Usb Wifi Antenna
Intro: Usb Wifi Antenna
this is the 1st. version of my usb wifi antenna. it has been inspired by:
https://www.instructables.com/id/EQARE4I72GEPUCHTHU/
http://www.usbwifi.orcon.net.nz/
i did not have immediate access to "Chinese parabolic cookware" however i will use one next time. instead,i used an eight inch strainer , without the strainer i do not get a signal in my house. this entire instructable has been uploaded via the strainer/usb antenna.
STEP 1: Purchase Usb Wifi
i used the belkin wireless G usb adapter. it comes with a base and some cable.
STEP 2: Purchase Strainer
this one is an 8 inch strainer with a handle.
STEP 3: Make Hole in Strainer
STEP 4: To Get a Better Signal Push It in About Half Way!!!
STEP 5: Connect to Friends
i am getting this signal from across a river.
175 Comments
Hypoherald 6 years ago
I opened up a Tenda USB wifi card that plugs in with no extension cable, drilled a 1/16th hole in the plastic cover, soldered a single speaker wire (about six feet long) to the tiny circuit board squiggly antenna, ran the wire through the hole and closed it again. Luckily my living room window faces an xfinity hotspot. From my desk by the window, with the wire taped to the top of the window, my signal strength went from one bar to the max. If anyone know the frequencies for xfinity wifi signals I could probably trim the antenna length to get even better reception.
treii28 7 years ago
But uh, the antenna in a dongle like that tends to be essentially a coil printed on the PCB. Meanwhile, the shield of the USB connector that is basically electrically tied to your strainer is usually tied to the system ground.
Ever hear of a Faraday cage??
seth1510 8 years ago
MuhammadT9 9 years ago
i thinks its not better idea.................................. dufer
GorillazMiko 11 years ago
GM
244 Jake 12 years ago
Big Jake
TheITSystem 12 years ago
simple_punk88 15 years ago
xavieronassis 12 years ago
runganwt 15 years ago
n3glv 15 years ago
frollard 15 years ago
The dish is not receiving the signal, its bouncing it into the built-in antenna
its making a uni-directional receiver a directional receiver. If your usb dongle is too deep, i.e. not in the focal point, the amplified signal is simply missing the receiver.
wombat7 15 years ago
henyobarker 15 years ago
xXFor_The_WinXx 12 years ago
BTW, it's only nice to get answers to your questions posted here rather than asking to have them emailed to you. Other people are probably having the same questions you are and would like to find the answers also.
bluemeanie 13 years ago
keebmn82 13 years ago
everyones a chump 15 years ago
n3glv 15 years ago
