Welding Plastics: Drill Bit Case
Intro: Welding Plastics: Drill Bit Case
I decided to write a small series of Instructables to show that there are a lot of things you can make out of plastic bottles and how easy the plastic welding process is.
Recently I ordered some hex drill bits for my electric screwdriver and they are awesome, however they arrived without a case and it was hard work trying to find the one I needed at the time. So I decided to make myself a case. For a while I've been pondering over the material I want to use for this project, and then it hit me as I was putting a milk bottle into the recycle bin. Why not use the milk bottle I thought to myself? Seems to be pretty sturdy and it's free (always a good thing).
The project is pretty easy and takes about 2 hours to finish. I would recommend creating a template before hand and maybe making a paper prototype first. I've included the template I made in step 2, just in case someone finds it useful.
There seems to be something quite enjoyable in the plastics welding process, since after the drill bit case I decide to make another three projects (flowers, cat toy and of course Instructables robot) which hopefully I will manage to write the Instructables for soon :D
Tools & Materials:
- large Milk bottle + the cap
- soldering iron
- scissors
- sharpie
- hobby knife
- ruler
- marker
- glue stick
STEP 1: Preparing the Milk Bottle
Start by cutting the bottle in half and then cut off the curvy bits so that it's easier to draw on later. Clean the bottle halves if necessary.
STEP 2: Cutting
Print out your template. Attach the bottle half to the template with a clear tape and score with a hobby knife all of the lines that will be folded later on. Trace all of the outlines with a marker and cut out. Fold as required. I was not able to fit the whole design onto the bottles half, so I cut the main bit from one half and the top bit from the other half with an overlap in the middle.
Cut one 2cm and a few 1cm strips, the longer they are the better.
STEP 3: Spot Welding
Set the soldering iron to temperature between 200-230°C. I only tried this on HDPE plastics, so depending on the plastics you are using you might need to adjust the temperature.
Align the 2cm strip with the base of the case and hold in with a piece of a clear tape. Because the melting point of HDPE plastics is around 130°C you only need to hold the iron in the place for a split second. Press the iron into the top edge of the strip, then on the bottom edge followed by another 4-5 welds in between. This should create a relatively strong bond.
At this point you will need all of the items you would like your case to hold handy, or in my case only one of the drill bits since they all have an identical base. Lift up the strip and place in the drill bit. Push down the right side and press firmly. With the drill bit still inside, hold the right side of the strip and press the iron into the top and bottom edge of the strip just like before and then fill the middle. Carry on until you've created all of the slots.
STEP 4: Making the Frame Sturdier
Using the template cut out 4 strips for the top of the case. Place them onto the top part of the case and spot weld all around the perimeter. This will help improve the stability of the case.
Bend in the bottom of the main part of the case and weld the edges. Fold in again and gently smooth over the edges with the iron.
STEP 5: Joining
Overlap the main piece with the top and spot weld the joint.
Align one of the 1cm pieces with the side of the case and spot weld around the perimeter. Repeat until all of the sides of the case have two layers of plastic.
Cut out another 4 strips and repeat the process from the previous step onto the back of the case.
STEP 6: Latch
Take 2 strips and spot weld them together. Place the strips over the left corner of the case, pinch over the sides and weld together. Cut off reminders.
STEP 7: Personalize
Cut out 1.5cm strip, trace the writing onto it backwards and spot weld onto the case.
Take the bottle cap and cut off the side. Cut around the recycling logo and glue it onto the cap with a glue stick. Cut out the logo with a hobby knife. Place the logo cutouts onto the case and spot weld. For this part I used a pointy tip in the soldering iron.
Once you finish welding the tip of your iron will end up with a black coating which you could just scrape off with a knife.
Write out the sizes onto the drill bit slots with sharpie and that's it ;)
62 Comments
John Harwood 5 years ago
Have you tried cutting up a few drill boxes and welding them together to make a milk botttle?
nerdyKat 5 years ago
Sounds great! That could be my next Instructable ;)
spark master 5 years ago
with all the stuff I have made for my kids out of paper waste, I wish I had thought of this way back when!! Many people Kvetched over recycling, to me it was a world of possibilities for Arts&Crafts. It added whole new meaning to "lunch box" or "boxed lunch" . Or when you just need a neat way to contain a thing that needs to go in the car/backpack etc. A PBJ on a lunch bag did not fair well, but Dad's home made sandwhich boxes were great. Really nice on trips as you could eat and toss.
I got bored with my Vacu-Form as a kid and made stuff out of the styrene sheets and junked toys.
This adds a whole new Dimentia to the process.
And remeber if asked by authorities always good to stick with "Honest, it was on Fire when I picked it up!"
Johnalvan 6 years ago
nerdyKat 6 years ago
I used a cheap adjustable soldering iron and I set the temperature between 200-230°C / 390-450°F
Alex in NZ 6 years ago
Great use of a neglected material. I'm going to have to think of something to do using your technique. Thank you for sharing this :-)
Thank you very much for your lovely comment, I would love to see what you come up with ;)
shazni 6 years ago
really cool!
Thank you very much ;)
MadeByGloria 6 years ago
Fantastic! Love this project, but I don't know if I have that much patience that is required!
Thank you very much, it wasn't that difficult you might be surprised ;)
saadland 6 years ago
keep it up, great ible!
I truly hope so, thank you for your lovely comment ;)
agis68 6 years ago
epic awsomeness....
Thank you ;)
rkrishnan7 6 years ago
Great 'ible! Thank you for doing your bit to prevent that island of plastic floating around in the pacific from getting much bigger than Texas! HDPE is slick and hard to glue, and stay glued - welding it with a soldering iron is a brilliant idea!
Thank you very much for your lovely comment ;)
Lord yLordy 6 years ago
Nice ingenious build.
I have used HDPE for projects before when I wanted a small block of plastic but couldn't buy a small quantity. Simply by cutting a few milk bottles up to fit in a baking tray and cooking it until it melts (somewhere around 180-200C) when it cools it can be cut and drilled and is remarkably strong.
amclaussen 6 years ago
I will be trying that myself soon. I need to make a set of small sliding "bearing" pads, that will take out the freeplay that a jigsaw cutting guide has. Even when Bosch has a nice aluminum guide rail for its large jigsaws, its sliding base where the jigsaw is attached has a too wide slot, so that the baseplate has too much freeplay. By inserting four small HDPE pads so take out the freeplay, the guide rail would be much more precise. I thought about using UHMWPE, as it has a better (lower) friction coefficient, but I found it too difficult to buy in small quantities. Using HDPE appears to be a good idea, but I have not yet figured out how to fix or attach it to the baseplate easily. Any idea? Best Regards.
Amclaussen.
Have you thought about Polymorph, it is an easy material to work with but it's melting point is low so working with it can be a bit difficult as it melts when you try to drill it. It does though, make it easy to install fixings as you simply melt the spot and insert it. Also, you can handle it hot as it melts at 60C but I would wear some sort of glove though.
The one difficulty I have found with HDPE is once it has been baked it is hard to get it to melt again. I suppose you could use both, the HDPE for the slide and the polymorph to fix it to the base.
