Introduction: DIY 2WD RC Stunt Car V1.0
Welcome to my another instructable.In this instructable i will show you how to make a cheap 2WD RC Stunt Car in a easy way.I hope You like my instructable and dont forget to favourite my instructable :D
What Is RC Car ? :
A remote control vehicle is defined as any vehicle that is remotely controlled by a means that does not restrict its motion with an origin external to the device. This is often a radio control device, cable between control and vehicle, or an infrared controller. A remote control vehicle or RCV differs from a robot in that the RCV is always controlled by a human and takes no positive action autonomously.
Step 1: Parts and Tools :
1: 1X Motor Gear Box
2:Piece of Plastic (will be used as chasis)
3:(Optional) Small Piece of cardboard For balancing The Chasis .
4:6v Battery pack
5:PVC Tape
6:Remote control Chip (very important)
7:On/off button
8:(optional) LED
Step 2: Check the RC Chip (important Step)
Before Making this RC car You have to Check the rc chip it is very important because if you dont check then it will be a Big Problem for you .^_^
Step 3: Tape the Gear Box:
Tape the Gear box to the bottom of the Plastic piece as shown in the pic and be sure that the tires of the gearbox are not touching the plastic.
Step 4:
Make a 6v battery pack for your rc car if you don't know how to make it then see my this instructable Click here .
Step 5:
Connect the battery pack wires to rc chip to v+ = battery positive ,v- = battery negative
Step 6:
Connect the gear box wires to rc chip :
MF - Positive terminal of the Gearbox MB - Negative terminal of the Gearbox
Step 7:
Connect the button directly to the battery and connect the led positive terminal to LED+ and led negative terminal to LED-
Step 8:
Tape the wires joints so they cannot be touched to one another >
Step 9:
Tape all the things to the Chasis And you are ready .Test it .
NOTE: It is upgraded to its version 2 :DIY 2WD RC stunt Car v 2.0
Soldering Challenge
Metal Contest
