Wooden PC Case
Intro: Wooden PC Case
My interest in both woodworking and PCs have encouraged me to make a wooden PC case.
There was a lot of thinking, measuring, drawing ...and there was Internet for the ideas.
Eventually, I got started without any complete plan and now my project is stabbing down more than 100 working hours.
STEP 1: Routing the Connections
STEP 2: The Back Panel
STEP 3: Mounting the Motherboard
STEP 4: Graphics Card, Wifi Card and Power Supply
STEP 5: The Fans and the Buttons on the Front
STEP 6: Harddrive Tray
STEP 7: Making a Window in the Side
STEP 8: Painting the Whole Construction and Mount It Together
STEP 9: And This Is the Result
I also mention the technical content here, but this was not my priority,
for me making the case was the most important.
Motherboard: Asus P7P55D LE
CPU: i5 750 2,67Ghz
Memory: Corsair Vengeance 2x4GB
Graphics card: MSI GeForce GTX 750 Ti
Power Supply: Cooler Master G650M
Water Cooling: Corsair H60
SSD: 120GB Samsung Evo 850
HDD: 2x Samsung 3.5 “2TB
Furthermore there are two Noctua fans inside, one fan from Cooler Master, and a laptop DVD writer from HP.
The fan grills, the legs and the front USB ports come from old desktops.
The system is installed with Windows 7 x64.
51 Comments
C3DRIC 7 years ago
Very nice! i would've liked more a steambent wood piece, with a more glossy finish but i'll leave that when i'll be able to work wood correctly x)
jlyvers743 8 years ago
I like the idea. Some instructions how how you mounted different parts would be helpful. For example, how did you mount the standoff screws for the mother board?
Elbee_ 8 years ago
I drilled through the plate with a drill as thick as the body of the stand-off. The stand-off itself as tapped into the plate and sat tight.
RockeyDA 8 years ago
I have had my own plans for something like this for a few months now... i just cant get any one to give me a ride to get the wood. imiges of my plans and what i have to work with... and i did deiced for card mounts, im just gonna cut the metal one out of an old dell case or something. im kinda pissed i cant get any one to just drive me to get wood, i started this in july.
tp.pa.12 8 years ago
Very nice case, I wish I had a computer worthy of one!
I do have to disagree with mounting the boards right to the wood, wood insulates too well, if you had a board in the middle, and cut out behind the boards, then your awesome two fan system could blow air across the boards cooling both sides, instead of just sucking the heat out that they produce.
very nice job once again, looks like a custom pro job.
Tp
Dwargh 8 years ago
Nice idea! :)
But it would be a better idea to move the PSU to the bottom of the case, like every case manufacturer does these days! And, as hijinx78 already mentioned, enlarge the exhaust of the psu on the back. Else, it will die soon! :/
Elbee_ 8 years ago
Thanks for your comment, I know that most standard cases have the psu at the bottom. But why should that be better?
hijinx78 8 years ago
PSU on the bottom is strictly a design/appearance element. You MIGHT draw in slightly cooler air into the PSU when it's bottom mounted because hot air rises, but that's at the expense of venting a LOT more hot air out of the case if the PSU is mounted on top. Plus, with a top mounted PSU you can usually skip a secondary fan on the rear of the case to vent it - assuming it isn't a fanless unit. But you're using water cooling so the point is moot - your biggest heat generator is already being vented directly out the back.
Elbee_ 8 years ago
Ok thanks for your explication.
Dwargh 8 years ago
Elbee_ 8 years ago
Ok thanks, i'll keep that in mind.
<sarcasm>How in the God-fearing hell did this make it into the Instructables email? You didn't use pallet wood. You didn't use a laser cutter. You didn't use a million dollar CNC machine. It's not powered by Arduino or Raspberry Pi. And not even a shred of paracord in the entire thing! Oh the humanity!</sarcasm>
The only thing I would have done differently is enlarged the hole for the power supply. Almost all PSUs draw air in the bottom (inside the case) and exhaust it out the back. Way to go the extra mile and dovetail it instead of just gluing and screwing it. Well done.
Elbee_ 8 years ago
Thanks for your comment! :-)
Jake Maverick 8 years ago
i have been thinking about something very similar for a while...but to echo the previous comment somehwat....I think it wd be safer and make a life lot easier if you used actual metal mounting plate for the motherboard....and the actual metal parts for mounting of the hard drives.
I also notice around your psu....you've not fully cut it out- the air intake for your fan on that is blocked, has your psu not overheated and blown yet? do you have any temp monitoring within your case...I imagine it's getting pretty hot in there under extended load?
Elbee_ 8 years ago
I don't have a temperture monitoring in the case but all the standard temperatures (cpu, graphics card...) stays stable also at heavy use.
very nice work
Elbee_ 8 years ago
Thanks!
spe672 8 years ago
I worked at a computer board company and we supplied PCI Express cards to Apple...apple was having dufficulty passing these tests without adding conductive gaskets around the express card slots.
reverendchip 8 years ago
I've run racks of unshielded multi processor motherboards (starting with overclocked BP6 boards) in my shop for literally decades doing distributed computing projects. I have yet to develop an antler, a tumor or illness. Sometimes government regulations are just stupid.
and at the other stream they encourage wifi everywhere and mandating smart metres....the adverse health effects are becoming well documented, despite the govt suppression of these facts....what they really want it for
www.wired.co.uk/news/archive/2012-08/06/wifi-radar
