Motorcycle Whack-bonk
Intro: Motorcycle Whack-bonk
Anyone who has spent any time on a motorcycle has probably experienced some close calls with unobservant drivers. Motorcycles and cyclists are powerless most times to do anything in these situations, other than shake a fist and yell in hopes the offending driver hears your colourful language over their caramel macchiato sips.
Time to fight back! Give 'em a taste of the whack-bonk!
Using a foam pool noodle and a wooden dowel it's time to give a little comeuppance to bad drivers. Add insult to injury by inscribing messages on the noddle, then giving the offending vehicle acouppla whacks to let them know they did you wrong.
Enough talk, let's whack-bonk!
*this Instructable is for novelty purposes only.
*not responsible for any injuries suffered from use of this Instructable.
*be safe, and always obey the road rules
STEP 1: Tools + Materials
tools:
- hot glue
- permanent markers
- hobby knife
- wooden dowel (squeegee handle)
- pool noodle
- empty plastic container
- 2 x cable-ties
STEP 2: Cut Foam Noodle
Most foam noodles come with a cylindrical opening in the centre that runs the entire length of the noodle, perfect for a dowel of the right size. Measure the length of the foam you will need to cover the dowel, leaving room for a handle and a little extra foam at the top to protect the top of the dowel.
If unsure cut a longer portion of foam than required and trim off excess as desired.
Pool noodle is a funny name.But since noodles aren't hollow, these should really be called foam bucatini. But I digress. Where was I? Ahh yes, cutting the foam. Cut foam to length and insert dowel, there should be enough friction between the dowel and the foam to hold it in place. If not, use a liberal amount of hot glue to secure the dowel in place.
STEP 3: Holster
You'll also need a place to store your whack-bonk when not in use. I chose a low-tech approach to hold mine, an empty plastic container slightly larger in diameter than the foam noodle.
Remove the top and bottom of the container. Create two small openings on the centre portion for cable-ties which will be used to fix the holster to the bike.
Find an appropriate place on your bike which will accept the whack-bonk. The placement needs to ensure quick deployment while keeping the bike functional. I chose the rear left hand side, just above the passenger pegs. Cable ties were laced through the openings on the plastic container and attached to the turn signal.
STEP 4: Share Your Thoughts
Dispensing justice with the whack-bonk is fun, but may not get your message across. You may just look like a lunatic with a large wand striking windshields and yelling muffled expletives inside your helmet. That's why it helps to write out your message to ensure that bad drivers knows exactly why you're so upset.
With permanent marker, embellish your whack-bonk with colourful sayings. Selectively place the sayings around the foam so that you have a choice of message to send.
STEP 5: Dole Out Bonks
With your whack-bonk installed, you're ready for the next unobservant driver who is paying more attention to texting their BFF than the road.
Go ahead, give 'em a couple of bonks to pay attention. Let those bad drivers know how you feel with a solid smack and a sassy saying.
Be safe, and have fun! Happy making :)
124 Comments
MillennialDIYer 6 years ago
Now I just need a jousting lance version of this...
yuukikonno08 7 years ago
I say make a bunch a take one and throw it at them instead, much safer on your part!:)
diyoutdoorsman 13 years ago
Fool! This post i obviously just a joke just like most of his other posts so i wouldn't waste my time with this long post that people are just going to criticize for being stupid. So go find something else better to do instead of waste your useless life making stupid posts. Have a nice day.
LynwoodJ 8 years ago
Something you should keep in mind if you decide to open your door on a motorcycle, or try to "put you in the ditch, under my wheels, or into oncoming traffic": This is a felony offense, punishable by up to 20 years in prison. Also, being as it is officially on record that this is a premeditated act, your vehicular manslaughter charge could be upgraded to first degree murder (I know that the DA would certainly try, at least). This is pretty clearly a joke post, so I would keep your thoughts to yourself.
Bloodbeard 12 years ago
I don't know what state you're in, but in California it is specifically legal for motorcyclists to share lanes with cars. By that I mean it's not some unwritten rule, the law goes out of it's way to state that it is permitted.
Also I highly doubt your statistic is true. I encounter bad/unsafe drivers constantly, and by far the majority are on 4 wheels. Also 95% of collisions I see (which is a pretty regular thing in my area) involve cars, and the rest of the time it's freight trucks. Motorcyclists may be irritating, but I would bet my life they are safer drivers. I certainly would be if there was nothing protecting me from getting squashed like a bug.
diyoutdoorsman 12 years ago
Sharing a lane with a car is certainly legal in California, but not everywhere else in the US and it is a dangerous practice. Lanes are narrow enough for one vehicle at a time. Riding a motorcycle is an inherently dangerous activity. Bike riders need to be vigilant at all times. Non-motorcycle drivers need to watch out for everything on the road not just bikes. Proportionally, there are probably the same percentage of stupid people driving bikes as there are cars. It just so happens that there are a lot more cars on the road than motorcycles. As long as everyone respects each other and shares the road we will all get where we're going.
DIYJRAY 8 years ago
The fine difference being, that a stupid motorcyclist will kill themselves, while a stupid car driver can certainly kill a motorcyclist. I don't know of any incidents where a motorcyclist ever killed a driver and walked away.
Grazerquart 9 years ago
And it is legal to ride between lanes on a motorcycle in California
floptw 12 years ago
Blaaken 12 years ago
Sovereignty 13 years ago
Matter-o-fact, I'm thinking of having another sticker made stating: "When I retire I'm moving up north to drive 20mph under the speed limit. I won't mind my own business and then b!tch and moan about how much better life was in Florida....but I'll stay up north anyway so everyone can hear me whine. I'll vote to make the north more like Florida...and then go back to Florida in the winter."
And I'm a proud member of the Ones out of the Fives.
mncamper 13 years ago
Still mad the south lost I see.
bo88y 13 years ago
- - On the other hand, magnanimity is more manly than an emotional lack of impulse-control. Read a biography of George Washington, or watch some old episodes of "Kung Fu."
- - One should distinguish the very different tasks of attracting notice for the sake of survival and exacting revenge. The former is prudent, but the latter is self-indulgent, emotional, and primitive, the kind of thing teenage gangs get all worked up about.
- - Our society is already losing civility fast, and contributing to the loss of civility only makes it worse. It can be an affecting gesture to reveal initial anger, but then make a visible transition to magnanimity and forgiveness. Unfortunately, this may often go unnoticed.
glorybe 13 years ago
By the way i live in a warm climate where riding every day is practical so the miles I put on my many bikes were really extensive.
I will say that many car drivers feel they have some natural right to be stupid or to operate a motor vehicle when they really are no longer qualified.
Death to innocent motorcyclists from car drivers making what they call a "mistake" is all too common. If we ever get real about this issue we will test car drivers on a swoopy race track with numerous corners to see if they can actually drive a car rather than simply go straight down a road like a brain dead sheep on tranquilizers.
-Aj- 13 years ago
If a car opened their door on a motorcyclist, for any reason, they are bound to be in a world of trouble. you may as well be purposely hitting a pedestrian on a crossing!
Only wearing protective gear and now pissed off.
And i can tell you right now there are many more incidents of motor cyclists being endangered by other vehicles than the other way around. Even cars in blind spots people have trouble seeing, so a bike 4x smaller is going to have alot more trouble.
Oh, and if you swerved at a bike to try and put them off the road, aside from being up on serious charges YOU would be the one "escalating a bad situation
The point of this instructable is to be fun / a novelty. The author does not condone hitting another vehicle with anything im sure. But i wouldnt blame him for wanting to in some situations.
lilroud 13 years ago
