How can I fix a gas tank crack?
I have an old chainsaw that has a little crack in the gas tank (plastic), it's not very big, but it will drain the entire tank in a few days, messing everything nearby. So, I had enough of the gas smell in my workshop and decided to repair it, but I don't know how. Can somebody tell me how?
Libahunt3 years ago
Epoxy with fiberglass. If it's not too tight give it few good layers all over the tank not just the broken part.
tgferreira184 (author)  Libahunt3 years ago
I can't do that becouse the leak is in the place where the handle meets the chainsaw, so, I don't have clearence for fiberglass
Vyger3 years ago
They make a kit for fixing gas tanks. Its intended for car gas tanks but will probably work with any tank. Included in the kit (at least with mine) is an epoxy that not only resists the gas but will actually harden while submersed in gas. You can fix a cars tank even when its leaking. I had the tank in my pickup leak and the stuff worked like a charm. You can get it an auto parts store.
rickharris3 years ago
In the long run it may be better to buy a new tank - they can't be expensive.
Epoxy (Josehf Murchison ) may work
Steel gas tanks are easier just clean and fiberglass, my old F150 had a tank like a sieve until I glassed it.
Joe
Flush and wash off the tank with ethanol when it is clean let it dry then epoxy.
Joe
