Wrap Around Workbench Under $100
Intro: Wrap Around Workbench Under $100
I am not a carpenter or a professional in any sort of way. I took the ideas of several other instructables on this website, designed my own design and am here to post my project for you.
STEP 1: Step 1
The first thing you will need to do is figure out how big you want your bench to be. I made mine 6 ft wide so that when I bought my 3/4" ply wood top, I wouldn't have as many scrap materials. With that being said, here is my material list:
4 - 4x4x10
8 - 2x4x10
1 - 4x8 ply wood sheet cut into (3x2, 3x2, 1.5x4, 1.5x4, 2x4)
1 - box of 2" wood screws
1 - box of 3/4" wood screws
1 - 2x4 peg board
1 - peg board starter kit pegs
Total $98.00 @ Home Depot
4 - 4x4x10
8 - 2x4x10
1 - 2x4 peg board
STEP 2: Step 2
Cut 4x4x10 into 40 inch sections.
STEP 3: Step 3
Next, I made the template for the top of my bench. Using the 2" wood screws, I screwed the boards onto the tops of the 40" tall 4x4 legs. The back is 6 ft, the sides are 4ft and the front is 1 1/2 ft each.
You can see in the fourth picture, I placed the two center 4x4 inside the center section. I did this for two reasons...first, so that I would have a solid surface for the top in the center, and second, so that I could brace the bottom of the legs and make it more sturdy. You will see in the next step.
PS - I lost a clamp in the making of this project :(
STEP 4: Step 4
Now, do the same exact thing for the bottom. I kept the bottom braces about 6" off the ground. This way I could have a footrest that I could reach and/or add a shelf later. Included in this plan is an extra piece of ply wood to add shelving, but I didn't install it in this instructable. I have not decided yet which side I want it on and where I will put my things yet.
Last, add the top. I used the 3/4" wood screws for the top surface.
You are all done!
You will have some extra 2/x4 left over - use this to build a frame for your peg board!
You are all done!
28 Comments
monty324 11 years ago
i'm gonna build one of these but a hell of a lot bigger
Soulsbane 12 years ago
tim_n 12 years ago
falks79 12 years ago
wilgubeast 12 years ago
Awesome job. Can you clue us into which 'ibles you used for inspiration?
mbusby 12 years ago
Firstly I am going to put castors ( two will be locking ones) on the legs so I can move it around.
Secondly the height will be the same height as my table saw so I can turn it into an Outfeed Table.
I already have two work tables, one of which is a dedicated mitre saw table so I don't need to fix any machines to it.
Great Instructable and a well thought out and constructed project too.
Capt Chumbucket 12 years ago
Thanx'
the Capt'n.
hiboyford 12 years ago
karossii 12 years ago
HandyMan1959 12 years ago
skiedra 12 years ago
SantaB 12 years ago
You actually could put in some lower shelving on the sides there. Just notch the plywood to account for the 2x4s. Then nail the plywood to your bottom frame braces.
Anianna 12 years ago
mengel 12 years ago
I like your container box of drawers - where can I buy similar?
Silence 12 years ago
Creativeman 12 years ago
rachel 12 years ago
altontoth 12 years ago
HowlinPreacherMan 12 years ago
As a couple of additions/modifications, you could:
- add some heavy-duty hinges to 'flatten' the bench against a wall to make space for a car (or a second, depending on your garage)
- reduce the length of the 4x4s by 1/2" to add a sacrificial hardboard/plywood top
