Arts and Crafts Pallet Clock
Intro: Arts and Crafts Pallet Clock
"Time for a pallet contest clock " get it
When I first saw there was a pallet contest coming up I got busy gathering pallet wood my favorite thing to build with.
THE STUFF
plenty of pallet boards
glue (tite bond 2 )
1/2" hinges "4"
battery clock works
clock dial
pendulum
2" clock hands
6x6 piece of glass
stain
varnish
STEP 1:
Finding just the right boards Since I'm building an arts and crafts style I wanted to find quarter sawn oak boards. I looked through a good many pallets but I found some nice looking wood.
STEP 2: Milling the Stock
I used a table saw to mill the boards to best I could just to find the best grain figure. I then worked with them to get as close to book match as I could. I found some pretty good ones
BE CAREFULL
always use care when using power tools and sharp chisels, knives and planes
also use safety glasses
dust mask are a must who knows what they treat those pallets with
Tools
table saw
band saw
chisels
dovetail saw
hand plane
drill and bits
sander
STEP 3: Building the Case
I joined the top of the case with hand cut finger joints leaving them 3/!6th " proud so to give it that LOOK
STEP 4: The Case
I used the closest bookmatched wood for the front of the clock . I had some nice grain on these pieces
STEP 5: Joining the Boards
With the table saw I cut a datto in all the boards where they joined together also where the glass fit the door. Than I made wedges to fit the slots this will give plenty of strength to the glue joints
STEP 6: The Door
Putting the door together I went ahead and stained the wood because
I didn't want to do it with the glass in it. This worked fine but I don't think I would do it again
STEP 7: Cutting in the Hindges
I marked out the hindges and cut them out with a chissel
STEP 8: More Work on the Doors
STEP 9: The Case Is Done
After staining the case I finished with amber spar varnish 3 coats Lite sanding between
STEP 10: The Works
I used a piece of 1/4" plywood to mount the paper dial on and mounted that to a 1/2" x 1/2" frame Drilled a 1/4"hole for the clock put everything together and through the back door I screwed it to the front of the case
a brass knob on the door looks nice front and back
I didn't use a lock or latch because the doors fit so nice and tight. The wood was good and dry but if it changes I'll go back and add them
STEP 11: Ok It's Done
Fun to build and looks nice on the mantle I like the pendulum swinging in the bottom
The quarter sawn oak looks nice and I really like how the nail holes have blackened
how cool to build with pallets
21 Comments
Träslöjdsomvillgöraenklocka 6 years ago
can you please post the length of the sides. It would help a ton because I’m about to make this fantastic clock.
jmblades 6 years ago
I would love to build this. Would it be possible to include some dimensions to give us beginners a starting point?
Thor Hunter 9 years ago
MelissaB1 9 years ago
Very impressed with your pallet clock! It's beautiful. I am just learning how to use my tools - thinking this project is too difficult for me at this point - but certainly inspired to keep making things and improve my skills.
jellybuster 9 years ago
Kai SaerPren 10 years ago
I like what you did and what you did it with. the plans are where?
K
rickysp8 9 years ago
thank you, No plans I copied some photo's of a clock I saw on Etsy and just used standard woodworking practices to build the case
shazni 9 years ago
Beautifully done!
thank you
craftclarity 10 years ago
Oh MAAAAAAN this is beautiful. I'm a huge fan of the Arts & Crafts aesthetic—took a class on the history of that period at school and learned to deeply appreciate the values that drive that style of work.
Thanks for sharing this. It's gorgeous!
rickysp8 10 years ago
The Green Gentleman 10 years ago
That case is beautiful! I'm not sure the clock you put in it really does it justice. Still, I really, really like that case. Super nice.
jonathanmerrington 10 years ago
newts420 10 years ago
billandritsch 10 years ago
The humble pallet becomes a thing of beauty, great job!
annrrr 10 years ago
