Smartphone As WiFi Headphone (for Kodi)
Intro: Smartphone As WiFi Headphone (for Kodi)
I have XBIAN (kodi on Debian) running on my rPi2 (Raspberry Pi 2) attached to a 27" monitor with inbuilt speakers. I chose this distribution as I wanted to tweak Debian settings a bit in order to use bluetooth (BT) controller and headphones (in the future). I had my BT controller working and things were running smooth.
Soon, I needed a way to wirelessly stream audio (living with a baby in an apartment) and I struggled a lot with BT headset. It paired fine but would disconnect immediately. I decided not to waste any more time on BT headset and instead started looking into uPnP. Some reading revealed that uPnP won't let me stream audio from whatever I have running on my kodi at any time. So, I needed a point-to-point solution over wifi for audio as BT did not work for me.
The idea is to have something setup on XBIAN (rPi2) and connect to it from smartphone (Android/iOS) which will act as Wifi headphones. This is a software based solution with very little scripting. We are going to install Linphone on both XBIAN machine (rPi2) and the smartphone (Android) and stream audio directly between them.
Pros: 1-WiFi has better range than BT. 2-$0 solution. 3-No custom software. 4-No additional hardware required. 5-Audio remains in you local network. 6-Uses generic mobile App which can also be used to make VOIP calls.
Cons: 1-Consumes slightly more battery than BT. 2-DIY.
IMP: The kodi machine and the smart phone should both be on the same network(LAN). While the phone will use WiFi, the kodi can use either WiFi or ethernet cable.
STEP 1: Install Linphone (at Kodi)
Exit kodi to go to the console/command prompt and run these commands:
To become root so you don't need sudo for almost every command.
xbian@xbian ~ $ sudo su
Prompt should change from $ to #. Now, Install non GUI version of linphone
root@xbian:~# apt-get install linphone-nogtk
Run linphonec to see if it works
root@xbian:~# linphonec
Ready
Warning: video is disabled in linphonec, use -V or -C or -D to enable.
linphonec>
linphonec> quit
Terminating...
root@xbian:~#
We can ignore the warning about video.
STEP 2: Autostart Linphone As a Daemon (at Kodi)
We want linphone to start automatically when system boots up. We also want it to be in auto answer mode and start sending whatever it hears on the loopback/fake snoop device added in step below.
root@xbian:/home/xbian# vim /etc/init.d/linphone
#! /bin/sh
# /etc/init.d/linphone
### BEGIN INIT INFO
# Provides: linphone
# Required-Start: $local_fs $syslog $remote_fs dbus snd-aloop
# Required-Stop: $local_fs $syslog $remote_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start linphonec daemons
### END INIT INFO
# The following part always gets executed.
echo "Linphone"
# The following part carries out specific functions depending on arguments.
case "$1" in
start)
echo "Starting linphonec daemon"
linphonecsh init -a
echo "linphonec daemon is alive"
stop)
echo "Stopping linphonec daemon"
linphonecsh exit
echo "linphonec daemon is dead"
echo "Usage: /etc/init.d/foobar {start|stop}"
exit 1
esac
exit 0
Save file and exit vim.
Now, we start linphone manually to check if above script works. We'll soon make it start automatically on reboot.
root@xbian:~# /etc/init.d/linphone start
Linphoned Starting linphonec daemon
Now, check whether linphone daemon is waiting for connections:
root@xbian:~# netstat -ntulp | grep linphone
udp 0 0 0.0.0.0:5060 0.0.0.0:* 22101/linphonec
Lets make this script run at startup & reboot, so we'll have the daemon always running:
root@xbian:~# update-rc.d linphone defaults
Lets reboot and check linphone daemon is waiting for connections again using:
STEP 3: Setup Capture Device to Snoop Audio (at Kodi)
Confirm that rPi does not have any capture device (source of sound e.g. a mic). This helps in identifying when a capture device is added below.
root@xbian:~# arecord -l
**** List of CAPTURE Hardware Devices ****
So, there are no capture device by default.
Now add fake capture devices:
root@xbian:~# modprobe snd-aloop
Verify that it succeeded:
card 0: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
... #2 to #6
Subdevice #7: subdevice #7
card 0: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 8/8
... #2 to #6
Finally, lets make this change permanent:
root@xbian:~# vi /etc/modules
This will open the modules file. Go to end of this file and under the exisiting line that says snd_bcm2835 add snd-aloop on a new line. This will automatically add the capture device on a reboot.
Lets reboot now:
root@xbian:~# shutdown -r now
After it reboots into kodi, exit codi again and run this command to verify it survived reboot:
arecord -l
STEP 4: Audio Plumbing (ALSA at Kodi)
We need to do some plumbing to make kodi/xbmc sound output flow to the loopback capture device. It will then be picked up by linphone to be sent over WiFi. Since XBIAN uses ALSA (no PulseAudio) we'll use that.
First, we create the config file for this:
root@xbian:/home/xbian# vim /etc/asound.conf
# default device
pcm.!default {
type plug
slave.pcm "loop"
# output device
pcm.loopout {
type dmix
ipc_key 328211
slave.pcm "hw:Loopback,0,0"
# input device
pcm.loopin {
type dsnoop
ipc_key 686592
slave.pcm "hw:Loopback,1,0"
# duplex plug
device pcm.loop {
type plug
slave {
pcm {
type asym
playback.pcm "loopout"
capture.pcm "loopin"
Save text & quit the editor.
Now we need to reboot:
root@xbian:/home/xbian# reboot
When it comes back and we exit to the console, we first verify that the plmbing is in place:
root@xbian:/home/xbian# aplay -L | grep loop
loopout
loopin
loop
STEP 5: Change Audio Output (at Kodi)
We need to tell kodi to start sending audio to the loop device instead of HDMI/Analog as we created during plumbing.
Go to kodi home or main screen.
Goto SYSTEM -> settings
Goto System
Goto Audio output
Click on Audio output device -> select ALSA: Loopback (loopout), Loopback PCM
Exit back to home and then try to play a stream, there should be no sound from HDMI/Analog.
STEP 6: Install Linphone App (on Smartphone)
We are going to install free Linphone App on Android and call our linphone daemon on xbian to listen to live audio of the stream playing on kodi.
Install Linphone app from Google Playstore. (I think there is an iOS version available to Apple users).
We are going to place a direct call between the app and the daemon running on rPi/xbian or the kodi machine. Lets assume it has IP address 192.168.1.3
Launch the app. Don't create an account if it asks to. we don't need to login to any VOIP server. The app should show Not registered on left top corner.
Now, tap on Number or address field of the app and type sip:192.168.1.3 and press call button on the app.
The app should now get connected and you should hear the audio of the kodi stream. It might be low, so you would have to bring the phone near your ear to hear it. You could tap on the speaker icon on the app to activate speaker phone and it should be louder. You could also connect earbuds for private listening.
STEP 7: Tips
Voice out of sync with video?
This setup like any other network based streaming might introduce some delay making audio & video a bit out of sync. Fortunately, kodi has an Audio offset setting that if set to ~ 0.200s will make video & audio in sync again.
Echo?
Keeping the mic on the App muted will avoid hearing yourself or other noises.
No Audio?
If you forward/reverse your video at kodi many times, the sound might stop even if the app is in call with kodi. If it happens, try play/pause video a couple of times and you should have the sound back.
12 Comments
atleta 7 years ago
It doesn't state which version(s) of the software are used. At least the debian version should be mentioned. On debian jessie the above asound.conf doesn't work. You have to remove the 'device' string from the beginning of line 19.
But even after doing that it turned out not to be working :-/. Nothing is heard over the sip call. This may or may not be related to the above asound.conf issue.
atleta 7 years ago
The problem seems to be with linphone accessing the sound card. When running it from the terminal and making a call to it, I start seeing these error messages:
ortp-error-snd_pcm_avail_update: Broken pipe
ortp-error-*** alsa_can_read fixup, trying to recover
ALSA lib pcm.c:7843:(snd_pcm_recover) overrun occurred
ortp-message-Recovery done
ortp-message-bandwidth usage: audio=[d=28.0,u=19.5] video=[d=0.0,u=0.0] kbit/sec
ortp-message-Thread processing load: audio=310.412964video=0.000000
ortp-message-Adjusting output timestamp by -2880
ortp-warning-Audio MSTicker: We are late of 5912 miliseconds.
ortp-warning-Audio MSTicker: We are late of 5946 miliseconds.
ortp-warning-Audio MSTicker: We are late of 6028 miliseconds.
ortp-warning-Audio MSTicker: We are late of 6169 miliseconds.
ortp-message-Local interface to reach 87.98.157.38 is 192.168.0.17.
ortp-message-bandwidth usage: audio=[d=10.7,u=7.5] video=[d=0.0,u=0.0] kbit/sec
ortp-message-Thread processing load: audio=576.780823video=0.000000
ortp-warning-Not enough ref samples, using zeroes
ortp-warning-Audio MSTicker: We are late of 6467 miliseconds.
I tried manually setting the card used by linphone to the ALSA loopback device (by default it uses the default device) but it doesn't help. No idea what the problem might be. The loopback device does work otherwise: setting the playback to it does produce sound on my TV.
DeepeshJ4 7 years ago
Did you get it to work ?
fjones7 8 years ago
i'm starting over from scratch now (fresh install of Kodibuntu), and after step one installing linphone, i get this error when i run linphone:
ALSA lib conf.c:4694:(snd_config_expand) Unknown parameters 0
ALSA lib control.c:953:(snd_ctl_open_noupdate) Invalid CTL default:0
i'm going to forge ahead anyway, hoping this is ok.
fjones7 8 years ago
happily, this error was not a deal breaker : ) i went ahead and it works anyway.
fjones7 8 years ago
actually, here's the full message:
root@kodi-livingroom:/home/kodi# linphonec
Ready
linphonec>
fjones7 8 years ago
on step two, i get "permission denied" when trying to run "/etc/init.d/linphone"
to fix this, i ran "sudo chmod +x /etc/init.d/linphoneroot"
fjones7 8 years ago
❤️❤️❤️ this. thank you so much, you've accomplished what so many have been trying to for so long. i can't wait to get it working.
i'm doing this on kodibuntu, and got as far as step 4, but when i reboot after saving the asound.conf file, kodi won't load anymore, and just defaults to the ubuntu desktop environment. upon removing the contents of the asound.conf file, kodi loads fine again. any ideas?
i should note that when i do "aplay -L | grep loop", this is what i get...
root@kodi-livingroom:/home/kodi# aplay -L | grep loop
ALSA lib conf.c:1686:(snd_config_load1) _toplevel_:19:17:Unexpected char
ALSA lib conf.c:3406:(config_file_open) /etc/asound.conf may be old or corrupted: consider to remove or fix it
ALSA lib conf.c:3328:(snd_config_hooks_call) function snd_config_hook_load returned error: Invalid argument
ALSA lib conf.c:3777:(snd_config_update_r) hooks failed, removing configuration
- fox
perwaysu 8 years ago
Glad that you find it useful.
The config errors you are getting, indicate possible format issues in asound.conf file.
I remember getting "may be old or corrupt" error when I had forgotten to match all the braces (one was missing). Please review the file content carefully and use tabs to indent.
Hope this helps. Look forward to hear how it goes.
fjones7 8 years ago
is there a typo in your code for step 4? i believe on line 19, as the error message suggests. I think you accidentally started the line with "device" when that was meant to stay in the comment line above. is that right? when i remove this so it starts with "pcm" like the rest, i get no more error message, and kodi starts up again.
"aplay -L | grep loop" does not say anything tough. i was expecting:
loopout
loopin
loop
also, i saw the ALSA device in Kodi before, but I can't see it anymore. Ive repeated all the steps twice now, and still not seeing it in Kodi. how can i get it back? i feel like i'm so close to making this work.
wold630 8 years ago
Do you have more photos of your steps?
Thank you for reading. I'll add more photos soon. However, most steps are done on console/ssh.
