Rustic Minibar From Pallet Frames
Intro: Rustic Minibar From Pallet Frames
In our lovely garden we have a nice sunny corner where we barbecue. But there is always too little counter space for both food and beers. So to solve this world problem, I want a piece of furniture that looks nice but also has both storage and counter space.
STEP 1: Plan and Materials
I wanted to use the rustic look of the pallet frames and started by making a sketch of how I wanted my minibar.
Materials:
- 4 pallet frames
- 1 pallet
- 1 tabletop
- Some spare wood (for the inner frame)
- 4 hinges
- 4 wheels
- 1 lock
- Screws
Tools:
- Hammer
- Saw
- Jigsaw
- Circular saw
- Screwdriver
- Grinder
- Orbital sander
- Crowbar
STEP 2: Adjusting Size
I found that the pallet frames were too wide for how big I wanted the minibar to be, but I still wanted to use the hinges. I removed the old nails from the hinges, cut the frames and screw the hinges back on.
STEP 3: Foundation
Of course the bottom had to fit the top, so I adjusted the width of the bottom and used the spare boards to fill out the holes. Then I added some wheels so I can "drink and drive" at the same time :)
STEP 4: Adjusting Heights
I wanted my minibar to fit the normal height of a kitchen table (normal work level from floor to tabletop is 91 cm in Denmark) and cut the upper frame and hinges.
STEP 5: The Inner Frame
In order to stabilize and secure bottom and top to the structure I needed to make an inner frame.
STEP 6: Tabletop
I had an old tabletop, but it looked rather new next to the old pallet frames, so to make it more "rustic" and "alive" I burned the surface. I think the result was rather neat!
STEP 7: Cabinet Hole
I wanted to be able to use the minibar for storage. I measured the width of a fitting size cabinet door. Then I put in a nail at both sides and used a strip of wood veneer to make an arched top. I made a small hole with a power drill in order to cut out the doors with a jigsaw. Afterwards i sanded the edges. Be sure to make an even cut since the wood from the hole will be used for the doors.
STEP 8: Cabinet Doors
I took the wood from the hole and used it for the cabinet doors. I used some spare wood to assemble and stabilize the boards. Then I used the circular saw to cut the boards in half. Afterwards I assembled the doors again with a little space between them so they wouldn't bind later on.
I put the hinges on the doors first and on the cabinet afterwards. To make the final look neat I made sure the space around the doors was even.
STEP 9: Skål = Cheers
When you are working with rustic materials it is more important to "take a step back" and look at it instead of measuring everything out.
7 Comments
MattTheMaker 9 years ago
Awesome use of recycled materials. I haven't seen anyone use an old flip style measuring device in a long time, nowadays all you see is retractable measuring tapes.
DK-learningbydoing 9 years ago
In Danish it called a "tommestok" and all Danish craftsman have one in their pocket.
you can not do without it! :)
Thanks for all the good comments. It inspire me to do more projects. :)
Porda 9 years ago
Great looking mini bar! I'll have to make one of these once I have a backyard.
Volthaus Electronics Laboratory 9 years ago
Nice that the pallet wood has a second life at the parties instead of going to the trash! Well done with english too. Keep woodworking and writing more Instructables.
Linc2005 9 years ago
seamster 9 years ago
Your mini bar looks great! Very well done!
Your english is good too. Can't wait to see what you make next!
