Make a Steampunk Pen Knife
Intro: Make a Steampunk Pen Knife
Here is how to make a Steampunk pen knife, this isn't a modification on an existing pocket knife, rather these are instructions on how to make one from only basic materials. This knife includes scissors, philips screw driver, imperial ruler, two sizes of flat screwdrivers, bottle opener, old fashion jar opener, can opener, file, wood saw, scribe and knife.
special note I have updated this with an additional step and the main image has been changed slightly, as a result of this some of comments apply to first 8 steps.
STEP 1: Tools and Materials
tools list
1 files
2 awl
3 dremmel with cutting disk
4 scissors
5 pliers
6 wire cutters
7 hammer
8 drill bits and milling bits
9 double edge tape
10 Screwdrivers
11 circle guide
12 blow torch
13 hack saw
14 taps, dies
15 hand held drill
16 rasp
17 vice
18 printer
19 basic photo editing soft ware
20 computer (although it's a bit of a given if you're reading this now)
optional tools
1 band saw
2 belt sander
3 drill press
materials
1 steel bar 1/8.............................. $2
2 brass sheet 1/16 .......................$12
3 rosewood 1/4 .............................$5
4 Phillips Screwdrivers...................$2
5 brass rod 1/8 ...............................$4
6 brass tube 3/16 od 9/64 id.......$1.5
7 four small screws..........................$0.5
8 two nuts and two bolts.................$1
9 file....................................................$4
total.....................................................$32
keep in mind that the price of the parts will vary depending on where and how you get the parts the list given is what I had to pay and I had some discounts for example the green steel bar was on the curb destined for the trash, the bolts were part of an useless attachment on my bicycle and the brass was floor scraps from a sheet metal shop, for $12. Even though some of these were free for me I still put what it would cost. To get the parts the best place to get them from is a local metal shops in a phone book ,the rose wood can be found in a music store for a guitar finger board, if you can't find it then go to a hardware store and get a wood such as maple or mahogany, if you cant find a metal shop locally then go to http://www.onlinemetals.com/ and all the remaining parts can be found at a hardware store.
1 files
2 awl
4 scissors
5 pliers
6 wire cutters
7 hammer
9 double edge tape
10 Screwdrivers
11 circle guide
12 blow torch
13 hack saw
14 taps, dies
15 hand held drill
16 rasp
17 vice
18 printer
optional tools
1 band saw
2 belt sander
3 drill press
materials
STEP 2: Part Designee
The hardest part of the progect I found was to design all of the components and to adjust the locking mechanism. this took longer to do, then all the metal fabricating. You could go ahead and design them yourself or take the scanned images of the parts I made. Start by dragging the first three images to a word, photo shop or any basic photo editing software file, then adjust the magnification until the rulers belonging to the software are accurate to a hand held ruler, then adjust the size of the scanned image until the ruler in the image is accurate to a hand held ruler ,then print. the parts are identified with a letter as given in the photo.
pieces A, C, D, H, I, K, L, are 1/16 brass E, F, J, N, O, are 1/8 steel
K, M, are 1/4 rose wood
P is a 3/4x3/16 od x 9/64 id
R in a 1/16 washer you could buy them from a hard were store or make them from brass
piece G, is 3/16 i decided to make piece C thicker then the rest for durability
some of the peaces are repeated K 8x L 5x P 2x Q 3x R 2x S 2x T 2x
STEP 3: Preliminary Metal Fabricating
Start by cutting the printed sheet then use double edge tape to attach the paper piece to the pieces of metal then cut them, just be sure to make them a little bigger than the the paper guides so they can be filed. I used a dremmel with a cutting wheel. Once you have finished cutting the pieces use a circle guide to find the center of the holes then drill them to the appropriate sizes. For the wood saw use the dremmell to cut the teeth then file all of the rough edges. some of the pieces are repeated, reefer to the previous page and the numbers.
STEP 4: Wood Work
Start by cutting the wood the same way as the metal by using thF paper guide. Follow this by drilling the holes then use a milling bit to cut square holes in the wood. for the metal nuts make sure that they cant turn., finish this step by using a rasp to round the edges.
STEP 5: Final Metal Fabricating
In this step you will perform some small alterations to the pieces, starting with the file you may have noticed that it is made of two pieces. I have done this was because the file was made of tool steel witch has a high carbon content and is heat treated and i was not able to drill it so I made an insert of soft steel attached with a dovetail joint (which is basically what you see in a jig saw puzzle). The insert was bigger then by hammering it resulted in a tight fit. the notch in the file can be made with a dremel. Follow that with making the thumb nail slot this can be made with a cutting disk. The scissors are one of the hardest parts to make start with the drilling a 1/16 hole in the center of both pieces then counter sink the hole with a /8 bit on both sides, then use a 1/16 headed smooth nail cut it to an 1/8 longer then the two pieces of metal then hammer and file it resulting in a smooth rivet, and for the Phillips screwdriver start by cutting a cheap screwdriver with a dremmel then place the cutting wheel in a drill press and use it to cut a notch follow that with drilling two 1/16 holes which should be countersunk with a 1/8 bit . then make a brass insert inside the steel screwdriver then drill two holes in the insert then finish it with two rivets such as the scissors. For the knife and other sharp edges use a file or a belt sander to turn the flat edge to a sharpened edge. Some of the item are complex and can not be cut with the dremmel so they can be cut on the inside with a hacksaw and file. To connect all of the stationary brass pieces it best to use thredded rods along the bottom, to thread the rod use a die and simply screw it on like a nut, and as for the threaded holes, use a tap to thread the three holes often seen in the bottom of the brass peaces. For the ruler engrave the the brass piece with a scribe. Finally next to the scissors two 1/16 washers are required make them by drilling two holes then cut the exterior. Once you have the peaces you could harden the steel by heating them with a propane torch then wen heated place them in an open metal container filled with water to quickly cool the metal, making it harder but beware that this will slightly change the shape and size of the metal so do not directly heat the hinge point or the brass. When you have finished hardening the metal compare it to the paper guide and file them to the right size.
Final be carful wen working with tools and the torch and I will not be held responsible for any injures.
STEP 6: Assembly
LAYER 1 start by arranging all of the pieces, then take M and two of the bolts and insert them head side down in the wood and cap it with piece D then use the small countersunk screws to seal the bolts in. the large holes in the side of the wood is for a screw driver to turn the bolts. as seen on image 1-7
LAYER 2 add the two tubes on top of the threaded bolts then instal piece L and peace N then place both of piece R the washers on the opposite side of the the screw driver as seen on images 8-11
LAYER 3 place 3 of piece K and the scissors piece P on opposites sides as seen on image 12-15
LAYER 4 add one peace K and peace I the ruler on opposite sides then cap it with peace C as seen in images 16-20
LAYER 5 add two peaces of peace L then place peace E and peace U on either side as seen in images 21-23
LAYERS 6 and 7 are much the same add four peaces of K to one side and peace B and J as see in image 24-31
LAYER 8 if you using a 3/16 knife peace A then add peace L twice then peace G, if your using a 1/8 blade then remove peace A, ether way place peace F to the opposite side of the knife.
LAYER 9 place peace H on peace O then screw it down after placing the nuts in the square holes, then take the three 3/4 threaded rods and file a slot in the top of the rod so that you can use a flat head screwdriver to turn it, next use an all to line up all the holes then screw down the threaded rods in the holes. finish this by capping it with the peace H and O combination and screwing it in and your done.
STEP 7: Conclusion
After finishing this project I had done some research and found the closest Swiss army knife to buy is at http://www.swissarmy.com/MultiTools/Pages/Product.aspx?category=doityourself&product=53341& costing $35 plus S.H allthough the one I made is about $32 it's not exactly cost effective however, it is a great project for the sake of doing a project and buying one doesn't give you a sense of accomplishment or some thing to brag to your friends about.
I hope you enjoyed this instrucaible, if you have any question or comments feel free to leave a message and I will leave a response if I am able, and since you have read this instructable this far I ask that you please leave a rating and good luck with your project.
STEP 8: Legal Document and Disclaimer
This project can be dangerous while being built and when completed so be sure to take safety precautions. I will not be held responsible for any negative actions resulting from viewing this. The only image that was used that I did not make myself has the url on the previous page and is again placed here http://www.swissarmy.com/MultiTools/Pages/Product.aspx?category=doityourself&product=53341&
STEP 9: Update, Optional Engraving and Inlay
After having read the comments I have noticed that some viewers argue that this does not look Victorian enough to be called steampunk, so in answer to this I have made an update of an optional step of how to engrave metal wire into the wood. To make the inlay start by drawing the design on transparent drafting mylar and tape it down with double edge tape. Then use a hobby knife to cut lines ,then carve a groove with a router bit. The router will leave a rough line so carve it with a chisel. For the brass lines use 1/16 wire, and bend it so that it fits in the grooves then use super glue to adhere the pieces. This will most likely leave a mess of glue, either way use a file to remove the top layer of wood, glue and metal; this cleans the surface as well as making the wire seem wider.
84 Comments
budharpey. 9 years ago
that's a cool project for training metal working skills... maybe i'm gonna try that...
Qwertyfish 9 years ago
sconner1 12 years ago
It would be cool to put only period tools in.
Phillips screws although superior weren't invented yet.
A straight shaving razor would be, even if it were difficult to use and maybe even downright dangerous.
I like the idea someone posted about including a clock key.
Steampunk is fiction after all so go ahead and add bluetooth :)
DIY-Guy 9 years ago
Beautiful concept.
I'd add a key to the Nautilus (Captain Nemo's submarine).
3366carlos 9 years ago
outstanding project.
triumphman 12 years ago
bobthebuilder728 12 years ago
weasel999 14 years ago
chicken12175 13 years ago
Void Schism 13 years ago
antonia27 13 years ago
LaBeasy 13 years ago
alexander.m 13 years ago
sneaky snake 13 years ago
jhonny 13 years ago
Foaly7 14 years ago
alexander.m 14 years ago
How2BRandy 14 years ago
a.nony.mouse 14 years ago
