You Have Captured My Heart
Intro: You Have Captured My Heart
I've made a Valentines gift for my wife. I saw this project for a CNC on
http://www.vectric.com/cool-stuff/projects.html. Unfortunately I don't have a CNC. But it can be realized without one.
STEP 1: Cut Your Board.
To build this, you need a Pine board 800x200x18 mm. I've cut one 200x200 mm and three 120x120 mm square.
I cut them into circles on my table saw. Circle cutting can also be done on a band saw or with a router.
On the 200 mm circle I cut a 15 degree bevel around. To do this I put the saw blade to the angle and rotated the board on a nail.
STEP 2: Make the Molding
I used a router table and the router bit shown in the picture to shape the three smaller circles. This can be done free hand. But you have to be very careful, because of the small circles. I recommend a router table.
STEP 3: Drill Holes
I drilled 6 mm holes for the bars. In the original plan are eleven bars, but I reduced it to eight. The bars are cut from a 6 mm dowel to a length of 13.5 mm.
STEP 4: Carving the Letters. Failed!
I tried to carve the letters. I clued the pattern with spray adhesive to the wood. But Pine is not good for carving. Even with a sharp knife or chisel.
STEP 5: Printing the Letters. Success.
For this step i used letter stamps to write the words on the wood. The letters are 20 mm high. I used regular stamping ink.
STEP 6: Making the Heart.
I cut the heart on a scroll saw. I clued two scrape pieces of 18 mm pine to double the thickness. Then I shaped it on a belt sander and with a dremel tool.
STEP 7: Dry Fit, Sanding and Painting.
I clued a doorknob onto the top piece, four 20 mm wooden balls to the bottom piece and made a dry fit of the cage. I was happy with the result. I sanded everything smooth. The heart was stained with Mahgoni and the cage with beech. I put two coats on it with sanding in between.
STEP 8: Finished.
Finally hanging the heart on a small chain and everything is clued together.
Please vote for me in the Valentines Contest. Thank you.
6 Comments
zposner 7 years ago
JanelleG8 7 years ago
oh, this is beautiful! I have never thought of shaping wood the way you have with a Drexel. I love this project. I am inspired!
oldorf 7 years ago
Sehr schön gemacht - wer auch immer das bekommt, darf sich freuen!
Well done - whoever get´s it can be very happy!
andibnbg 7 years ago
Vielen Dank, meiner Frau hat es sehr gefallen.
Thank you very much. My wife loved it.
DIY Hacks and How Tos 7 years ago
That looks amazing. You definitely have my vote.
