DIY IR Droid Module - 3.5mm to Infrared - Breadboard Prototype
I have built this on my breadboard, powered with 6V 150mAh AC-DC converter. First connect saw at least one of the LEDs flicker dark orange and then go out. Assuming this means I burned it out, as afterwards I didn't notice any response.
To prevent burning IR LEDs, I'll use visible LEDs, but I'm still concerned that my breadboard has a mistake. I'm pretty much worthless (but willing to learn, at least outside of the classroom setting!) at Phys II, so the debugging is foreign to me. Pulling out the multimeter... What process should I be using to confirm that everything is powered correctly? The schematic is attached if you would like to customize your response to the hardware, but a general guide to debugging amplified LED circuits would be much appreciated as well!
Additionally, if amplification the best way to go? How about a relay? Does that not offer the same (not Phys II...) amplitude? Smaller the better!
Source List:
- Schematic - Attached PDF
- PCB Creation - http://www.instructables.com/id/Extreme-Surface-Mount-Soldering/
- Mounting plan - http://www.instructables.com/id/LEGO-Nikon-IR-Remote/
Thanks in advance!
Andrew
Oh, and I'll post a picture of it within the week to get another set of eyes. I must confess, it is a little ratty...
schematic.pdf10 KB
Visit Our Store »
Go Pro Today »
Man, electricity is awesome, but its not easy! Pretty sure I'm gonna have to put yours on my X-Max list! -- Oh, I should mention they are for sale now... after I go and learned how to make it myself... breadboard and all..
Just one Op-Amp and two 47K 1/8 W resistors in a follower configuration..
A
What, exactly, are you trying to do ?
Steve
Resistance and power Resistor Values:
Resistance = (Vtotal - Vled forware) / Current
Power = Voltage * Current
I'll probably want to operate the LEDs underpowered, since 6V, 100mAh is giving me over 1/2 watt. on a SMD device, I want to keep it well below that to use 0805 parts.
RadioShack doesn't give real details, but 100mAh, Vled forward = 1.28V
So... since these are in inverse parallel I'm really confused about how this effects the voltage. (It is my understanding that this allows the pulses to add to each other, or something about additive frequencies, or amplitudes or something.
Making progress, at least I think so. Just running a few more sets of numbers... Thanks for the start!
Steve
In any case, thanks for your help and let's see if I can be of any.
Yes.
Attempting to solve my problem without this schematic (and applying what little I know if Phys II, having failed it 2x) I would do it differently. Thus, if I may, submit a new schematic design for conceptual approval:
If I'm not crazy all I need is a battery source that fully powers my LEDs to a brightness I like, with of course a limiting resistor. (Put a pot on if you want crazy range; this schematic claims 30m on an ir remote!)
For 3.5mm input I just take the pos ground end to a relay and hook it into my circuit.
+ 3.5mm
-- {Relay}
-- 3.5mm
+ Battery
-- {Relay}
+ LED
-- LED
-- Battery
