Light Box
Intro: Light Box
I needed a light box for tracing airfoils from kites (among other things).
I had some old fluorescent lights and of all things a recessed skylight box housing thing that looked perfect for the job.
STEP 1: Find a Fluorescent Bulb
and associated ballast, rip the things apart to get the pieces you need.
STEP 2: Wire to Test Power.
here i am wiring it up and placing it in box to see if there is going to be enough light to illuminate my pages and kites.
STEP 3: Test Light in Box
must test to make sure it will do what i want.
STEP 4: Put a White Bottom on the Box.
for more reflection. i had some old white laminex covered wood which seems perfect.
STEP 5: Add Switch Housing
for the on off switches. i'm adding 3 switches in case i need to put more lights in later.
STEP 6: Wiring It Up
i actually added a second fluorescent. as you can see it is not much good. you'll be able to figure out how to make more if you need em.
STEP 7: Feet for Bottom of Box.
i had these scraps of round timber left over from another project. simply woodscrewed into bottom.
STEP 8: Housing the Translucent Plastic on Front.
i had some old framing timber with a recessed edge perfect for holding the plastic in place.
STEP 9: Useability Testing.
well, does it work?
9 Comments
sunshinecook 14 years ago
http://www.eleventyhandmadedesign.com/2009/10/homemade-light-box-with-fluorescent.html
gurelli 14 years ago
http://www.eleventytheblog.com/2009/10/homemade-light-box-with-fluorescent.html
weasel999 14 years ago
needexercise3 14 years ago
grimgroper 14 years ago
mahbooty 18 years ago
Silvester10528 17 years ago
ringworld 16 years ago
bluelion 18 years ago
