How to Make a Shock Proof System for Your Gopro Hero Camera
Intro: How to Make a Shock Proof System for Your Gopro Hero Camera
this isn't the prettiest thing but i am just testing the concept and it seems to actually work...i dropped it off a 20 ft cliff while cliff diving and it hit the solid ground next to the water and it was perfectly fine.
STEP 1: Things You'll Need
not everything is in this picture
1. lots of rebar(i used conduit though)
2. something to bend your rebar with
3. either a welder or metal epoxy(i recommend the welder but i had to use epoxy cause my dad had the welder with him at work)
4. bungee or elastic of some sort
5. sheet metal
6. sheers to cut the sheet metal
7. electrical tape
8. a flat mount from your go pro
9. hammer and anvil to bent the sheet metal
5. sheet metal
7. electrical tape
STEP 2: Bend the Reabar(or Conduit) Into Squares of Size of Your Choice
make two squares size of your choice
STEP 3: Cut Four Pieces of Rebar/conduit
cut them to the same length as the sides of your squares
STEP 4: Mix the Epoxy(not Required If Using Welder)
epoxy usually comes in tubes separate so you need to mix equal amounts of epoxy and hardener (sometimes you can buy it in the shape of a seringe that are together like you see in the background of the picture)
STEP 5: Apply Epoxy
i applied it to the inside corner and placed one of the four pieces on the inside...the epoxy should set in about 10 to 20 minutes...do this to each side
STEP 6: Cut the Sheet Metal
cut your sheet metal into a strip about three inches wide and about 15 inches long
STEP 7: Fold the Sheet Metal
fold the sheet metal into a "U" shape like the picture
STEP 8: Cut the Sheet Metal(again)
cut your "U" some "wings" so you can hook the elastic to the "U" like in the picture...do this to both sides
STEP 9: Hook the Elastic On
i put electrical tape on the corners because they were sharpe...but hook the elastic to matching corners just like the picture shows
STEP 10: Finally Put the Gopro Flat Sticky Mount on the Inside of the "U"
this is pretty self explanatory
STEP 11: Now Your Ready!
please leave comments on what you thought and send pics of your finished product thank you for viewing my instructable
22 Comments
Fly4aWhiteGuy 8 years ago
1/2" pvc pipe would work fine, and less likely to hurt someone if it hits them.
Rose Workshop 3 years ago
Great Work! Gonna attempt it myself!
Eeroz 11 years ago
And Im also interested in your usage of this device. Are you just clumsy or do you have some sort of extreme usage for your camera?
roberto22223 11 years ago
RichardBronosky 9 years ago
Yeah I kayaking and handed my camera to a friend to get a shot of me because I'm never in the shots since it is mounted to my boat. He wanted me to come downstream and get the camera from him and I told him to just throw it. He said, "I don't trust myself to throw your camera." I said, "It's fine just throw it." From 15 feet away in a seated position he throws it and I in a seated position catch it. Which is a shock because neither of us ever played sports. I say, "See. Nothing to worry about. And if you missed, it's waterproof." He says, "Yeah, but does it float?" That's when it hit me how close I came to LOSING MY BRAND NEW CAMERA ON ITS FIRST OUTING. We're both pretty pathetic at both catching and throwing. We could have tried that 100 more times end never pulled it off.
They sell little floats made of foam, and also float handles & floating wrist straps.
Glad you didn't find out the hard way! I had to grin when I read your near miss encounter!
Eeroz 11 years ago
Anyway great idea you got here.
bjc4073 10 years ago
Gopro's can freefall literally from thousands of feet in the air (look on youtube) and hit solid ground with no trouble. The camera is completely waterproof, and is undestructable, so I don't really understand why everyone is freaking out.
NinjaBoy12 10 years ago
this is only true if the waterproof housing is attached
Ferriswheel 10 years ago
Ive seen one fall out of the housing whilst skydiving and it was fine.
the hero 3 cases had a sliding latch to keep them closed. every other one (including the new hero 3+ case) could be opened by a decent force applied in the right direction. in the video i saw, his gopro hero 2 hit the roof of the plane in the right direction and the case opened, letting the gopro fall out.
Although this is a brilliant design, and would be perfect for so many other ideas. Gopros are already designed to withstand serious impacts. They are designed to be lightweight so that their terminal velocity is drastically decreased, meaning they hit the ground at a speed that the camera has been designed to handle. The case is designed to withstand even more force- I have seen someones gopro fall off their helmet when they went skydiving, and it hit concrete and still worked (the case had a crack in it but was mainly fine- just not watertight). And cameras themselves are strong enough to fall off a plane and have no damage. I get that you are trying to protect your camera, and i think you designed a brilliant piece of gear here. But Gopros dont need it.
MartijnD 11 years ago
heromorph 11 years ago
jf_blanco 11 years ago
licenseless 11 years ago
zzbb 11 years ago
