Simi Auto Marshmellow Gun
Intro: Simi Auto Marshmellow Gun
okay to start off i have tried all sorts of ways no make a marshmellow gun automatic and without costom makeing some sort of spring action thing in a machine shop i don't think there is a way. but heres a nice way to achieve simi auto-ness. now your probably going to say "well what aboutthis ? well thats closer to a shotgun dont you think?
STEP 1: What You Will Need
i have got two models one being the the rifle (in my opinion it works the best) and the submachine gun
heres what you need for a rifle ( all of this is 1\2 inch schedule 40 unless i say otherwise of course)
4 tees
1 45 degree
2 caps
about a 1 1\2' schedule 40 and the hopper is schedule 20 (more space in the pipe so the marshmallow can slid down) doesn't matter how long.
somthing to make holes in schedule 20 pvc pipe (like a power drill) hole cant be too big (see the pic)
wire to match the hole you made in the pipe (see the pic as well (that black thing sticking out of the hole)) you will need a whole ton of it believe me it gets used up quick (about 3 feet)
and of course mini marsh mellows.
4 tees
1 45 degree
2 caps
STEP 2: Assemble
the proportions are not a big deal just look at the pic thats the rough design. i also have the sub machine gun down there if your interested.
STEP 3: The Mag
all righty now make holes about 3\4s of an inch apart through both sides (obviously). now cut the wire in to 2 1\2 inch segments. now its done. make sure you leave a gap of holes for the cap on the end and the tee piece on the gun at the bottom.
STEP 4: Loading and Firing the Gun
fit the mag into the gun and slip one of your wire segments in to the closest hole to the bottom (the bottom being the end in the gun) then drop a marshmellow down the mag at the top then slip another wire in at the hole above the marshmello and slid another marshmello in do this untill you reached the top and put the cap on now remove the bottom wire and the marshmellow will fall into the gun and you can blow (try to make it a quick burst of air) then the 2nd wire then the third and so on. as you will see it jams somtime but a lot less i can assure you then if you had no wires at all. and thats it.
29 Comments
xenongamer 15 years ago
yugiohmaster2323 12 years ago
xenongamer 12 years ago
The hopper, magazine, or thing that feeds marshmallows into the weapon, has twist ties holding back each marshmallow. By pulling out the twist ties, the marshmallows fall in. I thought it was innovative.
whitish 15 years ago
AzraelUK 13 years ago
14guy 13 years ago
bob the builder #1 15 years ago
DungMachine 14 years ago
toogers 14 years ago
Anton1995 16 years ago
whitish 16 years ago
HuntingWabbits 14 years ago
firefighter1333 14 years ago
And I am not a princess.
sgt. frog 14 years ago
Archy 14 years ago
mortso 14 years ago
Thelonelysandwitch 15 years ago
