Antler Candle Stand
Intro: Antler Candle Stand
Steps for making a beautiful candle stand that is shaped like deer antlers mounted on a wooden shield.I designed this product for my GCSE DT project.
STEP 1: Choosing Wood for Sheild
you need to choose the wood that you are going to use for the shield. I recommend a light colour of wood because it contrasts nicely with the antlers. I used oak, but didn't have a piece big enough, so joined two pieces together with a biscuit joint as shown.
STEP 2: Cutting Out the Shield
I marked out the shape of the shield using the template shown and cut it out with a band saw.
STEP 3: Routing the Shield
I used a router to make the edges of the shield look attractive
STEP 4: Starting Metal Work
I cut the rods into the below lengths in cm.***NOTE for the branches I drew them out and bent them into shape before I cut them to size so I was able to still hold them while they were heated in the forge***
50x1 (two of these for main antlers)
4x0.5(two for top branches)
6x0.5(two for second branches)
8x0.5(four for bottom branches)
STEP 5: Drawing Out and Shaping the Metal.
I heated all the rods in the forge and bent them into the shown shapes over the anvil.
STEP 6: Welding
Then I welded all of the branches on to the main antlers as shown on the orthographic projection that I drew. I used a MIG welder. After welding, I filed the joints to make the transition smooth.
STEP 7: Fitting the Antlers
I marked out and drilled the holes for the antlers slightly smaller than the metal rods. after that I filed the and of the rods into four sided pyramids to make them fit into the holes better. When I had filed them, I lined them up and hammered them into the shield.
STEP 8: Making the Copper Dishes
I cut copper with tin snips into the size of circles to fit the candles I was using (in this case tea lights). then I heated the copper until it was red hot , and then cooled it in water. this made the copper soft and I used a bossing mallet to hammer the copper circles into dish shapes and then cleaned them off with wire wool.
STEP 9: Soldering the Dishes
After cleaning the dishes with wire wool, I also cleaned them off with some Brasso.I then allied flux to the bottom and soldered them onto the antlers as shown in the orthographic projection.
STEP 10: Painting the Antlers
then I painted the antlers with black Hammerite, being careful not to get any on the sheild or the copper dishes.
STEP 11: Finishing Off
I cleaned off the copper dishes one final time, with Brasso before spraying them each with a clear plastic lacquer to stop them tarnishing.
STEP 12: Finished Product
Finally I put a hanger on the back to hang it on the wall and placed tea light candles on each of the copper dishes to light later on that night!
3 Comments
Danger is my middle name 9 years ago
Really cool! I really love the shape!
Lorddrake 9 years ago
great job. keep up the good work.
carve4 9 years ago
