Wood Pendant Necklace
Intro: Wood Pendant Necklace
Turn scrap pieces of wood into jewelry. In this instructable I made pendant necklaces by sanding small pieces of wood and stained them with a non toxic stain. Use different types of wood (cherry, maple, ash etc) for different colours and picking wood pieces with an interesting grain pattern makes for unique jewelry.
STEP 1: Material:
- Wood
- Pendant bails
- Mineral Oil (baby oil)
- Strong coffee
- Wood cutting tools (saw, Dremel etc.)
- Sandpaper (varying grits)
- Pliers
- Paint brush
- Rag
STEP 2: Shape Wood
- Cut the wood to the shape and size that you like with a saw or Dremel tool (one of the pendants I made was about 32mm X 25mm in size with a thickness of 5mm.)
- Round the edges of the wood, I used 60 grit sandpaper for this.
STEP 3: Sand Until Smooth
Sand the wood with increasing grit sandpaper until it is nice and smooth, I used 80,100,150,180, 220, then 320 grit. Always sand with the grain, and don't skip more then one grit size.
STEP 4: Drill Hole for Bail
- With a pencil mark the centre of the pendant where the hole for the bail should go.
- Drill hole with a small bit (1/16th).
STEP 5: Stain
Since I will be wearing the wood necklace near my skin, I didn't want to use a polyurethane stain. So I choose a natural, non toxic way of staining the wood, coffee.
- Brew some coffee stronger than you would drink, I made it about 4X stronger. Filter and let cool before you use.
- Apply the coffee stain with a small brush, this may take several coats ( I did 5 coats), dry between coats.
- Since it is a water based stain, it will make the wood a bit rough (it raises the grain) so lightly sand to make it smooth again.
STEP 6: Oil
I used mineral oil as a non-toxic finish. It also deepens the colour of the wood. Pour a small amount of mineral oil on a rag, rub it into the wood and wipe off the excess.
STEP 7: Add Bail and Chain
Put the bail on and squeeze shut with pliers and add a pretty chain.
80 Comments
Ray from RI 6 years ago
Very cool and you could do some chip carving on the pendent and or simple wood burn design as well.... Do not for get to wax the wood for a nice final polish Minwax or Johnson Past Wax would do the job too....
BOKANG23 8 years ago
This is awesome and I want to make it for my friend, can I engrave on the wood? I want to write something on it
ChrysN 8 years ago
Sure, engraving the wood would totally work.
thedestroyer 14 years ago
SIRJAMES09 12 years ago
__________________________________________________________________
this is a neat idea!! the black stain from walnuts....
Blue stain/paint from duck droppings(their poop)
Various other colors from different flowers, reeds, grass, etc...
I have never tried the walnuts, but I have made paint from roses, & from the ducks...
controlledwrinkles 8 years ago
Instead of walnut dye, use oak gall, the ink from oak galls is what the US Constitution was written in, also there is a pretty comprehensive list here: http://pioneerthinking.com/crafts/natural-dyes
ChrysN 12 years ago
Weather_blue 13 years ago
I figure if the dye's safe enough to put in clothes...
ChrysN 13 years ago
ChrysN 14 years ago
Atmfox 8 years ago
If you were to use a laser cutter to engrave the wood with a design of my choosing, would it look better if put the finish on after or before? I have been getting mixed messages from a variety of questions about this.
Atmfox, it all depends on what effect you want, if you color the wood before engraving, whether with a dye or paint and then laser etched area will be a different color than the dyed parts, if you treat the wood after you laser etch it, then the design might be less visible, it also depends on whether your etched design is really detailed or bold.
ChrysN 8 years ago
Although I haven't tried it myself, I think it would be better to add the finish on afterwards.
mdog93 14 years ago
if so, it might avoid splintering and raising the grain etc. It might also last longer.
just a thought.
bucklipe 14 years ago
chubby8 9 years ago
ChrysN 14 years ago
mdog93 14 years ago
Then i tried adding veg. fat or lard to make a wood wax and that didn't separate but the wood didn't take on much colour froim it unfortunately.
I think with a bit of tweaking it could work though.
tinadalton 14 years ago
