Simple Laser Tripwire
Intro: Simple Laser Tripwire
This is a tutorial for a small laser trip wire to keep things safe.
Things you will need
Wires
Photo-sensor
10k ohm resistor
pk buzzer
laser pointer
soldering iron and soldering
an arduino and a bread board
Use the fritzing diagram above for assisstance
STEP 1: Step 1
Solder together the 10k ohm resister and the photo-sensor so they can fit in the same hole in the bread board.
Add them to the bread board
STEP 2: Step 2
connect more wires and you can calibrate the photo-sensor with the following code
void setup() {
pinMode(4, OUTPUT);
Serial.begin(9600);
void loop(){
digitalWrite(4, HIGH);
Serial.println(analogRead(0));
more details here:
http://arduino.cc/en/Tutorial/Calibration
STEP 3: Step 3
The final bit of code to activate the alarm
int buzzPin = 11;
// buzzer connected to digital pin 11
void setup() {
pinMode(buzzPin, OUTPUT); // sets the digital pin as output }
void loop(){
if(analogRead(0) < 850){ // this number depends on calibration of the photocell
digitalWrite(buzzPin, HIGH); // turns buzzer on
delay(1000); // waits for 1 second
digitalWrite(buzzPin, LOW); // turns buzzer off
} else{
Edbed 8 years ago
