Hardwood Floors
Intro: Hardwood Floors
1 planer, 1 mitre saw, 140 4"x4" Treated Fence Posts
13,000 cuts, sand, stain, sealer, wallah!!!!!!
STEP 1: Cure the Wood
very simple but completely monotonous.
1. first I let the wood dry and cure for a number of weeks.
STEP 2: Planer
then I used a 13" planer to shave off about 1/8 inch off each side to have a perfect edge.
STEP 3: Miter Saw Cuts
3. next I set up a sliding template using painters rollers and rolled the wood onto my miter saw. with which I cut each piece 5/8 thick. (about a gazillion times) ( I found it a good idea to use a really nice facemask for this type of work, unless you want to have a headache as big as TX and pass out and die of strychnine poisoning)
STEP 4: Acclimate Wood to the A/c
4. after these were cut I would take them inside the house in the air conditioning and let them cure for another two weeks.
STEP 5: Wait
5. twiddle your thumbs
STEP 6: Lay Them Straight
6. as they were drying we set them all through the house in order to make sure my math was correct. I had two milk crates full left over.
STEP 7: Prep the Concrete
7. next I prepped the concrete slab.
STEP 8: Glue
8. then I went on to applying hardwood floor adhesive all over myself and the floor by using a grout trowel. (this was the most difficult part because of the speed at which the glue begins to harden vs. how fast you can lay down a row of wood tiles and go back to the first of that row)
STEP 9: Sanded It
9. after adhesion I rented a floor sander from the depot and smoothed out the surface. then cleaned all the dust away.
STEP 10: Stain
10. then we stained it a dark honey color which brought out the colors and lines more.
STEP 11: Sealed It
11. final step was applying hardwood sealer everywhere. this took a couple of days and I did about 3 or 4 coats.
STEP 12: Finally
12. last I added all the trim around the edges and I was done.
oh by the way, I ended up using every last piece of wood. down to final slivers which went into my master bathroom entrance.
44 Comments
doreenn 9 years ago
I'm really hoping you are still on here! What do you think about using old hand sewn beams (I think that's what they call them! Lol). I believe the slices would be larger and I know of a few reuse places around me where I could buy them. Do you think that would be more economical then conventional hardwood flooring? I'm thinking it would definitely be faster but would I need to add any steps that you haven't listed? Also, do you think there is a way to "dip" the slices into a solution to coat them in order to get better protection and perhaps a better moisture barrier? I'm not sure what I would dip them in but I'm just thinking it might be necessary due to the wood choice as well as perhaps make for a faster process altogether. If you could, let me know what you think. I have two rooms I really need to get to that were ripped up due to plumbing issue and I'd love to do something like this. Oh, one very important last issue. If the sub flooring that is down there right now is plywood, could I (or should I) nail instead of glue? Thanks very much and really hoping to get a response from you!
joelsprayberry 9 years ago
hardwoodchamp 9 years ago
This is super awesome!
vbaziuk 11 years ago
wecanclean 13 years ago
canida 13 years ago
WILL62 14 years ago
chrystopherlewis 15 years ago
joelsprayberry 15 years ago
snarke 17 years ago
So you might as well pick something cheaper. I'll agree that an end-grain floor is going to be way more durable than the usual plank-style floor, although a heck of a lot more work to install. Yikes.
verbatin01 15 years ago
Asmodeo 15 years ago
paappraiser 15 years ago
ask4rew 16 years ago
pyroswmr 16 years ago
nothingmuch 18 years ago
kaleb1999 16 years ago
incorrigible packrat 16 years ago
