How to Make a Survival Bow and Arrow
Intro: How to Make a Survival Bow and Arrow
this bow is much easier to make and use than a regular bow. if you are stranded in the jungle, this is how u will get your food. bamboo works well also if you can get some. and PLEASE RATE AND COMMENT
STEP 1: Materials
1 axe/chopper thing
2 paracord or rope
3 four 0.5 inch straight sticks/bamboo
4 kite string( i will explain later)
5 and a partridge in a pair tree
2 paracord or rope
STEP 2: Woodworks
take your sticks (no taller than you are) and arange them so they alternate thicker ends (see picture)
see, easy
see, easy
STEP 3: Knotting It Together
you can skip this step if you use twist ties but you wont have those in the wild and paracord gives a nicer look
I came up with these combination of knots
put them on the ends, near the handle, and in-between. (see pic)
to tie the knot:
1 start with a clove hitch (see pic)
2 flip over and tie a shoestring knot/ simple knot
3 flip over and tie a shoestring knot/ simple knot
4 flip over and tie a simple knot with a extra twist and then another simple knot
to tie the knot:
STEP 4: Making the String
KITE STRING:
i use it because it is
thin
strong
will not stretch over time(i think)
has a ring to it when the arrow flies
take your kite string and tie a loop on the end by
splicing it(see pics)
or doing a slip knot from:
https://www.instructables.com/id/How_to_Tie_a_Slip_Knot/
the string should be 4 in shorter than the bow
so tie another slip knot on the other end of the string
thin
strong
STEP 5: The Arrow(s)
take a smaller stick and whittle the tip into a point
whittle the other end with a small notch
take a sheet of paper and roll it into a cone,staple, cut the tip and the end so it looks a good size
slide stick into it so it to the end
staple to stick
tie thread above staple
i stiched a handle on mine from this video
staple to stick
STEP 6: The Finale
i do not know why most people have a final step but im using mine to show you how to sting the bow...... just slip 1 of the loops over 2 of the bundled sticks on top
and bend the bow until the string nocks over 2 of the top sticks
STRING MUST BE 4 INCHES SHORTER THAN BOW
PLZ RATE AND COMMENT
37 Comments
reneranzani 2 months ago
Looks amazing! Will make and use one as soon as bamboo is acquired.
michaelaudreymyersoct31st 8 years ago
Pretty cool. I found a webpage a couple years ago that teaches how to make a bundle bow from paracord and two to three sticks, each slightly longer than the last.
jakub.kohlmayer 9 years ago
first of all, the arrow doesn't have a heavy tip so once you shoot it, it will go spinning out of control. Plus the bow will break really fast because of the stress points. I'll still try it though.
MandalorianMaker 10 years ago
ssgtgibby 11 years ago
hossweightlifter 13 years ago
ibayibay1 12 years ago
ringring 14 years ago
ibayibay1 14 years ago
racoondawg 14 years ago
paintboy360 14 years ago
iMakeRandomStuff 14 years ago
magpies are australian crow like birds that are coloured black and white. in breeding season, they will sweep at anyone who gets close to it's nest. it happened to me once and it hurts.
and cats eat bread?
BearFist 13 years ago
noorladha2 14 years ago
kicker109 14 years ago
CristianBarraza 13 years ago
