Introduction: Mini Lego Starship Enterprise
Happy 45th Star trek!
This will show you how to make a Starship Enterprise model out of Lego's.
Most of the pieces included shouldn't be very hard to come by.
See also:
https://www.instructables.com/id/Mini-Lego-USS-Voyager/
https://www.instructables.com/id/Lego-Deep-Space-9/
https://www.instructables.com/id/Mini-Lego-USS-Titan/
https://www.instructables.com/id/Mini-Lego-USS-Kelvin/
Step 1: Pieces
The pieces needed are listed here.
Step 2: Lower Body
Put the 2x2 and the 2x4 together as shown.
Step 3: Middel Body
Add a 2x4 on the 2x2.
Step 4: Rear
Put the 2x3 on the back.
Step 5: Hinge Plate
Add hinge plate to the 2x3.
Step 6:
Add the hinges on the 2x3.
Step 7: Engine Base
Add the black clamps to the center of the hinges.
Step 8: Start Your Engines
Put the connector pegs to the 1" connectors.
Step 9:
Add the gray cylinders to the connector pegs.
Step 10:
Add the small wheels to the other end of the connector pegs.
Step 11:
Add the other wheels to the gray cylinders.
Step 12: Finish Engines
Add the transparent blue studs to the wheels.
Step 13: Attach Engines
Attach engines to the black clamps.
Step 14:
Add the 2x2 circle plates to the inside of the disks.
Step 15:
Put the red axle in the axle hole on the 2x2.
Step 16:
Add the disk on to the body.
Step 17: Finished!
Put the other 2x2/disk on the red axle.
The ship is done keep reading for the base.
Step 18: Start Base
Flip the ship upside down.
Step 19:
Add the hinge brick.
Step 20:
Add the center stud piece.
Step 21:
Attach the clear rod to the center piece.
Step 22: Finish Base
Add the clear bowl to the rod.
Step 23: Done
You can also adjust the stand on the hinge brick and the clear rod.
Flip back up and you are done! Enjoy!
4th Epilog Challenge
