off.
STEP 3: Insert Charging Port
3rd Install charging port, attach wires according to your needs, and set with hot glue. (I did not go into detail about making my electrical connections. This instructible is not geared for that information.)
NEAT TRICK: If you turn your canned air upside down and spray, you get a blast of frozen air (please don't get technical on this wording). If you spray your hot glue once you applied it with this method, it helps to set your hot glue quicker. I didn't spary much. Just a quick blast to hold it in place to keep it from dripping or running. Plus I am impatient and didn't want to wait for the glue to cool on its own.
STEP 4: Seal Connections
4th I used Hot glue to set and seal the connections and once it cooled, I hotglued the setup to my device.
STEP 5: Charge Your Device
5th You can now charge your device.
STEP 6: Your Done
6th Now its time to put it to work. Put cap on and you now have a sealed charging port that has easy access!!! ENJOY
8 Comments
pcooper2 11 years ago
palombo5050 11 years ago
nh4x4Jeep 12 years ago
T-Hawke 12 years ago
Well done.
Thanks for sharing
palombo5050 12 years ago
iPodGuy 12 years ago
sunshiine 12 years ago
