X-2812B Test
Intro: X-2812B Test
X-2812b has 4 ws2812b RGB LEDs. You can have a look at this video first.
STEP 1: X-project Member
STEP 2: Test Code
Library
https://github.com/adafruit/Adafruit_NeoPixel
Code example
https://github.com/lspoplove/D-duino/blob/master/X-Project/ws2812/ws2812b.ino
There is a dial switch which you can adjust D3~D10 to control ws2812.
Do not forget dial number 1 to the right side.
2 Comments
IgorF36 6 years ago
I switched on the D3 and used the code example above on a D-Duino-32 (with, obviously, an X2812B on top) but the four pixels still remain white.
Where I'm wrong?
kd8bxp 6 years ago
Use the GPIO number (I think it's 0 zero) - I had a similar issue. There is some timing issue with the display and the neo-pixels when using the D-Duino32. That issue doesn't seem to be there with the D-Duino ESP8266. Here is my instructable if you are interested.
https://www.instructables.com/id/ESP32X-Project-Cheerlight-Badge-Using-MQTT/
