Unwrapped: Kommunikations-Gully
Intro: Unwrapped: Kommunikations-Gully
Connect (at least two) duct-covers acoustically to bulid a communication system within the city.
A «unwrapped - Aktivierung städtischer Objekte» project: http://thinkunwrapped.org
Watch the movie: http://www.youtube.com/watch?v=q94EyO73Trg.
Concept developed in the «unwrapped» seminar in Graz: http://www.thinkunwrapped.org/index.php?id=75
Concept realised by the unwrapped team: http://www.thinkunwrapped.org/index.php?id=86
STEP 1: Material
a walkie-talkie
STEP 2: Material
a headset with a baby microphone
STEP 3: Material
active loudspeakers
STEP 4: Material
a wooden box, a flexible plastic, aluminium tape, glue, screws, orange spray
STEP 5: Material
a bag
STEP 6: Material
street tape
STEP 7: Construction
wooden box:
- wooden box: 10 x 21 x 5 cm
- 1 hole for the microphone
- 2 little holes for the cables
- 4 small screws on the box (construction to fix later the plastic)
- 1 big screw (later for the electric contact)
- 4 holes on the side (to fix it later on the duct cover)
STEP 8: Construction
- tape (to fix the elastics)
- elasitcs (for the walkie-talkie
STEP 9: Construction
- microphone into the big hole
- each part of the headset switch into one small hole
STEP 10: Construction
- stick the aluminium tape on the flexible plastic
- one headset switch cable is connected to the aluminium tape
- one headset switch cable is connected to the big screw
STEP 11: Construction
- connect the head-set cable on the walkie-talkie
- fix the walkie-talkie with the elasitcs
- fix the cables with the elastics
Information:
- this antenna in not necessary
Information:
STEP 12: Construction
et voilà
STEP 13: Installation
open a duct-cover
STEP 14: Installation
- put the active loudspeaker into the bag
STEP 15: Installation
- fix the bag with cable ties on the duct-cover
STEP 16: Installation
- fix the woode box with cable ties on the duct cover
STEP 17: Installation
- stick the street tape around the duct cover
STEP 18: Installation
- and let people interact
30 Comments
Maxaxle88 16 years ago
graymalkn 16 years ago
william20 12 years ago
tristantech 14 years ago
You should make it power itself from the methane gas in the pipes!!
nutsandbolts_64 14 years ago
NathanaelScheffler 12 years ago
nutsandbolts_64 12 years ago
scraptopower 12 years ago
marc92 17 years ago
cself 15 years ago
conceptualstratagem 16 years ago
toogood 16 years ago
true_geek 17 years ago
James (pseudo-geek) 17 years ago
Scozza 17 years ago
randofo 17 years ago
Andrew546 17 years ago
Randofo, I'm surprised you didn't mention your Camouflaged Power-Source LiberatorCamouflaged Power-Source Liberator, this would be the perfect solution for this problem!
As far as location is concerned, from what i understand, location is irrelevant, as long as its publicly accessible. So this, combined with your project, could be put on or near an outlet, where its much less likely to be damaged, and I'm sure someone could come up with a way to secure it, even if it meant chaining it to a pole.
I'm sure that it wouldn't be too hard to make a better antenna or something to extend the range.
5Volt 17 years ago
Also: in the main picture the subject turned his back to a Fiat 500L (in a pretty good shape, apparently). Shame on him !
Ciao e complimenti.
5V.
FrenchBelly29 17 years ago
