Introduction: From Old Bedsheets to New Rugs
I don't like to throw away anything that still has some use left in it.
Old bed sheets eventually get holes in them, making them no longer useful as sheets.
They can't be sent to a second hand store for someone else to get some use out of and I really hate to see them go into the landfill.
So I save old sheets and turn them into new rugs that are not only practical, but are also a very nice addition to your home.
These rugs are machine washable and last for many, many years.
That's Charlie in the photo, who loves to sit in the kitchen in front of the sink where the blue and white rug is now located. His new favorite spot.
We love having it on the floor as it is thick and comfortable. It gives good padding under your feet and keeps them warm when the weather is cold
The how to details are for this new blue and white rug, which is 20" x 24" in size, perfect for in front of the kitchen sink.
The larger rug is 25" x "40 inches is made the same way, just using more chain stitches to start. I will explain more as I go along.
Step 1: Gather Your Materials
20" x 24" rug
2 flat or fitted double bed sheets
10 mm crochet hook (US size N/15 - UK size 000)
Scissors
Ruler
Large darning needle
25" x 40" rug
To make the larger rug - you need to have at least 3 bed sheets
* If you don't have any old sheets at home to use, you can purchase them for a reasonable price at a second hand shop
Step 2: Prepare Your Fabric Strips for Crocheting
Using your scissors, trim the seams off the sheet
For a fitted sheet, you need to trim off all four corners and the top, bottom and side finished edges
For a flat sheet, you just need to trim off the top, bottom and sides of the sheet
You are going to be ripping the sheet into strip and you can start anywhere on the sheet you prefer, but I like to make the strips as long as possible so their are less joins in you bed sheet "Yarn"
Using your ruler, measure and cut 1/2" - 1" strips along the end of your sheet
Then, start to rip the sheets into 1" wide strips
Continue until you have a pile of strips ready for crocheting
* You will get lots of thread strings when you rip the sheet. Just pull these off and throw them away
* You can rip all of your sheet at once, or do it a section at a time as you begin to crochet your rug
Step 3: Join the Strips Together
You can just tie the strips together, but that leaves large knots in your "Yarn" so I have found a lump free way of joining the strips of fabric.
Start by folding about 1" of the end of your strip and cutting into it about 1/4" so that when opened, it has about a 1/2" slit near the end of the strip.
Do the same with the next strip of fabric.
Push the strip that you are adding, through the slit in the other strip
Then take the other end of the strip you are adding and pull it all the way through the slit to make a knot as shown in the photos
Step 4: Start to Crochet Your Rug Using Your Fabric Stips
These are instructions for the 20" x 24" rug
Use your 10 mm hook
Chain 7 sts
In the 2nd chain from the hook, sc 1 and in each of the next 5 sts
In last st, 3 sc
Turn your work so you are crocheting in the other side of the foundation chain
Sc in each of 4 sts to the end, then 2 sc in last st.
Continue to work in rounds...
3 sc in next st (corner)
Sc in 4 sts
Sc in 1 st
Sc in 5 sts
Sc in 2 sts
On your next and every round, 3 sc in each corner of your round ( the middle stitch of the previous 3 sc)
And sc in every other st between corners
Continue increasing in this way, working around the piece
Change color as desired as you work in rounds as shown in the next step
Step 5: Join Your Second Colour
Use the same technique to join your strips as you did in step 3
Just join another color strip to change colors and continue working around the piece
You can make as many rounds as you desire until the rug is the size that you want.
In this example, I crocheted 18 rounds
Step 6: Sew in the End of Your Fabric
Using a large darning needle, join the last st to finish the round
Then pull the end of the fabric strip though a few stitches in the back of your rug and trim the rest off to finish
Step 7: The Larger Rug
The 25" x 40" rug is made the same way except that you start with a chain of 26 sts
And work rounds in the same manner as in step 4
This rug has a total of 25 rounds
* You can make your rug any size that you desire
Runner Up in the
Rugs Challenge
