Wood Carving With a Dremel
Intro: Wood Carving With a Dremel
This Instructable was written as part of the Dremel Build at ADX Portland. I want to thank Dremel and Instrucatbles for sponsoring the event. I've used a Dremel before but this was a great chance to check out the latest models. I've never used the Multi-Max before and I was very impressed with its cutting abilities.
Here are the tools you will need for this Instructables:
- Dremel Multi-Max and cutting tools and sanding tools.
- Rotary Dremel and carving and sanding tools
- Clamps to secure the wood while cutting
- A block of wood
- Pencil
STEP 1: Rough Cuts
Start by figuring out the largest cuts you can make on your block of wood to create the rough shape of what you are going to carve. I decided to carve a skull (I love Halloween). So I started by rounding the edges of my block and removing the wood behind the jaw and bellow the back of the skull.
After I had sketched the areas I wanted to remove on the wood, I clamped it to a table and got the Dremel Multi-Max and a cutting blade.
Cut along your pencil lines to remove the wood. Don't worry if you don't follow the lines perfectly, this is a rough cut. The cutting blade can cut pretty deep, but you can also just remove small chunks until you have cleared the area.
Continue to sketch and remove areas until you have the rough shape of your object.
STEP 2: Edging
A little trick I discovered with the Dremel Multi-Max was that once I had my rough cuts done, I could take the Dremel and cutting blade and go along the edges of my rough cuts to remove sharp edges and round out corners.
STEP 3: Rough Detailing
Once you've got the basic shape of your carving done its time to switch to the rotary Dremel. Using the carving tools you can go in and start adding details.
For my skull, I started to carve out the eye sockets and noise along with details on the sides of the skull.
STEP 4: Sanding
The Dremel Multi-Max has a sanding attachment that is great for sanding larger areas of your carving.
Start with a course grit sand paper (60 or 80) and remove any rough areas and smooth out any jagged cuts. Once all the rough areas are removed, switch to a medium grit (120) and finally to a fine grit (220).
STEP 5: Keep Going Till Its Done
Switch back and forth between the Dremel Multi-Max and the rotary Dremel depending on what you need to do. Start big and work your way down to the finer detail.
Hope this was helpful and shows you to to use a Dremel to carve wood.
17 Comments
tagyerit 8 years ago
I would like to say from experience, that you should take more safety precautions. First rule I learned in woodcarving is to never use your body as a work bench. Having said that, I have broken that rule from time to time, but with extra care. First practice mindfulness. That is, you think, okay I'm going to hold it so I'd better know where the blade will go when (not if) I slip. And second wear carver's gloves. They make them with kevlar or a similar material. But don't trust them completely, they are better than nothing, but not if you are not paying attention.
So back to the first rule. If you are starting with a bigger piece, then leave a part that you can keep in the clamp and cut that stem off after you have done as much as you can to the rest of the piece. If the piece is already close to the finish size then attach a dowel or bolt or something that will help your bench hold the bench steady.
I'm looking forward to your next instructable, but I want you to finish it with all ten fingers intact.
thegrendel 8 years ago
Good points, but don't forget goggles or safety glasses. Flying debris or broken Dremel blades can blind you.
geordie_h 8 years ago
The shop I'm in requires safety googles so I forgot to mention them. But you are correct. Always where safety googles.
Good points. I've made a few more of these and now I use a wood working vise to hold the block while I make the large cuts. I do still hold it in my hands for smoothing out the edges and using the dremel carving attachments for fine details. I will look into the carving gloves.
Thanks for the advice. Safety is very important.
Rc70 6 years ago
Has anyone used these tools and techniques for carving on fresh wood (meaning cutting a small log from tree then making a figure)?
geordie_h 6 years ago
Do a few test cuts first.
Yonatan24 8 years ago
So many Dremels!
JakeB55 8 years ago
I know Ive been rambling a bit....but Im almost 40 and seeing this discussion gave me a shot of energy that i havent felt in a while. Again....any words of advice would be appreciated more than ya know.
Thanks fellas. Hope to hear from ya soon.
You can do a lot with just the Dremel. Get some good carving bits and some sanding discs and those are great for creating the detail parts.
Have fun.
nkhalsa 8 years ago
A couple of hints:
1) Don't carve pine. It's the worst, except for maybe fir. Start with basswood or tupelo. Mahogany and butternut are good. So is poplar. Red oak is too stringy and maple is very hard.
2) If you use power tools for carving instead of traditional hand tools, you really must address dust collection. A carpenter fried of mine died from lung cancer recently - he was not a smoker. It was from the sawdust. If you make dust from some exotic woods like cocobolo, it can put you in the hospital.
Thanks for the advice. Especially about dust.
I'm not a fine wood worker so I'm not well versed in selecting wood. I chose pine because it was cheap and easy to get hold of. If I make more of these and want them to last longer I will look into better woods.
If you do an instructable about picking woods to caver let me know.
spark master 8 years ago
I gotta disagree, for this, pine is fine enough, it is crappy to carve , but this is gross carving, that is little detail, looks nice I will need to carve one, but I will just use a saw to do the rough out then knives. I do have done many a "ball in a cage" carvings, and I used pine or whatever was available.
see
http://www.wikihow.com/Whittle-a-Ball-in-a-Cage
Power carving is nice but I just like knives, that said, I have used dremels for certain apps.
Nice Instructable I am going to carve a skull on a walking stick.
Thanks for doing it!
Grafx4Life 8 years ago
Do you have an instructable with a normal dremel and not the multi-max?
Not at the moment. I'm working on an idea for a Halloween one and some laser cutting ones.
ishmit 9 years ago
Hi,can i have ur telephon number or line id or instagram or somthing like this for easier coonection?
i have laser machine.when engraving photo on ston the picturehave black and white bound!means one bond about2 cm is strong and 2 cm or less or more is wake!and finally my picture will have bound...i can send its pgoto...please help me..my jobs stoped beacause that ...and nobody know that..
nikko2399 9 years ago
What attachment were you using for part three? 115? 117?
