Easy & Cheap Hanging Jar Light
Intro: Easy & Cheap Hanging Jar Light
I saw a bunch of these hanging together in a restaurant (Straw) by my house and decided to try and make one. I took the easy route and got the pre-assembled light socket and cord from ikea for pretty cheap. If you can't get to an ikea you can definitely take a trip to the hardware store and assemble the light socket yourself.
I've been a long-time instructable consumer, but this is my first time creating one so go easy on me please! Oh also, if hanging fixtures aren't your thing there are a bunch of other cool jar light 'ibles like this one .
STEP 1: Tools & Materials
Materials:
big jar - i used a bell mason jar from the hardware store $13 for 12 jars so... ~$1 per jar
pre-assembled light socket and cord - i used the "hemma" from ikea - $6.99
light bulb that fits through in the jar
Tools:
marker
some sort of cutting implement. I ended up using an exacto knife, but i'm sure there are better ways
Tools:
marker
STEP 2: Cut the Hole
keep the lid on the jar. unscrew the part from the light socket that unscrews (don't know what the name of this part is). put the part that the lightbulb screws into on top of the jar lid and try to make it as centered as possible. with your marker, draw a circle on the lid around the light socket.
now for the cutting part. at first i tried to use a hole cutter on my drill, but this didn't really work out so well. I ended up just using a box cutter to cut through the lid. keep in mind that the hole doesn't have to be perfect because it won't show and you can adjust everything when you are screwing in the socket. all you need to do is make sure that the end of the light socket can fit through the hole.
STEP 3: Attach the Socket
now put it together!
first, unscrew the attacher thingy from the the socket and unscrew the lid from the jar. then, stick the socket through the hole in the lid and screw on the attacher thingy on the other side of the lid so that it holds the socket in place. As you tighten it on you can adjust the placement.
if you took the ring part of the jar lid off, put it back on over the cord.
STEP 4: Now Put It Together
screw a lightbulb into the socket and then screw the lid on the jar. simple as that!
i like the look of the long low-watt lightbulb best. The red lightbulb looks cool as well. The regular lightbulb just looks kind of so so. i think it would also be cool to find either some super low watt long bulbs or do like this instructable and put it on a dimmer.
my next step is to add a switch. wish me luck!
i included a picture of the restaurant (Straw) in sf where i originally saw these lights.
3 Comments
aleist 12 years ago
robertlena2 12 years ago
drawe21 13 years ago
Other than that, nice work.
