How to Get Tons of Free Enameled Copper Wire
Intro: How to Get Tons of Free Enameled Copper Wire
There are tons of free copper wire rite under your nose and you dont even know it, hidden at the widest part of a CRT television/monitor held in by springs. There is a square black cable wrapped in tape. What many people dont seem to know is that its full of magnet wire!
All you gotta do is mess up a TV and cut it out. https://www.instructables.com/id/How-to-take-apart-TV/.
-=please dont comment on the dangers of taking apart TVs and such, that is discussed in the link above. this Instructable has nothing to do with taking apart TVs just an extra thing to get out of a TV when you take one apart=-
STEP 1: You Will Need
not much,
a pare of scissors,
a wire spool
and a chair to sit down in and relax for a while.
as well as the wire!
a pare of scissors,
a wire spool
STEP 2: Unwind the Tape
This is the hardest part as well as the most boring!
The tape usually starts where the two wires go in or sometimes about 6 inches down.
You may want to upload a YouTube video before you start because its going to take a long time!
If you want to keep the tape you could wrap it around a pencil or something.
use the scissors to cut excess tape and the two main wires but DONT cut the magnet wire!!!
STEP 3: Unwind the Copper
this part is more fun, but takes just as long.
do it however you want, i put the wire over my knee and turned it and wrapped at around the spool.
As you can see Im not very good at winding the wire but thats cause it takes much to long to do it neatly.
Different TVs will have different gauges and colors but i like the red wire best.
STEP 4: And Your Done
now you got tons of wire to make transformers, electromagnets, coil guns, etc. whatever you want with it!
59 Comments
Blueyzachary 5 years ago
CooperN2 6 years ago
i dont have any
alphatron 13 years ago
And also could you do the same with an old computer tube type monitor?
Thanks
ironsmiter 13 years ago
ALWAYS use standard tube discharge procedures. I
f you didn't just discharge the tube yourself, it's not safe.
The longest I've seen a tube hold a measurable charge was just under one year...larger tubes may hold for longer. I dunno, and am not gonna risk it.
Dischargiong is SIMPLE, and safe, when done properly. no reason to avoid it.
As to the computer CRT question... YES.
Some REALLY old monitors don't have the coils, but pretty much anything with a VGA connector will. Same tube discharge rules apply to Monitors as to tv's.
Celticlady1960 7 years ago
How do you Discharge an old TV Set properly?
ironsmiter 7 years ago
shannonlove 11 years ago
jon002 12 years ago
Jimmy Proton 12 years ago
NachoMahma 13 years ago
. Waiting for the charge to dissipate is not a good idea - it takes "forever" and doesn't always work well. Follow the procedures to safely discharge the tube.
Jimmy Proton 13 years ago
John T MacF Mood 7 years ago
Removing the eenamel, well, it is tough.
Acetone might work. Some enamels were made VERY tough to avoid shorts
in coils,so it's purposely VERY hard to remove. Fire removal gets you
much less at the scrap yard. Perhaps smelt it thereby cleaning the ash
and rendering better grade bright copper... Be prepared for a high
propane bill, and a costly smelter, unless you build your own. Heavy
fireproof gloves, tongs, a crucible, and some other safety equipment is
in order.
rah187 7 years ago
Awsome! I finished removing all of the copper wire from my television last night. I even had the patience to unwind all of the wire from the deflection coil because I needed the ferrite core to make a giant joule thief. I found that the wire from the coil was more useful for winding magnets, inductors, and transformers because there were only a few places where I had to solder the wire. I have been thinking about soldering all the individual strands of wire from the cable together, but that sounds more like busywork than a project, especially when you consider the fact that I already have a huge roll of 24 AWG wire just waiting to be used.
6teeth 8 years ago
Can " the black cable" be used for anything?.I mean it looks like a base for metaldetector or?
it is a very long wire with 1 outlets,same coil.
i tried google but didnt find anything it can be used for.
poiihy 8 years ago
wow!
I recently took apart a CRT and found that weird thing wrapped in tape... I did not know it was full of enameled wire! I will have to rip it open sometime! Thanks!
Don't forget the CRT deflection coils; they have lots of enameled wire too.
PaulineZ 8 years ago
BenderSanchez 8 years ago
Wew I love this guy and this instructable.
JeffB29 8 years ago
Thanks, did it!
JeffB29 8 years ago
comradekev 9 years ago
Yes, but how do you REMOVE the enamel from the wire? it makes the wire worth more to scrap. I've tried lye, denatured alcohol, varnish remover, and other things but nothing works - and some like the lye ate the wire. :(
