Wooden Radio
Intro: Wooden Radio
as a radio.
Discovering and understanding are two typical human acts which belong to the development and education in life. Men are curiously striving for knowledge and if they don‘t find any solutions it makes them anxious. Among its function, the radio “bola” is also a sculpture which does not give any hints to reveal its use. First of all, the observer of “bola” does not know anything about the use of it in the first way. He needs to find out by trying. For switching the radio on and off, setting tune, and to change the volume, the radio has two rotatable rings lying upon another. The round base is the speaker and to use the radio it has to be turned around. Then the radio finds a new stable position on its own through inner weight distribution. Except the electronic pieces, the radio “bola” is completely made out of wood. The case consists of many wooden layers, which are different in their thickness and sort of wood (obeche, balsa, linden, mahogany). If “bola” is not in use as a radio, it can be turned around again to stand on its speaker, which integrates itself as a sculptural object into the interior space.
STEP 1: The Design
After long time of researches, scetches and brainstorming I finally found my idea of a wooden radio. I found a method how to place the tuners for setting them by rings, not by buttons. In my pre-model you can see the axial position of the pencil, which shows the middle and the idea to place the tuners in one line, up to each other, not next to each other.
STEP 2: Choose the Wood
I decided to take different sorts of wood, in my case it got mahogany, obeche, balsa and linden. When I knew what kind and thickness I could buy in the modelling shop, I started to plan the layers, what part I give what wood for. After planning I started sawing and cutting the layers, piece by piece.
STEP 3: Build Up the Hollow Part
After cutting it's all about bringing them clean and parallel together.
STEP 4: Shapening to Final Form
With a turning lathe I finished the form. In one second I was not concentrated enough, so I broke it. It exploded into more then 20 pieces, but I was lucky and could find every little piece to bring it back together.. so take care, this shocking moment is nothing I can recommend :)
STEP 5: Add the Electronics
For the inside I builded an extra mount for the electronics, which is sticking by clicking in the hollow part. With this mount it's possible to place the controllers stacked. Here the upper one is for the volume, the lower one for the channels. To shape them for more grip to the wooden part I took a metal saw and rasps.
When all pieces are prepared, shaped, sanded and brazed, you finally can bring them together, there's no more glue neccessary, just stick them into each other. The profile on the controllers and in your controlling rings need to fit into each other, that there's just one (or two) possible positions. If everything went fine, your radio is done, ready, willing to be used!
Wish you a lot of fun trying it! You can check my technical drawing, but I'm pretty sure every radio would be unique, depending of the wood, the set and apperance.
Thanks for watching / reading, I'm courious and excited about your comments!
Best,
Helena
72 Comments
hummingbird2002 8 years ago
Cool project I am doing this in class!!
Izzypup 8 years ago
I simply LOVE what you've done and an grasping at straws in an attempt to have one if my own! Give my idea some thought and let me know what you think!
Thanks!
helmuel 8 years ago
Sorry for the late answer, I've sent you a message and some pics here, I couldn't add to the message:
(Some wires already broke, don't open it too often ;P )
Izzypup 8 years ago
Okay, so I stupidly asked how much you would charge to make one of your rolling radios for me. (I do crafts too and I know how time consuming they can be - hence the "stupidly".) But I still want one! (Feel free to read that in a whiny voice) I'm admittedly grasping at straws here but what is the possibility (and price, if it is possible) of you putting together the electronic bits? As I said before, I'm electronic-stupid and wouldn't have any idea where to start, no matter how good the instructions are. I'm a visual learner. I MIGHT be able to do it if I watched you and mimicked each step.
The wood is a different matter. I LOVE working with wood and am at least 95% sure I could pull off the housing for the radio.
As I said, grasping at straws. But I HAD to try!
owatson 9 years ago
jjmorrison4 9 years ago
helmuel 9 years ago
Porda 9 years ago
I love the minimal design. Great work!
PowellMade 9 years ago
Nice work fitting that all inside!! Loved it.
Lathes are sure fun. Do you know what went wrong so others can avoid smashing their jobs? Chisel fell below rest or caught?
tomas75a 9 years ago
This is awesome! Nice work! :)
aerohydro_nz 9 years ago
This is a great Instructable. It's a lovely design, reminds me a bit of a wooden MP3 player that was mentioned on BoingBoing a few years ago. (http://gadgets.boingboing.net/2007/12/10/acornshaped-wooden-m.html)
adamwatters 9 years ago
really beautiful work!
hgaikwad 9 years ago
Do u have any simple design which as beautiful as this
helmuel 9 years ago
Izzypup 9 years ago
helmuel 9 years ago
jdenslinger 9 years ago
If I put a blutooth receiver in it, can I call it the e-bola radio? Ok ok... that was lame
But Really awesome product! I almost wish I could buy one! If you find a manufacturer to (semi-)mass produce these, please share with us!
helmuel 9 years ago
helmuel 9 years ago
robolimbo 9 years ago
I'll bet I could put one of those little radios in a hollowed out gourd! Great build!
