How to Make a Awesome Safe Zipline
Intro: How to Make a Awesome Safe Zipline
this is my first Instructable so be nice also I do not own all but 3 images and those three are bitmap images the rest I grabbed from google. that being said have a great time building and riding this
STEP 1: The Materials
OK these materials are redially available to me because I rock climb but most other materials are redially available at home depot and REI (I am in the USA so it might be different for you if you live elsewhere)that being said I AM NOT RESPONSIBLE IF YOU HURT YOURSELF ADULT SUPERVISION IS REQUIRED AND BY ADULT I MEAN RESPONSIBLE ADULT ALSO PLEASE JUST USE COMMON SENSE so with that all out of the way here is what you need...
1. rock climbing harness
2. 2 100 foot lengths of rock climbing rope or steel cable
3. 1 come along AKA hand winch
4. a couple caribeners (3-4 max)
5. a ladder
6. a large pulley
5. a ladder
6. a large pulley
STEP 2: Locate Your Trees
now if you have a large backyard with many trees as i do this is a relatively easy task but below is the tree formation you are looking for basically a tree formation in a "T" completely onobstructed by bushes and other trees (also i apologize for the horrible bitmap image i am not too good at digital drawing)once you have located your trees move on to the next step.
STEP 3: Setting Up Rope 1
this is where your responsible adult comes in now depending on the height of your zip-line set the ladder up on the base tree climb the ladder and firmly secure the rope to the tree with good knots then walk the rope to where it is in-between the other 2 trees
STEP 4: The Yoke (that's What I Call It)
the yoke consists of a length of climbing rope stretched between your 2 trees the yoke rope is suspended off the ground and is connected to your main rope (the one coming from the base tree) using a caribeaner the base rope AKA the main rope is actually suspended in the air by the yoke so to build the yoke string the rope and pull it TIGHT with the come-along but be mindful to thread the main rope with the pulley before pulling the yoke tight
STEP 5: Now Ride That Thing!
provided you have done all steps correctly you should be in business all you need to do is put on your harness climb the ladder on the base tree clip in to the pulley and go down as for getting off the zip-line have a responsible person bring you a ladder to step on while you get off now with that all being said have fun be safe and don't let your friends strand you by not bringing you a ladder
49 Comments
Mary TaylorB 6 years ago
We have made a 250 zip line. All I need to know now is how to manually retrieve the trolly. We have a disc seat on the zip line trolly. Do we just attach a rope to the rope under the disc seat and pull it back up the line. This zip line is ove a very big pond. Thanks
sbtuttle 7 years ago
Do you leave the come along attached?
Thanks
kutz 12 years ago
kutz 12 years ago
Im not a mountain climber but I can agree about double safety lines and such
About the whole murdering trees buisness, the reason that the tree strangulates itself when you put the cable around it is because the tree gets nutrients through the inner bark and the core, and you basically cut off its supply above the cable, same thing will happen if you cut a deep ring around the bottom.
Assuming that this is going to be a permanant zipline, you probably want to use an old tire or two the stop it from killing the tree quickly (like under 20 years)
My friend has a fairly large one in his backyard and he didnt do any of the above suggestions with safety gear or tree health, and he hasnt had a problem for over half his life :3
romac 15 years ago
sk3lton 13 years ago
BobMarleyFan 12 years ago
sk3lton 12 years ago
romac 13 years ago
the image below of the tow-strap being used looks fine and dandy to me
anyway it's a good issue to bring up so that people at least consider it
fight4gipper1 13 years ago
passerby06 14 years ago
However, if you're just setting up a temporary zipline (like for the day or weekend, not a week or more), a strap is probably OK. As mentioned elsewhere, tho', use a strap where both ends are secured to each other, away from the tree. Not a "noose" where one end is slipped through a knot or loop at the other end and cinched tight against the tree. The potential is much greater for real damage to the tree, and likely will make it more difficult to take it all down when you're done with it.
jtpoutdoor 14 years ago
bedbugg2 15 years ago
lane29 14 years ago
ilpug 13 years ago
dragonsniper 13 years ago
ilpug 13 years ago
julian_blnc 13 years ago
mr_darker 14 years ago
