Kids' Chair Made of Recycled Materials
Intro: Kids' Chair Made of Recycled Materials
I recommend this chair for kids under 6 year old, because of
the size of the chair it would be uncomfortable for bigger kids.
STEP 1: MATERIALS
You can find most of the materials at your home (or in a toys store)
1) A clean 5 gallons plastic bucket
2) A plastic flying ring
3) A plastic flying disc
4) A piece of wood of 1 inch where you can draw the bottom of the bucket
5) A little bath toy bucket (if want)
6) A wood broomstick
7) 4 (four) metal squares about 4 inch
8) 8 (eight) 1 inch screws
9) 4 (four) 1 1/2 inch screws
10) 1 or 2 sand papers for wood
11) Cardboard or paper sheets
12) Pencil
13) A drill
14) Something to cut the bucket (I used hot knives)
15) Scissors
16) Paint
12) Pencil
13) A drill
15) Scissors
16) Paint
STEP 2: START
Once you have the materials the first step is to take the sizes or proportions of the bucket.
1) Cover the body of the bucket with a white cardboard from under the metal handle and to the bottom
2) Mark the bottom in the cardboard as guide of how high will be the back of the chair
3) Mark the perimeter you want the chair's back will cover.
4) Quit the cardboard and draw the design you want the chair's back will have, fold in half for symmetry and cut the pattern
STEP 3: MARK THE BUCKET
Use the cardboard pattern to draw the design of your chair in the bucket.
Remember the bucket's bottom is the sit.
then cut the bucket by the line, be careful.
After cutting use the sand paper for making smooth the edges of the bucket
STEP 4: MAKE THE FEET
1) Use the bottom of the bucket to mark a guideline on the wood and then cut the circle. And cut the broomstick in four pieces
2) Mark the wood circle as in image and make four holes for the sticks making sure to not go all through the wood.
3) Use the metal squares and use the 1 inch screws to set the sticks
use the sand paper to make smooth edges
(the metal squares are 90°, for making a bigger angle you can
hit them with a hammer until they have the angle you wish. This
chair uses an angle about 100°)
STEP 5: TIME TO PUT ALL TOGETHER
Use the image as a guide.
1) The feet at the bottom, then the cut bucket, then the flying ring and the flying disk at the top.
2) Make the holes for the 1 1/2 inch screws as in second image
STEP 6: BACK BUCKET
This is optional
you can add the bath toy bucket at the back of the sit using some screws or using silicon or a special glue for plastic. I used two screws with screw nut or threads (whatever name it has)
At this point you can paint the chair and then assemble the pieces or you can put together all the pieces (including the back bucket) and paint the chair at the end.
wait until paint dry and there you have, a little chair for your kids.
7 Comments
tumidaj 10 years ago
lindarose92 10 years ago
shazni 10 years ago
mariaclemente2000 10 years ago
HollyMann 10 years ago
criztos 10 years ago
ella10 10 years ago
